Question about Keurig Elite B40 Coffee Maker
I need to obtain a replacement water holder - Keurig Elite B40 Coffee Maker
    Sniper:
  • 67 Answers
I know of this great! site, it sells all kinds of keurig products including replacement parts give it a shot i hope it helps http://stores.ilikenew.com/-strse-21/kuerig-coffee-maker%2Ckeurig%2C-keurig/Detail.bok
Posted on Mar 17, 2011
    Champion:
  • 213 Answers
What exact battery do I need for Seiko SKA348?
  • Remove back
  • Find battery holder
  • Note battery type
  • Obtain replacement battery
  • Remove old battery and install new
  • Check operation
  • Reinstall back
  • Set time, etc.
OR,
Take your Seiko watch to a jeweler who, for a reasonable sum, will replace the battery
ORORO
Nov 22, 2016 | Seiko Watches
I need to replace lock latch holder on fridgidaire front load washing machine
You can try to obtain the part you need directly from Frigidaire or possible an appliance parts dealer
Apr 11, 2013 | Frigidaire Washing Machines
My tail lights are not working on my 2000 jetta the front lights work the break lights work and the blinkers work all inside lights work just fine
you need new bulbs in tail lights one bulb in each side has two elements one works brake other works running lights the elements in the bulb for tail lites are bad . so just replace bulbs. hope this helps.
Sep 13, 2011 | 2002 Volkswagen Jetta TDI
It flashes 01 on the display and the bucket full indicator light blinks and it wont run.
If the water bucket has not been emptied the until will not start. If it has, be sure that the bucket was reinstalled properly in the holder and is making contact with the Water Level Control Switch on the back wall, inside of the bucket holder. The bucket should be installed "squarely" into the holder from top to bottom. The bottom of the bucket should not tilt down at the bottom when installed properly.
Hope this helps and thanks for choosing FixYa.
Aug 04, 2011 | LG LHD45EL Dehumidifier
How do I change the filter, (Holmes hm7204 Humidifier) Where does it go?
REPLACING THE FILTERS
Through normal use, waterborne minerals and sediment
become trapped in the wick filters. The harder your
water, the greater the amount of minerals in the water,
and the more often you will be able to monitor the life of
your filters in your humidifier.
You will be able to monitor the life of the filters in your
humidifier by checking the FilterCheck® Indicator. After
60 minutes of use, FilterCheck® Indicator will move and
indicate your filters condition. New filters will register in
the section reading Good filter. After frequent use of your
humidifier, the FilterCheck® Indicator will let you know
when the filters need to be changed, see Figure 2.
When the needle is in the CHANGE section, this means the
proper amount of moisture is not getting into your air due
to the excessive minerals and sediment that have become
trapped on your filters. At this point, you should replace your
filters. It is important to change your filters as
indicated to obtain stated performance level.
To replace the filter, follow the steps below:
1. Turn the unit off and disconnect from the electrical
outlet.
2. Remove the tank and main housing to access the base.
3. Remove the wick holder from the base of the humidifier.
4. Remove each individual wick and discard. Do not
remove rivet, replacement wicks come equipped with
rivets for easy replacement.
5. Follow the weekly cleaning instructions.
6. Insert new filters into each section of the wick holder
making sure the rivet attaches to the wick holder
securely.
7. Do not use wicks without rivets as this will not
produce the units intended output.
8. Replace the wick holder into the base and replace
main housing and then tank.
9. Repeat Operating Instructions.
It will take about 30 minutes for the humidifier to reach
maximum output.
Cheers!
Feb 14, 2010 | Holmes Products Cool Mist HM7204-U...
Icemaker overflows into holder freezing
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Sep 07, 2009 | Refrigerators
CAN NOT REMOVE WATER FILTER FROM PLASTIC HOLDER
it will also state to turn of the water supply and release any pressure
Jul 02, 2017 | Maytag MSD2651 HE Side by Side...
Cartridge holder broken
You could try the Lexmark parts store at
https://parts.lexmark.com/wpo-catalog/US_en/search_by_part
If they do not sell the part, if I were you I wopuld visit the second hand stores in your area (Goodwill,Value Village, Salvation Army,etc) and see if I could find a used printer with the part intact for a few dollars.
Thank you for using Fix Ya and please rate this solution.
Aug 18, 2008 | Lexmark Z600 InkJet Printer
Cartridge holder for BJC-4400
I have the cartridge holder you are looking for and wiould be glad to trade you for the black only cartridge holder. PRB4u@bellsouth.net
Jul 18, 2008 | Canon BJC 4400 InkJet Printer
Keurig Elite B40 Coffee Maker Logo
150 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
