Question about HP DeskJet 895cxi InkJet Printer
1 computers, 3 printers, all pink
I have two HP 895cxi printers and 1 HP 710c printer. All three print pink for color. I have changed out the cartridges in all three. Even the black print has a pink tone to it. I have cleaned, I have primed, I have turned off everything and back on. What's left?
  • 164 Answers
Routine maintenance and keeping full ink tanks will prevent this problem, however if you have the problem you can resolve it by doing the following:
1. Clean your print head using denatured alcohol solvent which can be purchased from most hardware stores. If unavailable, use 91% Alcohol (isopropyl alcohol (first aid antiseptic) which is available for less than a dollar at most Walmart pharmacy departments.
*Warning: You may want to use a pair of latex exam gloves as this is a messy process and can stain your fingers.
Supplies needed:
Isopropyl Alcohol or denatured alcohol
paper towels
latex gloves
sink, bowls and or basin
can of compressed air
very small screw driver
tablespoon or baby bulb type syringe
warm water
Time necessary 45-50 minutes
1. Lift print head from printer. It pulls out easily because it is held in with the same down lever that holds the cartridge in place.
2. Put two layers of paper towels in the bottom of a dish to protect sensitive sprayer heads.
3.Put enough solvent in dish to cover the screens on which the cartridges sit when in use.
4. Take the two small screws out that hold the white ceramic piece
5. Gently, pry the ceramic piece back and away , to reveal the underside (No need to pull away the glued points on the sides.)
6. Gently, move head up and down to slosh solvent around it the best as you can. Use a table spoon or syringe to pour solvent over all orifices in the print head, turning it upside down and then back a few times.
7. Use canned air with a plastic straw to blow into and through all orifices, alternately sloshing/swishing and pouring solvent over head (be careful not to touch any of the holes, screens, or sprayer heads with anything)
8. Empty dirty solvent from bowl and replace with paper towels and clean solvent. Soak for approx 10 minutes. Rinse again with clean solvent poured directly on all parts, letting solvent overrun and fall into dish or basin.
9. Gently shake the solvent off the head, take it outside and spray with compressed air into all orifices to clear out and help evaporate any remaining solvent. Let sit on a clean paper towel for approx 20 minutes. (There may be a little ink bleeding out of the head, but once it dries completely it does not present any problems.
10. Reinstall head, cartridges and it will print like a new printer.
SUGGESTION: For many years of problem free printing, keep a double set of ink cartridges, one set full at all times. Whenever a cartridge runs out of ink, replace it IMMEDIATELY, with a new one or a refilled one. This gives the print head no chance to dry out and create clogged heads. Routine maintenance of cleaning the heads every 24 months does wonders for keeping your ip3000 in new condition.
Happy Printing .
Posted on Feb 07, 2010
  • moofarm Mar 31, 2011
    I found this hard to believe, but I also had my 710C printing black and pink. Someone suggested taking the color cartridge and soaking the tip in hot water! I microwaved some water in a cup for 2 minutes, placed the end of the color cartridge in it for 30 minutes. I took it out and blotted with a paper towel until finally all three colors bled out. I dried throughly and put back in printer.... it works great. I might also add I had 2 new cartridges that this happened to.
Color Laser Printer Pink Tint
have you tried cleaning the charging wire and the transfer belt
Feb 17, 2014 | Ricoh Aficio SP C420DN Laser Printer
I have a hp officejet pro L7680 all-in-one printer.2007. I got new ink hp 88 combo pack & hp88xl black, but everything prints in pink color where the color part should be what ever the color is on the...
Go into the control panel in windows, select printer and select the properties for your printer.
Push the printing preferences button
Select services
Select service this device.
Press the device service tab.
Run all three tests.
Alignmet, Clean and print a test page.
Jun 28, 2008 | HP Office Equipment & Supplies
I put new print cartridges in my 960c printer. They are hp 78 for color and 45 for black and white. my orange ink light will not stop blinking. It is not printing
I have an HP DeskJet 1220C that has been working fine for two years now. All of a sudden it can only print in pink and black. It is driving me crazy. I have tried the following without any success:
1. Replaced the cartridges twice
2. Aligned and cleaned the cartridge from the
computer
3. Soaked the cartridge head in hot water,
and made sure that all three colors will bleed
out of the head
4. Cleaned the cartridge contacts with an eraser
5. Cleaned the cartridge contacts on the printer
with a brush
Is there a cure, or is it time for a new printer?
Aug 25, 2011 | HP DeskJet 960c InkJet Printer
I have installed new printer cartridge (Colour) and it is only printing blue. Cartridge is identical to the old one which printed OK.
I found this procedure hard to believe, but my 710C was printing black and pink only. Someone suggested taking the color cartridge and soaking the tip in hot water! I microwaved some water in a cup for 2 minutes, placed the end of the color cartridge in it for 30 minutes. I took it out and blotted with a paper towel until finally all three colors bled out. I dried throughly and put back in printer.... it works great. I might also add I had 2 new cartridges that this happened to.
Jan 12, 2011 | HP DeskJet 895cxi InkJet Printer
My hp deskjet 895cxi has worked so well for years
probably clogged nozzles. Clean the print head. If that doesnt work, replace the cartridge with a new one
Jul 23, 2010 | HP DeskJet 895cxi InkJet Printer
The color does not print black prints perfect but no color. WHat do I do?
check that the color cartridges have sufficient ink and also run the printer through a mantenance and nozzle check. Quite often cold temperature will clog the jets.
Please rate my help++++Thanks for using FIXYA
Jul 01, 2010 | Apple HP DeskJet 895cxi InkJet Printer
HP printer not printing true color all of a sudden.
Altho the cartridge is new, you may have used all of the ink of one color. Pictures take an enormous amount of ink to print and all three primary colors are used to create the hues and colors indicated on the picture. Try a new color cartridge and see if that works.
Mar 22, 2009 | HP Photosmart C3180 All-In-One InkJet...
HP OfficeJet R40 only prints in pink
I had 3 bad printing cartridges. I went to Staples bought a new 23 and everything is printing fine now.
Feb 29, 2008 | HP OfficeJet r40 InkJet Printer
HP DeskJet 895cxi InkJet Printer Logo
221 people viewed this question
Seeker5211
Seeker5211
