Question about Fujitsu Lifebook C1020 Notebook
Fujitsu LifeBook P7120 has intermittent static in audio playback. Sounds like it's being interrupted, but the processor load is not that high. I replaced the audio drivers. Noise is the same with both internal and external speakers.
  • 159 Answers
SOURCE: I HAVE A PROBLEM W/ MY FUJITSU LIFEBOOK FMV 6866NU
You can download new drivers from here:
http://www.falconfly.de/voodoo2.htm
That's a spectacularly old laptop, fyi. The video card manufacturer went out of business a decade ago.
Posted on Dec 07, 2008
Geekman
  • 32281 Answers
SOURCE: Fujitsu Lifebook C4135 specs (32bit CardBus slot included?)
This is a very old laptop, when new it was installed with Windows 98.
Not sure if it had a PCMCIA slot on the laptop, but it can be easily identified if you look on the laptop. If it has PCMCIA slots, most likely it would be located on the LHS or RHS of the laptop. The PCMCIA could be a single slot or a double slot and it would be 55mm wide ie 2 3/4 inches wide with an eject button for a single slot and two eject buttons for a double slot.
Posted on Jul 06, 2009
  • 59 Answers
SOURCE: touchpad stopped working on my Fujitsu lifebook
You need to re-enable it. Hold Fn and hit the F5 or whatever key is appropriately assigned to the touchpad. This should enable it for you.
Posted on Oct 19, 2009
pontelemon
  • 538 Answers
SOURCE: My Fujitsu Lifebook is stuck in some sort of
Disconnect keyboard.
See if it's going to stop scrolling.
Posted on May 26, 2010
Sunnyrepairs
  • 808 Answers
SOURCE: How do I update the BIOS for my Fujitsu Lifebook
U can chek this link for bios update http://www.pc-ap.fujitsu.com/support/manual_lb.html Or http://driverscollection.com/?H=C2210&By=Fujitsu
Posted on Jul 28, 2010
Lifebook p7120 bios v1.23 cant boot from usb
Go to your BIOS and change the boot order from there
Oct 02, 2013 | Fujitsu LifeBook Computers & Internet
Can I use an 18 volt universal AC Power Adaptor on Fujitsu Lifebook P7120 which is a 16 volt laptop?
With voltage step down power supplies, output power is more important than data plate output V (volts). V times output A (data-plate amps) equals output Watts (or VA) under normal load. If the voltages are close and the output watts (VA) are very close (one or two watts) you are in luck as long as the connector is same size; AND THE POLARITY (+ & -) IS THE SAME for the old and replacement unit!
Jan 17, 2012 | Fujitsu LifeBook P7120 Laptop AC Power...
There is a fast clicking intermittant noise.
Your harddrive could be failing or it could be your processor running. It's difficult to tell. You could run a SMART check on your hard drive to find out if it is failing.
Install this and run it, good luck.
http://download.cnet.com/Active-Hard-Disk-Monitor/3000-2086_4-10879927.html
Mar 02, 2011 | Fujitsu LifeBook N6410 Notebook
Want to download drivers for Fujitsu lifebook P Series P7120 notebook
Hi here for you the link for drivers download Fujitsu P7120 click in to my name to download
dont forget to select the operating system of your laptop
Good luck techbelkin
Nov 02, 2010 | Computers & Internet
No audio playback device installed
It's means there's no sound device installed, this could be audio drivers problem, please reinstall it. You can download the driver from here if you have problem with yours. Fujitsu Lifebook t1010 drivers Please select the corresponding drivers for your operating system type. Good luck. Thanks for using FixYa.
Jun 05, 2010 | Fujitsu Lifebook T1010 Tablet PC
Beep 4
remove the rams from the laptops. clean them with cloth and place them again.
and check display.
or try any other ram.
Nov 04, 2009 | Fujitsu Siemens LIFEBOOK P7120 PC Notebook
How I can down load audio driver for N3010?
Follow this link to the driver downloads page at Fujitsu. Choose Notebook PC > N series >N3010 and all of the drivers will be available to download.
http://support.fujitsupc.com/CS/Portal/support.do?srch=DOWNLOADS
Oct 18, 2009 | Fujitsu Siemens LifeBook N3010 Notebook
Screen flickers from red to blue to green. Must be a loose wire or contact somewhere. Is there a manual for opening the P7120?
flickering means your monitor is faulty. you might need to replace it.
if machine is under warranty i believe the replacement is free.
Jul 01, 2009 | Fujitsu Siemens LifeBook P7120 Notebook
Fujitsu Lifebook C1020 Notebook Logo
81 people viewed this question
Top Fujitsu Computers & Internet Experts
Alun Cox
Computer Links
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
