Question about Electrolux Refrigerators
Electrolux french door wave touch error on screen ice er
  • 363 Answers
SOURCE: Error code Er IF on my french door LG
IF(icemaker fan) This fan is located behind the rear panel of the freezer compartment.
Posted on Aug 05, 2009
  • 289 Answers
SOURCE: LG er 15
is there ice or frost forming on the back wall.
Posted on Jan 16, 2010
blueextc3221
  • 15935 Answers
SOURCE: Help....kenmore trio refrigerator, error message "er co"
The Er Co error code signifies a communication error between the display control board on the freezer door and the main power board on the outer back panel of the refrigerator.
Check the wiring and connections between the low voltage interface and the main high voltage board.
If you are able to unplug the refrigerator and remove the cover over the control board on the back of the refrigerator,
you can check the wiring connection on the main control board.
If this wiring connection is okay, check the wire harness connection under the hinge cover on the top of the left hand refrigerator door.
If these connections are okay, then you will need access the wire harness connection in the dispenser.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 25, 2010
SOURCE: I have an electrolux wave touch french door
pull the ice tray out, on the bottom of the left side there's a metal rod that needs to be repositioned into the tooth gear.
Posted on Oct 22, 2010
MNTECH
  • 1543 Answers
SOURCE: Not working, ER and CO in spots for temp. French
ER CO is an indication of a communication error between the display board and the main board. Has this unit had a board replaced recently? If so, one of the multi pin plugs may have not gotten connected firmly, or an incorrect board may have been installed. The problem has nothing to do with the dust.
Posted on Feb 28, 2011
Display panel on Electrolux wave touch French door refrigerator will not adjust temperature. Ice or water won't' dispense either.
Hello friend, thank you for your post!
Based off the information you are describing it sounds like your control panel is locked. Can you check to see if the control lock is lit up? If so, please hold down the control lock button for 3 seconds and it should allow you to operate the front panel. If not you could be experiencing a problem within your control panel and may need to have a professional come out to diagnose it. I hope this helps. -Matt
Sep 10, 2014 | Electrolux EI23BC56IS (226 cu ft) Bottom...
Error code on my electrolux refirgerator
Good Morning Friend,
I understand you are receiving a T3 error code when you turn the ice maker on your Electrolux refrigerator. I suggest resetting your appliance, by either unplugging your appliance or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and make sure your ice maker is on. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Jul 02, 2014 | Electrolux 25.9 Cu. Ft. Side-by-Side...
I had the typical issue with the ice maker on my electrolux french door fridge. The kit to fix the issue was installed but after the tech left the fridge reported a "ice t3" error. A new...
It would need to be checked at the main board to see if the sensor is ok. then the wires need to be checked one by one from the sensor to the main board to see if there is a problem with a wire inside the cabinet (non repairable).
Feb 11, 2018 | Electrolux EI28BS56IS (278 cu ft) Bottom...
My wave touch does not make ice filter and water connection are ok .frigde is 6 months old
Mine does this quite often. I turn the ice maker off from the options control panel on the front and leave it off several hours if not over night. When I turn it back on using the same control panel and it works. Sometimes I will see a puddle of water on bottom of the water dispenser or inside the fridge after turning off the unit.
Mar 04, 2011 | Electrolux EI23BC56IS (226 cu ft) Bottom...
We get no water or ice from control panel. On panel it says Er iF. What does that mean and how can we fix it. We have tried resetting the power and it goes back for a second then returns to Er iF.
Er IF - Ice-maker Fan Error - This can be caused by frost accumulation on or around the ice maker fan. Unplug the unit for 3-4hoursto allow this to melt off. If error code persists, call customer care to check & replace ice maker fan motor.Thanks.
Jan 29, 2011 | LG LFX21960 Stainless Steel Bottom Freezer...
My LFX25960st LG stainless refrigerator ice maker isn't working, it'll make a few ice cubes every couple of days and now on the touchpad it says ER IF and i can't touch anything, how can i fix my problem?
Remove the fresh water hose coming into your refrigerator and check the water flow with a small bucket. This actually sounds like a replace water filter error. Some IF error codes break down to Inline Filter.
Jul 31, 2010 | LG LFX25960ST Stainless Steel French Door...
Error code er 55? I am not getting water into ice
There are several issues with this ref.
Ref. Lamp cover melting.
Department of energy rework.
Contact LG for service repairs are free.
Jan 04, 2010 | LG LFX25960ST Stainless Steel French Door...
Refrigerators Logo
55 people viewed this question
Top Electrolux Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you an Electrolux Refrigerator Expert? Answer questions, earn points and help others
