Question about Panasonic FV-08VKML1 WhisperGreen 80 CFM Premium Ceiling Mounted Continuous
Does the light on a FV-08vkml1 go on automatically with the motion sensor?...or does this unit need a switch...I have units w/o the light that do not need a switch...they are great. This installation needs a light as well.
  • 8,197 Answers
If you would like the light to come on with motion sencer then you need to ad a motion sencer switch. you can get them at the link below.
http://www.amazon.com/Zenith-SL-6105-WH-Motion-Activated-Switch/sim/B000OUW7MK/2
Posted on Feb 07, 2010
Just installed a motion activated light (model 021746). The light will not turn off; there is no switch.
in the installation notes , it probably reads to this effect
to run the light all the time --switch of power supply and switch on
to run a light sensor - turn the power off , back on back off back on
one action changes the internal program to leaving the light on , the other activates the sensor mode
the switch is the light switch that controls power to the unit
Oct 26, 2016 | Home Security
Installation instructions for a Cooper Wiring Devices OS310U-W-K Motion-Activated Occupancy Sensor Wall Switch, White
LED bulbs with leaking motion sensors tend to flicker as well, more so than CFL. I switched to Cooper style - but now my Cooper OS310u will sense motion - and keep sensing motion almost all the time. If it's in test mode - it will shut off but otherwise it keeps sensing it. This is in a garage - and door open or closed does not seem to affect it. I have the same unit working in my basement just fine.
suggestion - don't try LEDs to solve the problem and yes - it will burn out your CFLs real fast.
Jan 12, 2012 | Electrical Supplies
My journeyman motion light just quit working for no reason. The bubls are good. As mention it was working fine then just stop working. What could be the problem?
The motion sensor unit shorted to due to rainwater infiltration, if its like the last half-dozen motion sensor units I opened up. Take the unit down, open up the sensor unit head, and if its got moisture inside, you know why it quit. If not moisture, then they sometimes do what all electronic devices eventually do, they fail due to 1 of the components reaching its failure - every sensor has an MTBF
(mean time between failure).
Jan 05, 2011 | Heath Zenith Journeyman 270 Degree Motion...
We want to replace our bathroom exhaust fan. We like the Harbor Breeze 'Rosemont' model at Lowes. It's a decorative combo fan/light unit. The unit is equipped with 2 13 watt (60 Watt incandesant...
It does not matter whether you turn on the switch or the switch is motion
activated, the light does not know who turns it on.
The switch must be designed for florescent.
What do you mean by proper base, you have a single gang wall box,
that's a box inside the wall, with the electric and a switch,
The gang could be single or hold 5 switches, which ever is installed.
Most all switches fill fit into any gang box.
Feb 08, 2010 | Dryers
Dvd player to work while in motion
This can be done with a toggle switch or a relay.
**Toggle** Connect one side of a toggle switch to a ground and the other to the light green wire on the unit (parking brake input). Once the vehicle is started, just flip the toggle and apply ground. Taa-daaah.
**Relay** (see image)** This will bypass the parking brake automatically every time.
Aug 03, 2009 | Pioneer AVH-P4000DVD Monitor
Motion sensor light stay on
Hi, You don't say what the make or model is, so I will give you the best advice I can. Most motion sensor lights today have a switch or two on them for "on", "test" and then some time like 3 minutes, or 5 minutes. The switch is tiny so it or they are easy to overlook. The "on" position will keep the light on all of the time. The test position does different things on different models but you will want one of the time settings. If this doesn't work for you get back to me with a little more info and we'll keep on it. Good Luck!
Feb 06, 2009 | APC Electrical Supplies
My unit stays on 24/7, on bright, it's a heath/zenith dual bright
how old is unit. did it enter manual override? Turn off power for 2 minutes and turn back on. any better.
Jan 14, 2009 | Desa International 240 Deg. White Twin 150...
My motion sensor stopped working--the lights are full on all day.
Good Morning -
Make sure the bulb is point in the right direction and don't use an incadescent? bulb like a 60 watt bulb.
make sure you use floodlightor spot light bulbs so theydon't shine on the sensor.
Have a Great Day!!
Dec 09, 2008 | Electrical Supplies
Panasonic FV-08VKML1 WhisperGreen 80 CFM Premium Ceiling Mounted Continuous Logo
Top Panasonic Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you a Panasonic Hardware and Accessory Expert? Answer questions, earn points and help others
