Ice coming from unit?? WHy would ice be "spitting" from front indoor wall unit
  • 334 Answers
The unit has frozen up, and the fan is blowing out small particles of ice.
Freeze up is due to Improper airflow, and/or low refrigerant charge.
In the case of a heatpump, it can also be due to a malfunctioning defrost cycle.
Most likely, the filter and/or coils are dirty, causing an air restriction. I'd reccoment cleaning both coils and the filter. Let the system defrost, and run it again. If the problem persists, you have a refrigerant problem.
(or a defrost issue with a wall mount heat pump.)
Posted on Feb 07, 2010
Why won't the water come out of the in-door water dispenser? Why won't my ice maker make ice?
Be thoughtful of any water leaks. Water leaking beneath the machine will damage floors.
If both the ice maker and water dispenser are not working it is likely the feed connection from the wall to the unit. The hose/ copper tube can get kinked or the valve at the connection at the wall internally plugged. Close off the water at the wall and using a catch remove the connection at the unit open the valve at the wall and confirm the that water flows freely through.
Check the filter of the water located usually at the front grill near the floor. If the filter is removed the water connection will buipass the filter.
It is not likely with both the ice maker and water dispensor that both electrical solenoid valves have failed.
26159659-bocfglvi4lojepqiax35xhd0-1-5.jpg Hope this helps?
Apr 10, 2016 | Kenmore Refrigerators
Amana ptac unit blows air, it feels kind of cool, but it's set at 65 and it's not reaching the desired temp... does it need 2 be recharged or are my lines possibly froze...???
If the unit is frozen you should be able to see ice at the indoor coil. If you pull the air filters and peer inside to the indoor coil there may be ice. Either way it needs service. If no ice and blowing cool not cold it could be the condenser coil is dirty. On the outside you can see the air leaving side of the condenser coil. The air entering side is the side that gets dirty and can only be seen by pulling the unit out of the wall. Its best to leave it in the wall and call a tech that has experience with ptacs.
May 23, 2015 | Amana Heating & Cooling
In winter the outside unit sounds like a rubbing/ticking noise
Sounds like ice coming of the coil. That would explain the ticking. The rubbing could be ice buildup before the defrost cycle or it's building on the blades of the fan throwing it of balance a bit.
Feb 13, 2015 | Fujitsu Halcyon ASU12RMLQ Mini Split Wall...
Front grill
Check the air filter and if it is dirty, replace..
Turn equipment off and let the ice melt.
After ice melts, place a/c in cooling mode and set the thermostat to 3 degrees below room temp display.
The indoor unit fan should start blowing cold air immediately and then turn off once the room temp drops one degree below the cooling temp setting.
If the indoor unit does cycle off, check the outdoor unit and make sure it turns off at the same time.
If the outdoor unit continues to run and the indoor fan is not running, the indoor unit will ice up.
A defective compressor relay that is stuck in a closed position will cause icing of the indoor unit because it keeps the compressor running when it should turn off with the indoor fan.
Do you have an error code being displayed on the controller?
Is there an led light that is flashing on the indoor unit?
Another possibility causing the indoor unit to ice up is if the freon in the system starts to get low.
Make sure the ice has all melted for this next check.
Pretty easy to check without special tools.
If the air filter is clean and there is no dust/ dirt blocking the fins on the indoor unit, turn a/c back on to cool and check that the indoor unit fan comes on and is blowing air good.
Once everything seems to running good go to the outdoor unit.
There will be two lines with black rubber insulation covering them.
Peel back the insulation three inches on each line and observe the copper lines.
If either line starts to frost up the a/c system is most likely low on refrigerant.
Another cause of indoor unit icing could be that the aluminum fins behind the air filter are clogged with dust or other foreign material.
This would block the air that must be pulled in causing the indoor unit coil to become too cold due to lack of air flow and it will ice up.
Operating the cooling system when the outdoor temperature is below 60 degrees can cause the indoor unit to ice up also.
I'm Robert.
Florida certified a/c contractor. 30 years experience.
Hope this helps.
Mar 18, 2014 | Fujitsu Heating & Cooling
Comfort star
Make sure the indoor filters are clean. The outside unit will continue to run until the indoor reaches the temperature you have selected. Dirty filters can throw the temperature out. Its common for outdoor units to freeze up when on heating mode if the ambient air temperature is below 5 degrees Celcius.. The machine should however, defrost itself. There could be a problem with one of the pipe or air sensors on the outdoor unit.
Feb 23, 2014 | ComfortStar CHH012CD-13B Wall Mounted Mini...
What could be causing one of the wall mount units to ice up on a 3 port mini split hp?
Icing is caused by one of two things.
1. The air coming in is too much and has a lot of water vapor in it.
2. The evaporator is too cold. This could be because of a low refrigerant charge
Jun 04, 2013 | Fujitsu ASU7RLF HFI Wall Mounted Mini...
On cool will work for a short time. then will stop regardless of room temperature. If stopped for a short while then restarted will begin to spit water or ice.
Unit stopped by coil sensor when ice formed.
Problem due to weak capacitor of indoor fan motor/short of gas/coil & air filter dust blocked.
Replace fan capacitor/if short of gas, tap up some gas/clean coil and air filter.
Hope, it's helpful.
Feb 26, 2011 | Mitsubishi Heating & Cooling
The line coming into my indoor unit gets iced up. The ice extends the length of the line out to where in connects to the outside unit.
Icing in door due to 1. Less rpm of indoor fan motor (Replace capacitor or motor). 2. Indoor coil and blower wheel, filter dust blocked. (Service the unit). 3. Short of gas. ( Find for leak and arrest. Then vacumise and do gas charging)
Dec 24, 2010 | LG LS122CE Split System Air Conditioner
Frost on front grate unit, starting frosting up on thel ittle grates
Dip the thermostat into a glass of ice water. if the compressor stays on you have a bd control thermostat. Clean your coils. use a foaming coil cleaner that is non rinse for indoor use.
Jul 01, 2009 | Frigidaire FAC124 wall/Window Air...
A/C spits out ice
you probably have a plugged filter and or a dirty evaporator. pull the filter and see if it is dirty. it should be lockated right behind the front panel. The evaporator is right behind it. If they are both clean then the unit is low on refrigerant most likely. if it is low it is probably more worth wile to by a new window unit then having a service man out.
Jun 15, 2009 | GE AJCQ08ACB Air Conditioner
Heating & Cooling Logo
187 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
