Question about HP Compaq FS7600 17" CRT Monitor
Everything on the screen is blurry... not unreadable, but almost like there is a shadow behind everything.
  • 12 Answers
[u][b]LCD Monitor Shadow Effect[/b][/u]
This problem is best described as the LCD monitor "Shadow Effect".
The solution to this very simple. No software or hard ware changes required.
The cables that are connected to the LCD monitors are causing the problem. Its also called as electromagnetic noise or electrical noise.
[u][b]Solution: [/b][/u]Keep the two cables - (power cable and moitor display cable), that are connected to the LCD monitor as far away as possible with each other and also away from other electrical cables.
Thats it. Your shadow effect is fixed.
Thank you.
Posted on Feb 07, 2010
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 151 Answers
Separate your cables behind your computer. Move them so they aren't touching, problem solved. Easy, but true.
Posted on Apr 29, 2014
I have a lg flat screen monitor, the words are blurred
Is it just the fonts that are blurry, or everything? If fonts only, then this almost certainly suggests that running the ClearType tuner again would solve the problem. But this applies to all displays, so if one is good and the other is not, then this isn't it.
If everything is a little blurry, then this suggests one of two problems -- the first, you report trying, which is that the display adapter is set to a different resolution than the native resolution of the LCD monitor itself. Your display adapter should probably be able to drive 2 monitors (the built-in laptop monitor and the external monitor) at once. You should be able to set their resolutions separately.
Assuming Windows XP: Start > Control Panel > Display > Settings > at which point, you should see two monitors listed in a dropdown. Set them to their native resolutions there (using the slider bar, usually all the way to the right), and save.
If you do have the display resolutions set to their native resolutions for both monitors, then it's possible that your external monitor is messed up. A quick test would be to run the on-screen settings, usually from a button on the monitor itself. If what is displayed there is sharp and what is displayed from Windows is not, then this points to a problem with the display driver. If everything, even the on-screen display is blurry, then perhaps the monitor settings are messed up -- usually there's an option to restore to factory settings -- try that.
Apr 02, 2012 | LG 22" FLATRON LCD Monitor
All of a sudden I am getting a red shadow to everything on the picture. There is a red swirl on the bottom of the screen, Any text is doubled in red. Everything has a red highlight and seems a little...
a CONVERGENCE problem.
If you are able I have start to finish and step by step instructions for this repair in this set.
Total parts cost if you can do it is under 20 dollars.
Let me know if you want the instructions and I will post them here for you to copy/paste.
SD TECH
May 21, 2010 | Panasonic PT-51HX41 51" Rear Projection...
'Shadows' behind all texts and images on the screen
Thank you.
Oct 13, 2009 | Acer AL2016W 20" LCD Monitor
Whenever i print a test page everything has a shadow behind it, making it look blurry.
Dear Sir,
If your using new catridge please goto Printer service option and clean the head once. Then youwill get clean print.
Thanks
Sep 19, 2009 | HP PSC 1210 All-In-One InkJet Printer
The images on my computer are blurred
if you use the default dell settings you may experience the problem with blurry images in Internet Explorer. This effect is due to the automatic scaling in IE6 and above. IE tries to resize the images so that everything looks the same as when everything is at smaller dpi, but does a terrible job at it, resulting in blurry and unreadable images. Change the following registry setting from 1 to 0 in order to disable this "feature":
HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\Main\UseHR
[1] Adjusting Scale to Higher DPI Screens (MSDN)
good luck with this. please do this, and get back if u run into a problem. also, if this fixes the problem please rate my answer. thanks so much, Joe
Feb 02, 2009 | Dell Inspiron 1501 Notebook
BLURRY SCREEN
If all 3 colors are mis-aligned, you may have solder connections that blew a fuse. There are three fuses next to the flyback transformer, one usually blows causing this issue. Resolder the flyback solder connections and replace the fuse to fix.
Dec 06, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Mitsubishi WS-55511
Good Day;
Sounds like you have bad Convergence Output IC > 267P155010 > STK393-110, replace and it will correct the problem TV uses only ONE, make sure all resistors look good in the circuit around IC.
Good Luck, big IRISH.
Sep 19, 2008 | Mitsubishi WS-55511 55" Rear Projection...
55 inch Philips
I have 50" philips magnavox big screen. I recently started to have a problem with the edges of my tv. They became blurry. the center of the tv is clear and the edges are blurry. what should I do to fix this problem.
Sep 06, 2008 | Philips 9P5034C 50" Rear Projection...
Everything on the screen has a blue shadow
need to change both convergence ICs STK392-560. you can get replacements at the following link with free instalation instructions with pictures.
http://servicemanuals.vstore.ca/
Jun 30, 2008 | Sony KP-46WT500 46" Rear Projection...
Red shadows in picture
Possible "blooming"==red CRT, adjust screen control==qualified tech only.
Oct 09, 2007 | RCA D52W19 52" Rear Projection Television
HP Compaq FS7600 17" CRT Monitor Logo
241 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
