Question about TruTech PLV16320 Television
Akai lct42z6tm Help, I just bought this t.v. no manuals How do I hook up my cable no cable connecter ???? I have a trutech monitor. We previously used this for a TV, using our cable box. The place we just moved to, doesn't offer the cable box. Do you know what exactly i need to buy, to make this work? Thanks.
    President:
  • 814 Answers
You have to buy a adaptor for coaxial to television antenna hook-up. One side is used to hook up the cable to and the other side is to hook up to you televisions antenna's screw hook-up. These adaptors can be bought in most electronic stores and you should be able to find them on line. Just use google for cable to television adaptors. I hope this helps you with your problem.
Posted on May 17, 2009
Without a coax. imput , how do i connect my cable
You have to use a cable box using the Red, Grn, Blue outputs along with the red & white audio, or use the HDMI if the box and your set has it.
Apr 08, 2010 | Akai LCT42Z6TA 42 in. LCD Television
Fixed capacitors but now my colours are jumbled
It should have a year parts and labor warranty with the manufacterer. Contact Akai for auth serv. you will void your warranty if you tamper with it.Check connectiond on t con board lvds cables. same on all inputs?T con board could be bad.
Sep 13, 2009 | Televison & Video
My Akai LCT42Z6TM TV does not have a coaxle
A converter box isn't going to fix this problem.
Your TV is a Monitor. It doesn't have a built in tuner. That's why it doesn't have a Cable/Ant coaxial port.
The TV needs a cable box for tuning or some other outside source box for receiving signals.
Are you using cable from the cable company or an antenna for reception?
Apr 23, 2009 | Televison & Video
AKAI 48 in. LCD HDTV with bad signal board
Option 1
The web site shopjimmy.com has tons of parts for your TV.
I looked through it and they don't have a signal board right now.
It's the best place I know to find the parts you need.
Sooner or later, they should acquire one.
Option 2
Fix the signal board.
Try to find a SERVICE MANUAL for your TV on the web. This manual will have parts list, schematics, and test points for circuit boards for your TV.
A electronic tech should have no trouble fixing it.
Good Luck
Feb 21, 2009 | Akai LCT42Z6TA 42 in. LCD Television
Hot to hook up cable
This monitor with a television tuner does not have a coaxial connection. I was able to get cable by connecting (buying if you don't have) to my dvd/vcr which had the coaxial connectors. Then I ran the video component cable (green, blue & red - had to buy that) from the tv to the dvd/vcr. Then I ran the audio cable (red & white) from the tv to the dvd/vcr. A little tricky figuring out where on the tv to actually connect but eventually got it. YUV2 on the side.
Dec 24, 2008 | TruTech PLV16320 Television
Coaxial cable hook up
Aug 26, 2008 | TruTech PLV16320 Television
Akai lct42z6tm
The "tv" you bought is actually a monitor, meaning you need a cable converter box to actually watch cable with it.
Jan 12, 2008 | Televison & Video
TruTech PLV16320 Television Logo
309 people viewed this question
Top TruTech Televison & Video Experts
Jason Morris
Are you a TruTech Televison and Video Expert? Answer questions, earn points and help others
