Question about Bosch PS20 2 Factory Reconditioned 10.8V Litheon Pocket Driver
Hello: I am looking for PS20 screw gun' I need the work light bulb. Thanks Joseph
  • 154 Answers
Unfortunatly the bulb is attached to a circuit board and everything must be replaced. Bosch dosen't make a replacement bulb for that unit.
Posted on Feb 08, 2010
Need the light bulb for the 6005 Elna. I've had this machine for many years and its been a real work horse, but now the light bulb has gone out in it.
Looking here, it looks like a capless bulb like in cars.
Lamp Socket Unit Elna 395723 43
In fact it is, a 12 volt 5 watt capless auto bulb
Changing the Light Bulb The sewing light is located behind the face plate. Unplug
the machine. Remove screw cap and screw. Pull away
face plate.
Pull out light socket. Pull out light bulb. Push in light bulb
with pins aligned to holes in light socket. Push in light
socket.
Replace face plate, screw and screw cap.
NOTE: Only use same type light bulb rated 12 Volts, 5
watts
6005 Elna light bulb Google Search
similar
ELNA 6200 Instruction Manual Changing The Light Bulb Feed Dog
Feb 05, 2018 | Sewing Machines
We're looking for a replacement light. Where can we find one?
Hello, you can get a light bulb by ordering from: The bulb's part number is 7333. You can order a replacement bulb here for about $2.50 :http://www.e-sonic.com/aboutus/cat/S/soldering%206.pdf.
GB..stewbison
Aug 04, 2011 | Weller 8200 Soldering Gun
I just changed the bulb for my headlight on a 1995 Toyota Avalon fairly easily. Bought the bulb at Pepboys for 10.99. Now I noticed the the running light on the opposite side (passenger) is out. Any...
To change the running light on the passenger side is quite simple and should take no more than 10 minutes.
1) Open the hood
2) There will be a Phillips head screw on top of the headlight close to the fender, its the only screw holding the marker light in.
3) After the screw is out simply pull the marker light straight forward (the clip in there is a right pain half the time but it'll come out)
4) Change the bulb
5) Reverse the steps to re-install the marker light
May 30, 2011 | 1995 Toyota Avalon
How to change out the light bulb
Hi
Please check this video for bulb replacement, it's an example though:
Hope this helps...please post back with manufacturers name and model no. for further assistance.
Daniel
Mar 20, 2011 | Kitchen Ranges
Trouble with the 2 work lights
You need to open the gun case and check the connections to the bulb sockets inside. I have several of these guns and the only problem has been the occasional need to re-tighten the tip screws to break through the oxidized copper adjacent the screws. Good luck!
Jul 07, 2010 | Weller D550PK Professional Soldering Gun...
Weller soldering gun replacement light bulbs
that takes a common 6volt screw in type bulb you can buy at most radio shacks or parts stores
Jan 22, 2010 | Weller 8200 Soldering Gun
Lights don't go no weller d550
I cannot see by the picture if you have one or two light bulb model, but if you have the 2 bulb, then you must know that these bulbs are in series so they both must be good and they have to be 1,5 volt bulbs each or you will get a very dull light. If it is a single bulb, then you need to check the screw-in socket and check the bulb with an ohm meter or continuity tester. iF ALL TESTS OK, THEN THE PROBLEM IS INTERNAL AND YOU WILL HAVE TO OPEN THE GUN OR JUST FORGET IT. GOODLUCK, MACGIVOR.
Jan 09, 2010 | Weller 8200 Soldering Gun
Ordered new gear train for my PS20. Does it have to "bolt on" to the motor or is it held in place by the tabs?
The motor will have a plastic plate screwed to it and the gear train attaches to this plate with tabs. You just twist the gear train and motor apart and they will separate.
Dec 26, 2009 | Bosch PS20 2 Factory Reconditioned 10.8V...
Where can I find replacement bulbs for an old D-550 with screw in type lights? I don't know the numbers for them.
The bulb you seek is a type222 2.33v 270mA bulb available from Radio Shack p/n272-1124.
http://www.radioshack.com/product/index.jsp?productId=2102806
Apr 05, 2009 | RTO Weller D550 Soldering Gun
Rear blinker light change 2001 ram1500
Hello
Welcome to FY
open the tale gate look at the side where the light is there is 2 screw that hold the light to the box
RD
Jan 10, 2009 | 2001 Dodge Ram 1500 Truck 2WD
Bosch PS20 2 Factory Reconditioned 10.8V Litheon Pocket Driver Logo
145 people viewed this question
Top Bosch Drills Experts
Matt Olenzek
Matt Olenzek
woodzowl307
Are you a Bosch Drill Expert? Answer questions, earn points and help others
