Question about GE DVLR223 Dryers
I hear the motor but basket not moving - GE DVLR223 Dryers
  • 530 Answers
Open the door
look up and you will see 2 screws
remove them
pull the lid towards you to remove
make sure unit is unpolugged
your belt is probably broke
if you do not see a black band in the center of the drum
that is your problem
let me know what you find
Thanks
EG
Posted on Feb 07, 2010
I have an LG front load washing machine and when it spins I can see and smell smoke. Some say it might be a belt but I just don't wanna go from that. Can someone plz help with this issue.
Hello sir
First you need to do something before attempting
To get an exspensive repair it or just buy a new unit.
Unplug from utility power
Open door and try to spin the basket by your hand
First attempt clock wise then counter clock wise
If you hear a deap ticking sound that increases with speeding up it's the motor damaged
If you hear a hissing sound the bearing and maybe the basket shaft try to pull outside the basket of it moves them its confirmed from bearing problem.
Smoke could be the belt sliding on the pulley but evenually will get out from position
Depends on the smell
If it's like burning charcoal then the motor or wiring got a water leak from inside washing machine on the motor also check pump by visual to see if the outside bodey rusted .
Regards
Feb 28, 2016 | LG Washing Machines
Kenmore agitates doenst spin
You will have to look at the inside of the washer when in spin cycle to see what is going on. Is the spinner motor not engaging the drum? Is the spinner working at all? It sounds like the spinner isn't being moved against the drum before the spin cycle starts. Most washers use a seperate spinner motor, which is lifted off the drum by a relay and / or solenoid and if one or more of those is malfunctioning, it will cause your described problem.
Dec 22, 2007 | Kenmore Elite HE4 Electric Dryer
Dryer motor hums, basket does not turn. If you move the basket by hand then try restart, it will work. Happens each time.
test the belt if there are tight? or loose? . If there are o.k the problem is Motor or control board, see in both cases if the voltage are entering to motor terminal , and output from control board is out to the input to the motor ? use the VOM. repair or replace.
God bless you
Oct 01, 2013 | Dryers
Kenmore Elite oasis washer code F54
F54 is a Motor Control Overcurrent.
1) check to see if there is anything between basket and agitator this can cause this error.
2)move the basket .. should move freely
if all is clear then most likely you will need a new motor
Jun 12, 2013 | Washing Machines
Tub does not move during wash cycle;just keeps filling;timer jumps from 25 to 4:then drains;flashes OL(small loads)
First, OL/UL stands for "Overload", so in other words, the washer things the tub is too hard to move because it's overloaded and the motor is struggling or the unit is way out of balance causing the washer to struggle. The most common problem is a nut below the inner tub that needs to "float". Floating is when the tub fills up with water to a certain level the inner basket will rise about 1 inch from the center agitator. What this does is disengage the basket from the motor so that the agitator can rotate independently from the basket. If the basket does not float then when it tries to agitate the whole basket will turn back and forth at the same speed as the agitator and this will cause the OL/UL error code.
Nov 21, 2012 | Maytag Bravos MTW6600T Top Load Washer
Washing machine operates sporadially
What made you replace the motor? Sounds also like a transmission problem. You motor reversing in spin but gears for agitate stripped in gearbox. Double check motor/coupling alignment. Pull the motor back off and turn the gearbox drive shaft both directions. One direction makes the basket turn, the other direction makes the agitator turn. If the agitator does not move, the gear case is bad.
Feb 17, 2010 | Washing Machines
Whirpool model GSQ9669LW1 basket does not spin after replacing the broken coupler between motor and transmission. Motor showed good continuity using volt-owm meter on ohms setting on low, medium, and high...
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, phone number, address and the model and serial number for your washer.
Apr 06, 2017 | Whirlpool Washing Machines
No locomotion or spinning of basket
william
i would check the coupler on this unit
it sits between the motor and transmission
this is a three peice part it is a rather easy repair
just goto appliancepartspro
type in your model number
look in the motor transmission block
motor coupler
Oct 13, 2009 | Washing Machines
My ge profile washing machine went off balance and moved across the room.the basket is no longer centered. is the basket broken?
Hhi, It could be the basket brackets have jump over the shipping bracket and will not let the basket center it self.
There are 2 clips in the gap between the top and thefront panels. use a flat blade and push in on the clips releasing the front panel. It will lift off. The bracket I mentioned is located under the motor. There are 2 brackets and they have holes in them. If the basket is lodged against these 2 brackets, just bend them down toward the bottom to get htem out of the way. They serve no purpose. While you have the front off, the basket hangs on each corner. Make sure eash corner is still attatches to the hangers.
I hope this helps you.
Please let me know if I can assist you further.
Vic
Jul 11, 2009 | Washing Machines
Washer won't agitate
Just fixed the same problem. Its a broken belt. Take the front panel off and to the right of the tub you will see a pulley and belt. We replaced both the pulley and the belt for around $40. Was real easy to do yourself.
Nov 27, 2006 | Frigidaire FEX831CS Top Load Stacked...
GE DVLR223 Dryers Logo
57 people viewed this question
Top GE Dryers Experts
John Tripp
John Tripp
JP Services
JP Services
Are you a GE Dryer Expert? Answer questions, earn points and help others
