Question about Pentair Minimax NT Heater
Does not ignite
The igniter comes on, the gas begins to flow but does not light.
  • 677 Answers
Http://www.pentairpool.com/pdfs/minimaxsafetyREL.pdf
Where you aware of this asfety recall ? Maybe it does not apply to your unit, but I would take a look
Posted on Feb 07, 2010
Whirlpool duet dryer doesnt get hot
Is this a GAS Dryer? Or, an ELECTRIC Dryer?
If this is an ELECTRIC dryer, the following link will give you some advice on how to troubleshoot a no heat problem:
http://www.fixya.com/support/r3576548-dryer_runs_but_does_not_heat
If this is a GAS dryer, the most common failure for heat related problems in a gas dryer is a weak or blown igniter on the burner assembly.
The way the ignition system is supposed to work is like this:
1. Select the dryer cycle and press start.
2. The drum begins to spin and the igniter begins to glow.
3. Once the igniter reaches a certain current potential, the gas safety valve opens.
4. Gas is introduced into the manifold and you have ignition.
NOTE: It can take roughly 30 to 90 seconds from the time you start the dryer to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the appliance that prevents free flowing gas from accumulating in your home without ignition. That's why you typically don't hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
You can purchase replacement parts (if required) at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
The first three sites on the list also offer some excellent exploded view diagrams of the appliance.
If you have any questions, please post back with your complete model number and let me know. I hope this helps you.
Feb 27, 2010 | Dryers
Not heating up
If this is a GAS dryer, the most common failure for heat related problems in a gas dryer is a weak or blown igniter on the burner assembly. The way the ignition system is supposed to work is like this:
NOTE: It can take roughly 30 – 90 seconds from the time you start the dryer to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the appliance that prevents free flowing gas from accumulating in your home without ignition. That’s why you typically don’t hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
TWO BASIC IGNITER TYPES:
Carborundum (Cylindrical in shape) – needs to produce 2.5 to 3.0 amps for the gas safety valve to work.
Norton (Rectangular in shape) – needs to produce 3.2 to 3.7 amps for the gas safety valve to work.
NOTE: There is a UNIVERSAL FLAT BAR igniter on the market as well, that can be used as a substitute if the igniter type that came with your range is not available.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the dryer still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad.
You can purchase a replacement at any of the following websites:
repairclinic.com
If your replacement igniter comes with a connector plug that does not match your appliance, you will be instructed to cut the old plug off and splice the wires together using ceramic wire lugs included in the kit. Do not use standard wire lugs as they will melt.
If you have any questions, please post back with your complete model number and let me know. For future reference, always include a brand name and model number when posting questions. This makes it much easier to diagnose the problem. I hope this helps you.
Dec 23, 2009 | Dryers
Dryer is not heating
repairclinic.com
Dec 22, 2009 | Dryers
Will not heat up in any cycle
  1. NOTE: It can take roughly 30 – 90 seconds from the time you start the dryer to the time it takes for the gas to ignite.
repairclinic.com
If you have any questions, please post back with your complete model number (located on a nameplate around the door opening) and let me know. I hope this helps you.
Dec 21, 2009 | Washing Machines
Whirlpool LGR7646DWO runs but no heat
The model dryer you have listed is a GAS dryer. The most common failure for heat related problems in a gas dryer is a weak or blown igniter on the burner assembly. The way the ignition system is supposed to work is like this:
  1. NOTE: It can take roughly 30 – 90 seconds from the time you set your oven temp to the time it takes for the gas to ignite.
NOTE: This is a designed safety feature of the oven to prevent free flowing gas from accumulating in your home without ignition. That’s why you typically don’t hear any gas flowing when you have an igniter problem. You might think you have a gas problem when actually you have an ignition problem.
The igniter typically goes bad in one of two ways, the igniter either stops glowing completely, or becomes weak over time and doesn’t produce enough current to open the gas safety valve (in this case the igniter will still glow but the oven still won’t light). Longer ignition times can be another symptom of an igniter possibly going bad.
For the model number you have listed, the part number for a replacement igniter is 279311. You can purchase a replacement at any of the following websites:
repairclinic.com
The first three sites on the list also offer some excellent exploded view diagrams of the appliance if you use the Search By Model Number feature. The ingiter is listed under the "Burner" category as item 4.
If you have any questions, please let me know. I hope this helps you.
Dec 17, 2009 | Whirlpool LGR7646E Dryer
There is no heat
repairclinic.com
Dec 17, 2009 | Whirlpool Dryers
Gas pilot light
Most modern appliances that use gas as an ignition source do not have a pilot light. The gas and ignition is controlled by a burner assembly with a gas safety valve. In theory, the way the burner ignites is:
1. You push the start button, the drum begins to turn and the igniter on the burner assembly begins to glow.
2. The igniter must reach a predetermined current potential in order for the gas safety valve to open. Once this current potential is reached, the gas safety valve opens.
3. Gas begins to flow into the burner manifold, and you have ignition.
NOTE: It can take 30-90 seconds for the burner to ignite. As an igniter ages, it may take longer.
The reason burner assemblies are designed this way (especially in dryers) is to prevent free flowing gas from filling up the appliance cabinet without ignition. If such a condition existed, the could be a potential explosion hazard.
If you are experiencing problems with ignition, the first thing to check is your igniter. The do wear out with age and are fairly simple to replace.
NOTE: A glowing igniter does not necessarily mean it is good. If it is weak from age, it may never reach the required current level to open the gas safety valve.
If you have questions, or require additional assistance, please post back with your complete model number (located on a nameplate around the door opening on most dryers) so I may be able to provide you with better service. I hope this helps you.
Oct 12, 2009 | Kenmore 63942 Dryer
How do you light pilot light?
Dryer does not have pilot light.  There is an ignitor that glows when the dryer is started and lights the flame when the gas begins to flow.  With the front of the dryer off start it up and look for the glow. when it glows hot enough (or on a newer model it might be a spark) the gas should ignite.  When the flame sensor sees that the gas is ignited it shuts off the ignitor and keeps the gas valve open until the temperature sensor gets high and shuts it off.  When the temp sensor cools down the cycle repeats.
If no glow or spark-->bad ignitor If no gas flow-->bad flame sensor or bad gas valve coil If gas comes on and goes off quickly-->lint filter and/or vent pipe or outlet may be clogged or bad flame sensor.
May 29, 2009 | Whirlpool Dryers
Oven
the igniter is not getting hot enough. It can get hot enough to allow gas to flow but not quite enough to ignite the gas. It is an easy fix. The igniter is usually under the floor of the oven.
Aug 27, 2008 | DCS RGS-305 Professional Gas Kitchen Range
GE Profile Gas Range Igniters working but gas takes a while to start flowing
HI thanks for your question. the igniter is the cause for this problem. the heat from the glow bar is just not hot enough to ignite the gas. i would replace the igniter. thanks
Nov 26, 2007 | GE Profile JGSP48 Gas Kitchen Range
Pentair Minimax NT Heater Logo
114 people viewed this question
Top Pentair Pool & Spa Experts
Pj Kiley
Pj Kiley
Level 1 Expert
Jay Finke
Jay Finke
Bill Jordan
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
