Question about Epson Stylus NX400 InkJet Printer
My NX400 doesn't print. I changed original 69 type cartidges with bought on ebay self-resetting 88 type.Printer did resetting but doesn't want to print, actually prints but without ink, copies without ink. What sholud I do? yeah, I used to have canons, this is my first epson
  • 677 Answers
Do not use Resetter.......
ALL…. Epson & Brother Requires Genuine Epson Cartridges. !!!!!!!!
That sounds like your problem.
In Purchasing Epson's CX 5400, CX4600, & CX7400 and more, I found out that Epson does not like Generic Printer Cartridges. I also Purchased a Brother. That also does not like Generic Print Cartridges. Color that should be Yellow, will turn out Green, Blue Brown, etc.
These printers have a CHIP that will detect if it is Generic or Genuine. When they see it’s Generic Cartridges, it will print lines thru the words, stripes across the picture and also do a mix match with the colors. It also will not let you print anything, if only one of the cartridges is empty.
I wanted to print only Black, and would not let me, because I did not have any ink in one of my cyan cartridges. Go figure.
That's what these Companies do., so they can keep selling the ink cartridges. Some Printers, are able to use Generic, and some are refillable. Some you can refill them up yourself and I heard, quite MESSY.
So I learned, thru trial and error, that you must use the ORIGINAL Genuine Cartridges for these PRINTERS. Some people say some models work fine compatible, but not mine.......
I had to replace the printer, but Epson, Lexmark & Brothers are always on sale. My Brother & Epson cost me $50.00 with Rebate. .
This is the only advice I can give you. If you find this helpful, pls rate me.
Thanks and Good Luck :0)
Posted on Feb 09, 2010
I have changed the black cartrage but get Error 88/69
1) Remove all ink cartridges, unplug, plug back in,
put all ink cartridges back in--should now work
2) if not, download drivers from epson.con, and install &
then do 1 above again
Jan 23, 2015 | Epson Stylus NX400 InkJet Printer
BOUGHT NEW CARTRIGE FOR MY NX 415 AND THEY AREN;T REGOGNIZED!
If the cartridge is not the same code as the previous used by the printer, then it will not be compatible. Your printer has been replaced by Epson Stylus NX415 All-in-One
  • One 69 Black Ink cartridge (T069120)
  • One 69 Cyan Ink cartridge (T069220)
  • One 69 Magenta Ink cartridge (T069320)
  • One 69 Yellow Ink cartridge (T069420)
  • Therefore, ensure that the catridge follows the above code (69).
    Best regards.
    Jun 10, 2011 | Epson Stylus NX400 InkJet Printer
    I just change my ink printer and the printer
    to reset your printer, turn off your printer, remove cables on it, press and hold the power button for 5 seconds. Reinsert cables then turn on your printer. Hope it works...
    Jun 02, 2010 | Epson Stylus NX400 InkJet Printer
    Error message after replacing black ink cartridge
    This happened to me twice, You can possibly have no ink in your cyan,magenta and yellow , you would then have to replace them to work the set. I had to do that and it worked =]
    Jul 18, 2009 | Epson Stylus NX400 InkJet Printer
    Gives me an error88/69
    This error means you are out of ink. The error will show a colored box, that's the ink you are out of. The 88/69 is the type of ink you can replace it with.
    Jun 16, 2009 | Epson Stylus NX400 InkJet Printer
    My Epson NX 400 is giving me this error message:Error B88/69/68 C
    Try to run the ink pad reset utility software.
    Please log on to epson.com. The software runs on win xp and win vista.
    Mar 31, 2009 | Epson Stylus NX400 InkJet Printer
    UNABLE TO USE #88 INK FOR MY EPSON STYLUS PRINTER.
    I don't know where you got your #88 cartridges from or who told you that they were compatible with your printer, but they were wrong.
    The CX7450 will only work with the #69 type cartridges.
    The cartridges themselves may look similar but the chip programming will be different for each.
    Hope that helps.
    Feb 21, 2009 | Epson Office Equipment & Supplies
    Just installed Epson NX400 printer. Keep getting M88/69 "Cannot recognize ink cartridges" error. Tried re-inserting cartidges twice already and still same error. What next?
    I found a solution to the same prolem that you guys have. I took the cartridges out and shook them horizontally, instead of vertically, with the large surface up for 3-4 seconds. Re-inserted them back in. Then I started seeing on the LCD "Recharging Cartridge". When it returned to regular copy screen, I turned the printer off and turned it back on. No more error message. It's been working for almost a day now. Try it to see if that works for you. Good Luck.
    FYI. I just bought NX400 last Friday. The error message came on this morning.
    Jan 01, 2009 | Epson Stylus NX400 InkJet Printer
    I am trying to refill my ink cartridge and i dont know how. HELP!!!
    When your ink starts getting low, you will see a red light flashing on the printer. There is a tear drop shape next to the indicator light on the top of the printer. You can keep printing until the light stays red. Once the light stays red, they will need to be changed. When you need more ink, Epson will have a window pop up on your computer wanting you to purchase ink from them. You do not need to do this. We bought our ink cartridges at Best Buy. This printer uses DuraBrite Ultra Ink. There are 2 types; 69 or 88. They recommend 69 for heavy use and 88 for moderate use. The 88 has about half the ink the 69 does. We buy the 69 because it lasts much longer. We use this printer about 3 times a week on average and we haven’t had to change the ink for about 6 months. The 69 black ink at Best Buy is less than $20.00 and the color ink is about $14 for each of the 3 colors. The color 88 comes with all 3 in a pack and it’s about $30.00.
    You should not remove any old cartridges until you are ready to replace them because if there isn’t any in there it can dry out the nozzles. You open the scanner and press the stop button and the printer head moves to the correct position. Open the cover and squeeze the tabs that are there and remove the old ones. Then as mentioned in the set up, insert each one in the correct color and press until they click. This printer was actually the easiest that I have ever had when it came to changing the ink. Another thing that you should know is that you cannot refill the cartridges. They have to be new.
    Dec 30, 2008 | Epson Stylus Multifunction Inkjet Printer/...
    Epson Stylus NX400 InkJet Printer Logo
    434 people viewed this question
    Top Epson Office Equipment & Supplies Experts
    mukhtar21 shaikh
    mukhtar21 shaikh
    Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
