Question about Toshiba Satellite P205D-S7802 Notebook
On my touch pad I can scroll up and down but I'm not able to double click on the touchpad to open a link. I have to us the left click under it to open something up. Can you please help me?
  • jennajenna12 Feb 07, 2010
    I tried that and it didn't work.
    Thank you very much, it worked!!!
    Brigadier General:
  • 4,090 Answers
START CTRL PANEL MOUSE
Now at first few times youi might get a dialogue box asking if you want to uninstall select NO, eventually the mouse control box will display.
Tick the CLICKLOCK BOX on the first screen, SET THE SPEED that suits you. Now when you tap on the PAD it will open the folder. Test it ( icon on mouse screen will respond whjen you tap on pad)
SELECT Apply andEXIT
Thanks for using FIXYA
Posted on Feb 07, 2010
  • dennis bullard Feb 07, 2010
    Then your driver is corrupted.
    Go to start CTRL Panel SYSTEM Device Manager and delete the mouse. Reboot computer and have it rediscovered.
    Insert the driver disk that came with your unit and let it reinstall.
    Nettiser
How to open unlock mouse pad
Click the Windows "Start" button in the bottom-left corner of your desktop.
Scroll up and click "Control Panel."
Choose the "Mouse" icon or type "Mouse" in the field in the upper-right corner.
Click the "Enter" button and then click the "Mouse" link.
Press the "Hardware" tab or the tab to the right of it that specifies the type of touch pad you have.
If you are under the "Hardware" tab, highlight the touch pad in the list of devices and click the "Enable" button.
If you are under the touch pad tab, click the enable button.
Click the "Apply" button and then click the "OK" button
or
Locate the function key on your keyboard (F1 through F12) that has an icon of a touchpad. This is often a rectangle with two smaller rectangles below it, representing the touchpad and its two buttons.
Press and hold the "Fn" key, usually found in the lower left area of your keyboard.
Press the touchpad function key and then release both keys. If this does not enable your touchpad, try holding the "Fn" key down and pressing the touchpad function key twice in a row.
Shortcut Key Method
Press the Windows icon key on your keyboard and hold it down until the Start menu pops up. If your keyboard doesn't have a Windows icon, press "Ctrl-Esc" at the same time.
Use your arrow keys to locate the Control Panel and press "Enter."
Navigate to "Mouse" with your arrow keys and press "Enter" to open the mouse control dialog box.
Then, press "Alt-F" together to access the tabs at the top of this box.
Navigate using the arrow keys to "Device Settings" or "Touchpad" or the similar option on your system and press "Enter."
Press the "Tab" key until the "Enable" option or a check box next to it highlights and then press "Enter." Press "Tab" again until you are highlighting "OK," and press "Enter." Your touchpad will be re-enabled.
hope this helps
Sep 22, 2012 | Computers & Internet
Hi i have acer 5542g laptop currenty i got one problem i cant open any file or folder by double click on touchpad
Hi
Have you done all the windows updates ???
start
programs
windows updates
check for updates
install them all then restart laptop
if this does not correct things
start
right click my computer
go to computer properties
device manager
scroll down to find mouse/touchpad
un install it
restart laptop
windows should then on start up find new hardware
and install the touch-pad correctly
and may ask for another restart
if still no good try here www.acer.com
go to support/downloads
find you make model and operating system as in xp or vista or windows 7
then scroll down and find the touch-pad driver
download it
install it
restart and keep fingers crossed
good luck
Feb 19, 2011 | Computers & Internet
My cursor moves as i type what can i do
You seem to be brushing against the touch pad while you're typing. You need to adjust the sensitivity of that touch pad:
Click on the "Start" icon in the lower left corner of the screen. Select "Control Panel." Next select "Mouse" under "Hardware and Sound." You can also left-click the touchpad while the cursor is anywhere on the desktop. From that screen, choose "Mouse Pointers." Select the "Buttons" tab at the top of the dialog box that opens. This shows the type of touchpad device installed on your laptop. Set the touchpad for right or left-handed use from this dialog box. You can adjust the double click speed of your computer as well. When you finish making any changes, click "Apply." Pick the "Device Settings" tab from the dialog box now. You can see the touchpad for your Vista machine highlighted on this screen. Select "Settings." Read the information provided in the next dialog box. It gives you options for tapping your touchpad, using the buttons, scrolling, pointer motion and sensitivity. Make any changes you want from the various topics. When you make a change, click "Apply." Click "OK" when you finish making all your changes. Do some work on your computer for a while. If the touchpad is still too sensitive, return to the "Mouse" menu and continue to adjust the settings until you get them just the way you want them.
Jan 01, 2011 | Computers & Internet
Have a Satellite P 305D-S9800; scoll bar will not pull down by mouse or touch pad; as soon as I let go it jumps back to the top please help
The "Touchpad is very sensitive; if you look while scrolling, the "scroll-bar" will turn (Blue), click on the ("scroll-bar"), until it turn "Gray." Note: "You ca use the Pointer Device / Touchpad without using the Scroll-bar, basically anywhere on the screen; ("bottom scroll-pad" = left to right"), and ("right -side edge scroll-pad = up & down").
Jan 24, 2010 | Toshiba Computers & Internet
Lenovo G550 touchpad scroll bar does not work with windows 7.
Have you tried installing the drivers for the touchpad?
The link below will take you to the driver download page for your laptop, scroll down to the section for touchpad and install either the windows 7 32-bit or 64-bit drivers.
http://consumersupport.lenovo.com/en/DriversDownloads/drivers_list.aspx?CategoryID=600154
Dec 30, 2009 | Lenovo G550-29583AU Notebook
I cannot enable the touchpad settings.
Hi there...
First of all has the touch pad ever worked?
Lets give this a try, go to the START button and left click, look for the CONTROL PANEL and double click on it.
When the Control Panel opens look for the MOUSE and double click to open page, on the tabs look for ULTRANAV, you should see a check mark box, ensure that there is a check mark under the Enable Touch Pad, hit the APPLY and OK.
Voila, your touch pad should start working.
Aug 29, 2009 | IBM ThinkPad R40 2722 Notebook
Touchpad malfunction
Do you mean when you just tap the pad w/ ur finger? if so this is a setting that can be turned on and off. Have you or anyone been pilfering through the settings?
  `Nbryson
May 30, 2009 | HP Compaq Presario R4000 Notebook
Dell latitude c610 touch pad left button problem
Will your laptop work properly with an external mouse? If so, check your touchpad settings in "Control Panel" by selecting "Mouse". Here you can reassign your Buttons. Try setting your Right Button function to "Double Click". If the "Double Click" function works on your Right Button then chances are you have a problem with your Touchpad Assembly which means it will have to be replaced. Dell refers to it as a "Palmrest" which they will replace if still under warranty.
Sep 20, 2008 | Dell Latitude C610 Notebook
THE 4-way scroll button IN MY ASPIRE 5100 DOESNT WORK
Double click the icon in the toolbar. Click the device settings tab and then hit setting. select buttons in the list on the left side. Hit the plus sign(maximize) and select scroll up button action....scroll down button action...Etc. For each action select what you want it to do and just hit apply and move to the next. Once you have selected the action for scroll up, down , left, and right hit apply again just to be sure and try it. It should work. I just did it on my 5630 but Im assuming it works the same.
Aug 14, 2007 | Acer Aspire 5100 Notebook
Toshiba Satellite P205D-S7802 Notebook Logo
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
