Question about LG L4200A 42 in. HD-Ready LCD Television
  • Anonymous Mar 02, 2008
    I have the same problem
  • Mats Gustavsson Aug 24, 2008
    Yeah, same problem here, backlight on but no picture, no OSD, nothing. One red LED is lit on the powersupply circuit. Have measured up the cables that goes from powersupply to the signalboard and everything looks ok. Please help !!
Hi again !
After a few (6) hours of troubleshooting i finally fixed it !!
Underneath both powersupply and signalboard, there is a third circuitboard that sends the signal to the monitor it self (i guess). On that board there was a small, small fuse, it said F1 and 1,5A, 63V.
Soldered two cables and put a regular glass-fuse instead. Voila, it works !! Hope this helps for someone else.
Posted on Aug 24, 2008
My 42" LG did that exact same thing all it was was a 71 cent capacitior that controls the input functions. It is located on the main power supply board on the left side of the tv (with the back off looking at the back) if this is your problem you will be able to see the end of the capacitior buldging out a little bit (if you dont know for sure ASK someone) If you can't find the capacitior you need anywhere local go to they will have anything you'll need just make sure you get the same microfarad rating. Hope this helps someone.
Posted on Oct 15, 2008
Lg tv power light comes on but screen stays blank
If you can't see a faint picture with the flashlight then the T-con board is gone. If you can see a faint picture, then the led driver or ballasts for the back lights quit. You can get parts from here: TV Parts Universal TV Stands DLP Chips ShopJimmy
Dec 05, 2016 | LG Televison & Video
Troubleshooting Flat Panel Monitor issues. Screen is blank and power indicator...
Screen is blank and power indicator is off
The monitor is possibly not receiving power. Perform the following steps to fix the problem:
  1. Ensure that the electrical outlet and the monitor are both switched on.
  2. Check that the power cord is firmly plugged into the electrical outlet and the power supply unit.
  3. If the power cord has a removable fuse, replace it.
  4. Try another power cord.
  5. Try another electrical outlet.
  6. Check the power connection at the back of the panel.
Screen is blank and power indicator is steady green
Brightness and Contrast may be too low. Adjust the brightness and contrast using the On-screen display controls (OSD) by selecting the button
Screen is blank and power indicator is steady amber
The monitor is in the Power Management Standby state. The power management feature is invoked when the computer recognizes that you have not used your mouse or keyboard for a user-definable period. Perform the following steps to bring monitor out of the power management state:
  1. Press any key on the keyboard or move the mouse to restore operation.
  2. Check the Power Management software on your computer.
  3. flatpnlmont12.jpgPress the (OK) key to switch between analog and digital mode. If the panel is the wrong mode for the signal being provided, the monitor appears to go into sleep mode.
Screen is blank and power indicator is flashing green
Display mode of the computer is outside the range of the monitor. The display mode the monitor uses is controlled by your computer. Therefore, you should refer to your computer's documentation for details on how to change display modes.
The image size, position and shape may change when the display mode changes. This is normal and the image can be readjusted using the IMAGE SETUP and the monitor controls.
Note: Unlike CRT monitors, which requires a high refresh rate to minimize flicker, TFT technology is inherently flicker-free. If possible, configure your computer for 1600 x 1200 addressability at 60Hz vertical refresh rate.
Use the following table as a guideline and reconfigure your computer to use a supported display mode. The highest resolution (for example, 1600 x 1200) produces the optimal output, but limitations of your monitor may prohibit this setting. Adjust the addressability mode until an image appears.
CHECK SIGNAL CABLE" message is shown and power indicator is steady amber.
The monitor is not receiving a video signal. Perform the following steps to fix the problem:
  1. Check that the signal cable is firmly connected to your computer
  2. Check that no pins are bent in the signal cable connector.
There are noises in the video signal. The IMAGE SETUP function is used to adjust the level of noise in the video signal which causes horizontal lines or areas where the image appears to be unstable and jitters or shimmers. This can be done automatically or manually.
Note: It is not applicable to digital input.
Use the image setup fix the problem:
  1. flatpnlmont6.jpgSelect (Image Setup) menu in the OSD.
  2. Select Manual to adjust CLOCK/PHASE settings.
Image appears to be discolored
The color setting may be incorrect. Perform the following steps to adjust the color settings:
  1. flatpnlmont8.jpgSelect (Image Properties) from the OSD menu.
  2. flatpnlmont9.jpgSelect (Color Properties) to adjust the color mode you find most comfortable or fine tune the colors using the Custom menu.
A few dots are missing, discolored, or inappropriately lighted
A small number missing, discolored, or lighted dots may be present on the screen, which is an intrinsic characteristic of the TFT LCD technology and is not an LCD defect.
Using On-Screen display (OSD) controls
flatpnlmont12.jpgThe settings adjustable with the user controls are viewed through the OSD. Press the (OK) button to display the main OSD menu.
OSD main menu:
Note: The LCD monitor needs time to become thermally stable the first time you turn it on each day. Thus, to achieve more accurate adjustments for parameters, allow the LCD monitor to warm up (be on) for 15 minutes before making any screen adjustments
on Aug 08, 2010 | Televison & Video
I have a hp 1530 flatscreen monitor when I push the menu button on the screen it blacks out...and says osd lockout...what does tht mean...I have to unplug it in order for it to come bck up
OSD means On Screen Display. To unlock the OSD hold the power button of the monitor until you get a message similar to "OSD unlocked".
If you still have problems, click on this link for further instructions :-
Dec 29, 2010 | HP Televison & Video
Push the button on the Monitor to activate the OSD (On Screen Display). With the OSD, one can "stretch" the picture (horizontally/vertically) and "move" the picture (horizontally/vertically) in order to "fill" the viewable area with your compueter's output.
May 09, 2010 | LG Flatron F700B 17" CRT Monitor
The language on my menu has changed to Russian. How do I get it back to English
Press one of the buttons on the monitor to activate the OSD (On Screen Display). Wait about a minute -- the OSD probably will cancel itself, if you've pushed the correct button.
Then, use the other "left/right" or "up/down" buttons to navigate through the various settings (contrast, brightness, et cetera) until you get to the "language" setting. Press the "accept" button to select it.
Press "left/right" or "up/down" until 'English' is displayed. Press the "accept" button to choose that language. Then, wait a few minutes, for the OSD to "self-cancel".
Apr 24, 2010 | LG Flatron L1750S 17" LCD Monitor
I was watching the tv, when the screen went blank but the voice was still on, then smelled something awful, like something plastic melting, then noticed a lot of smoke coming up from the back of the...
Most probably, Electrolytic condenser in the Power supply to display circuit may have punctured resulting in smoke coming out. Take tv to service centre. There is no other option.
Good luck.
Rating the solution is highly appreciated.
Mar 15, 2010 | Polaroid TDA-03211C 32 in. LCD HDTV
On screen display is locked. Fix it by:
The OSD can be enabled or disabled by pressing and holding the Menu button on the front panel for 10 seconds. If the OSD is locked, the warning message OSD Lock displays for ten seconds.
* If the OSD is locked, press and hold the Menu button for 10 seconds to unlock the OSD.
* If the OSD is unlocked, press and hold the Menu button for 10 seconds to lock the OSD.
Mar 14, 2010 | LG Flatron L1951S 19" LCD Flat Panel...
My monotor its all black but u can
This should be an (LCD) screen. They are the ones that usually have this kind of problem. You will need to take it to have it checked if the problem is the VGA signal cable leading to the monitor. They will check if it is properly connected or has gone bad. It is very unlikely that the screen is bad. When this VGA signal cable goes bad it could result in a totally blank screen.
Sep 13, 2009 | Dell Computers & Internet
W2361VG Monitor "OSD Locked" and service menu
This just means the On Screen Display (OSD) is locked. Press and hold the menu button on the front panel for 10 seconds.
Aug 29, 2009 | LG L1915S 19" LCD Monitor
Using buttons on monitor to control color, etc
some monitors, I do not have a manual for, however after 5 min I can usually figure out how to operate the osd. menu then up down then menu again if not that then push a few buttons and see if you can select what you need.
May 27, 2008 | LG Flatron L1710S 17" LCD Monitor
LG L4200A 42 in. HD-Ready LCD Television Logo
414 people viewed this question
Computer Repairing
Computer Repairing
