Question about Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304)
How can I make my router private so no one else can connect to it?
  • 4 Answers
To make your router private u will have to get acces to ur router firs if u cant just reset the router from the back the log to the internet and if u cant conect type this192.168.1.101 the brand name of the router appear then enter the user name and pasword if u cant type ADMIN in the user then press enter then go to settings and chose WEP share key and type your password recomment to use a strong password ok then click save. also create a user name while u in thre ok. that will reset the router after that go to my network conection right click on ur wireless router name and go to propertis then chose the WEP share key and type the password then ok. that will set ur router privated ok. good luck
Posted on Mar 28, 2010
  • 2,260 Answers
Is there any computer connected to the router ?
If not then you will need to connect the computer to the router.
check the IP address of the computer.
open the router set up page of the router.
Here you can change the wireless settings of the router.
Click Here for step by step instructions
Posted on Feb 07, 2010
Belkin Security
Your surfing is only private when you're using SSL (https) connections between your browser and the website[s], no matter what route[s] your internet connection takes.
Feb 16, 2014 | Belkin Basic Wireless Router
Hello I have a belkin router model # F5D7230-4V9000 with serial # 140849R7901012 having IP address of 192.168.2.1 . I am trying to connect a DL wireless camera Model # DSC-920 but it connect and shows...
Step 1 : Connect Router - Computer ( Wired)
Step 2 : Open Router Setup by typing http://192.168.2.1 on the address bar of internet explorer
step 3 :click on firewall disable the firewall
step 4 :click dmz - >type in private ip 192.168.2.25
step 5:click on virtual server type description camera inbound port 0 and type tcp&UDP or Both and private IP is 192.168.2.25 and private Port 65535
( Or )
In order to configure this, you need to know:
- The IP address of the computer or device to have the port forwarded to.
- The port numbers to be used and whether these are TCP or UDP ports
(Note: We recommend you use a computer that has a wired connection to the router.)
Setup steps:
  1. Open a Web Browser on the computer. Type in http://192.168.2.1
  2. In the address bar of the Web Browser type Click Login in the upper right hand corner of the page. The router does not ship with a password, so just click submit.
  1. Click on Virtual Servers under Firewall in the menu on the left
  1. Enter the following information
    • Click Enabled
    • Type a general description of the application i.e.. Remote Desktop
    • Type the port(s) specified by the program manufacture for both of the Inbound port fields
    • Select TCP, UDP, or BOTH for the Type.
    • Private IP address: Enter the IP address of the computer you want grant access too.
    • Type the port(s) specified by the program manufacture for both of the Private port fields.
  1. Click the Apply Changes button
Jan 30, 2011 | Belkin (F5D7231-4) Wireless Router
Router was working on a wireless computer. The next day it wouldnt connect. Tried putting in password still nothing.
I recommend either resetting the router, (little pin size button on back) or what most people do is unplug for 10 seconds and plug it back in. They tend to build up a static charge.
Nov 04, 2009 | NetGear WGT624 Wireless Router
Local access only.
You need to configure the router for internet access. If you are on Cable ISP, you need to do MAC Cloning. If you are on DSL ISP, you need to configure the router for PPPoE. Normally, the router's setup CD can guide on how to do it.
Oct 22, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Comuter gets a 168 private ip
enable DHCP on the router and you'll get the right ip adress
Aug 05, 2009 | D-Link RangeBooster G WBR-2310 Wireless...
Belkin G plus mimo
Hi never ever disable nat on your router as that is the one which gives ip address to computer , x-box etc. You can make your x-box live work by just opening some ports
1. open rsp by typing in 192.168.2.1
2. On the left hand side under firewall you"ll find virtual servers
3. Click on that --- You"ll find some fields then check on enable for 1,2,3(ie three rows)
4.Description - x-box for all three
5.Inbound Port: 88-88 ,connection type : udp ,private port : 88-88 for the first row
6. Inbound port : 3074-3074 , connection type : udp , private port : 3074-3074 for second row
7. Inbound Port : 3074-3074 ,connection type : tcp , private port : 3074-3074
8. As FOR the private ip address it is that of your x-box which you can find on the dash board of your x-box . Same for all three rows .
9. Best of luck And do rate me
Jan 31, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Hey desperate help
it only hands out private ip addresses. they typically start with 192.168.x.x.
in the setup of router make sure and change all default values for Administration (router username/password) and also change the default IP Address of router to whatever you like, e.g router ip can be 192.168.1 - 249.1
Jun 27, 2008 | Zhone Paradyne 6388-A1-200 Router
Paradyne 6218-12-200 won't connect all computers
A public IP address is usually assigned to the WAN port (outside/public side), which is how your router is conected to your Internet provider service.
A private IP is always assigned to the private network side (LAN = Inside). Unless you are hard coding your IP addressing on each of your devices, you will need to have DHCP enabled in your router with enough user IPs for your devices (more than 1).
Apr 11, 2008 | Paradyne (6218-A1-200) Wireless Router...
Xbox
check your router's settings on the set-up page and configure your wireless settings to be able to receive private chats or get invited or invite friends to an xbox live game. try to check your firewall because sometimes its blocking your connection
Jan 17, 2008 | Linksys Wireless-N WRT150N Router
How do I get rid of the router using an automatic private address which keeps disconnecting?
the router will give you a private address , that is the functionality of the router, the problem is not with your connection, try to upgrade the latest firmware inthe router and reconfig the router in a pppoe mode that will fix your problem..
Dec 20, 2007 | Linksys WRT54GX2 Wireless-G Broadband...
Gateway Belkin 54g Wireless DSL/Cable Router (DHF5D72304) Logo
2,402 people viewed this question
Top Gateway Computers & Internet Experts
Prashant M
Prashant M
Matthew Spark
Matthew Spark
Are you a Gateway Computer and Internet Expert? Answer questions, earn points and help others
