Question about Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range
Bottom element in oven went bright red and smoked on one end. Now it dosent work. How do I replace the element
  • 12,061 Answers
Most element simply "Plug In" as such it is NOT too much of a mission to install. Ensure you get the EXACT element.
Posted on Feb 07, 2010
We were making dinner and then there was a bright flash and the oven wasnt heating. I checked the element and it was fried (bottom element) I bought the new element and installed it but it doesnt work. ...
check the wires,, follow them from the burner element back to the switch,. usually one of them burns off , you can check the wires with a simple meter ,, check for continuity
Sep 28, 2011 | Kitchen Ranges
Last night, we were using our Frigidaire oven to heat some salmon. My wife openned the oven door and there was a bright flash with sparks and a crackling noise, and a 1/2 inch portion of the element caught...
Kill the power to the stove. L2 is always hot to the element. If it welded itself to the frame whats left of the element stays hot. Easy fix but power needs to be OFF
Apr 17, 2010 | Ovens
Turned on oven, waiting for it to heat up and saw a bright flash of light and now nothing works control panel doesn't even light up
the bake element shorted out turn of the power to the unit and replace the bake element or bottom cooking element that will fix it
Apr 03, 2010 | Whirlpool RBS275PD Electric Single Oven
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
The bottom element in my Kenmore oven just got red
Yes. Unplug the range, remove the screws, holding the element, remove element, disconnect wires on the ends of the element. Installation is the same in reverse. Complete model number is needed for the part# of the element
Mar 04, 2010 | Kenmore 96422 / 96424 / 96429 Electric...
There is heat, but not nearrrrrly what it should be. The other day we noticed the metal coil thingy on the bottom ("bake element"?) do a weird thing, it turned very bright and a small bright spark spread...
That is what I would do. Be sure to remove the power plug before doing any kind of work on the elements or wiring. If the element is a 'plug-in' device, the repair is simple. But if the element connections are buried in the oven back, it requires more careful work. Hope this helps!
Feb 14, 2010 | General Electric Stove/Oven/Range Chrome...
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
Hidden bottom element not heating. Went to remove it and it had burnt through. New element doesn't get hot.
Assuming that you installed the replacement correctly, can you check the element with a resistance meter?
It's possible the replacement element you bought was faulty. But first, we want to ensure that the oven is otherwise functioning correctly. You'll need that resistance meter to check continuity along the red wire (i'm presuming) that connects your top and bottom element to your selector knob. Also make sure there are no internal fuses in your oven that may have blown.
Please remember to turn the oven off at the breaker board before working inside it.
Hope this helps, let me know.
John
May 09, 2009 | Kitchen Ranges
Oven won't work
It sounds like your heat ignitor went out. To find out open the door and look for a 1/4" rod that starts in back and wraps to front then to back again that is it. shout door turn on oven to se if that get bright red I would start at 475 degrees. If it does not get bright red it went out and needs to be replaced. If I get model # I can get part # and manual to show you how to replace it. Or you can cal out an appliance repair man.
Good luck.
Dec 16, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
The oven broiler work but the baking part doesent.
hi thanks for the question I would replace the bottom igniter it has failed thanks the appliance doc
Sep 30, 2008 | GE JGRP17 Gas Single Oven
Open Questions:
See all Thermador RDDS30 Dual Fuel (Electric and Gas) Questions
Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
131 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
