Question about Mitsubishi WS-65511 65" Rear Projection Television
Power outage tv never came back on
The power blinked and the tv never came back on.the green led blinks but thats it .I've tried the reset,unplugging it,and i removed the rear cover and checked the fuse.I just get a fast blinking green led on the frt panel
Unplug connector zn under front speaker panel if it comes on with remote replace this part. If fails to come check DM caopacitors generally also cause this problem
Posted on Mar 04, 2010
Green light on front of TV keeps blinking after power outage. I have tried powering back off and on and resetting the tv. Nothing works
Thats caused by weak DM capacitors when power is lost even for a minute the caps drain and then cannot charge again when power is restored so the led will blink non stop. The Repair kit called the WS48511 - WS65511 DM repair kit should solve the issue. The kit contains the caps and the cd with repair instructions. The kits available from www.tvrepairworld.com
Aug 02, 2011 | Mitsubishi WS-55511 55" Rear Projection...
Mitsubishi DLP 60" - power
Unplug the television, let it sit for an hour an try to plug it back in. That should resolve the problem. if it still flashes green after you do this, use the "reset" button again. Let me know if that works.
Nov 23, 2010 | Televison & Video
Had power outage and after hitting reset button green light blink
Hard to say without looking and sniffing!
But if you suspect that it is and it is likely, you may be able to get it repaired on your insurance policy. It should be covered under FUSION
Dont mention the lightning but check your policy. Then get the repair guy to write fusion problem on the receipt and submit for claim.
Sep 07, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Green light on front rapidly blinks after power outage. No picture, or can't turn on
This unit, when first plugged in or after power interuption takes 70 to 90 seconds for the digital module to boot up. During the time the LED blinks green and the set will not respond to anything. After the appropriate amount of time the blinking should stop and the set should operate normally. If the blinking never stops then you have to have the Digital Module repaired.
Apr 25, 2009 | Mitsubishi WS-55511 55" Rear Projection...
The green light blinkig and does not stop, no picture
Did you try unpluge from the wall, and repluging back after 10 min.
Also run the self diagnosis by pushing the menu and device buttons on the front and let me know the code?
Thanks
K
Apr 23, 2009 | Mitsubishi WS-65909 65" Rear Projection...
Mitsubishi WD-52525 52 in DLP.
You most likely need the V26 DM repair kit at the following link, that usually repairs the blinking led problem.
http://servicemanuals.vstore.ca/
Nov 24, 2008 | Mitsubishi WD-52525 52" Rear Projection...
MitsubishiWS65511
You have the V21 chassis when the led blinks constantly you need the V21/V19 DM repair kit which has the parts and step by step instructions with pictures on how to do the repair. And its less than 40.00 for the entire kit with free shipping. Here is the link its listed under the repair kit category.
Aug 14, 2008 | Mitsubishi WS-55511 55" Rear Projection...
Tv dont come on
Sounds like the typical power surge created by the outage has caused a power supply problem inside your TV. IF that is it, there not much you can do yourself.
Nov 07, 2007 | RCA D34W135D 34 in. TV/DVD Combo
Open Questions:
See all Mitsubishi WS-65511 65" Rear Projection Television Questions
Mitsubishi WS-65511 65" Rear Projection Television Logo
130 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
