Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
My cameras shutter is frozen shut. its a canonet giii model
  • 1 more comment
  • frank thomas wilson
    frank thomas wilson Feb 07, 2010
    add some solvent to the self timer (a few drops) and turn the camera around in circles for a minute with the lenses horizontal only the shutter will work. do this for a week everyday until it is freed up without using solvent again. this shutter will last you a few more years before it starts sticking again
    frank thomas wilson Apr 25, 2010
    This camera was made 25 years before the Digitals came out. Thanks fot the reply back
  • Arun John
    Arun John May 11, 2010
    Hi, I am sorry, but please explain your problem in a bit more detail. Does the camera turns on and display and all the other functions are working fine?
    President:
  • 2,653 Answers
I'd recommend visiting a local camera repair shop, otherwise you could damage the camera permanently.
Posted on Apr 06, 2010
My olympus sp-590uz will turn on but then act like it is frozen. I can't focus or shift to menus
I don't have an answer but I have had this problem too. I think it has something to do with the zoom/shutter control. Something broke on this and the camera can't be revived unless you shut it off and on again. I was in the Montparnasse cemetery in Paris when this happened and I suspect I might as well have buried it there.
Jun 29, 2012 | Olympus SP-590 UZ Digital Camera
Shutter frozen shut but makes noise did not drop. 10 min prior took pics
The shutter motor gear linkages are seized, the lens assemble will need to be dismantled for repair.
May 27, 2012 | Olympus FE-25 Digital Camera
Frozen shutter
The usual cause of this is a failure of the motor in the SQ unit that drives the mirror up and down, operates the aperture lever, and charges the shutter. This parts is so notoriously bad that it is on permanent back order at Nikon
Some of the other solutions with popped shutter blades - usually when I see this it is caused by the customer trying to clean his image sensor and having the shutter blades close on his/her tool.
Jan 17, 2012 | Nikon D40x Digital Camera
2g 16gb redsn0w 3.1.2 shutter on camera is frozen, can you help?
what do you mean?? Like you've taken a picture and its frozen on the shutter screen?
Dec 29, 2010 | Apple iPhone Smartphone
I have a Minolta X-370 camera that will not advance the film. Lever seems to be frozen.
The shutter is already wound and the shutter is not releasing.
You may have bad shutter release capacitors if the batteries are good.
May 11, 2010 | Minolta X-370S 35mm SLR Camera
Half the lense shutter will not close
It might need cleaning. You can try these:
1. Start and shut down the camera a few times to see if it shuts down itself.
2. If that didn't help, try this: you should be able to see the edge of the shutter if you look carefully towards the corner from where it was supposed to drop down. Get a pin or a needle, get a grip on the edge of the shutter with the pointed end and pull it down.
3. Clean it - Get a lint free cleaning cloth, dampen it with a lens cleaning solution and wipe the surface of the shutter. When still wet, start and shut the camera a few times. Repeat step 2 if required.
Oct 21, 2009 | Kodak EasyShare C613 Digital Camera
CLEANING SHUTTER ON CANON CAMERA
onion skin knowledge about cameras (more on how it interfaces with computers)
tried searching for the tool and i can't locate one, better ask a camera repair shop tech (i also passed this query to another expert who can better help you)
WD-40 comes to mind with torqued parts.
Dec 06, 2008 | Cameras
Nikon D80
Your question is not much clear. When the camera shut off?? eg, after pressing shutter, etc. Did you use original battery?? What is your camera age?
PROBABILITY :
Your camera might be have on/off button problem.
EXPLANATION :
I had experience this with my coolpix 8xxx (could not remember exact model). The problem is with nikon on/off switch and shutter design. After a few years of usage, then the on/off switch with start losen a bit. These will cause autofocus activated without you pressing the shutter yet, and it will shut off without warning.
SOLUTION.
There is no DIY solution for this problem. For temporary, try your luck with pressing the on/off swith a bit harder. But that is for temporary + a bit of luck. Best solution is to send the camera to Nikon Centre.
Oct 24, 2008 | Nikon D80 Digital Camera with 18-135mm...
Broken shutter
could be a loose ribbon cable or a frozen internal shutter issue. with out looking at it it is hard to properly diagnosis the issue. let me know if I can help out any futher.
Apr 08, 2008 | Canon PowerShot A540 Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
106 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
