Question about Car Audio & Video
Kicker rs65.2 What is the proper way of installing the kicker rs65.2... how do you hook up the cross-over? which wires go where?
  • RJAT0064 Feb 21, 2008
    KICKER RS65.2
  • RJAT0064 Feb 22, 2008
    *note* i am also hooking these up the an amplifier so what would be the best way to do that with the crossover.
  • 25 Answers
A standard cross-over is pretty straight forward.
You have your L (+) L(-) and your R (+) and R (-) you connect your (+)'s both to the correct channel. but as far as the (-)'s go switch the channels. so the order should be L (+) R(-) ;;; R(+) L(-) .. This is a cross-over connection. Hope this helps
Posted on Feb 24, 2008
I hooked up my kicker ix1000.1 backwards now what?
if you have connected the power supply up backwards (crossed over plus to minus ) then im afraid you've damaged it internally , but if you have only connected the speakers backwards , that's not too bad . unpower it and ck your wiring to the speakers make sure all the speakers red or + goes to the positive or + on the amp and the negative goes to the other terminal
Apr 14, 2016 | Kicker Car Audio & Video
How do I wire up a kicker ps60 powered substation?
Kicker Product Manuals KICKER
The above link should bring you to the Kicker manual page. On the menu boxes, choose ' sub boxes' on the left and ps 80-60 substations. Review the manual for hook up directions.
Jun 08, 2014 | Car Audio & Video
I have a kicker impulse ix702 that keeps blowing its fuse when I turn it on.
Take a volt meter, put it on continuity, cross it between the battery and ground term. on the amp and make sure you get no buzz, now cross it with the remote term. and make sure no buzz. Make sure the only thing hooked up is the battery and ground then take a wire and cross it between the battery input and the rem. to turn it on and see if it blows. Make sure all other cables are removed.
Sep 04, 2011 | Kicker Car Audio & Video
How to hook up 2 kicker 10" speakers & kicker amp to a 2002taurus
Good day ma'am, hi, hooking up an extra amp. on your radio is done by audio professionals, but if you can remove the radio out from your ford, you can install that extra amp. Just follow the diagram below.63bff30.gif You need to find line out of your radio to line in of your kicker amp. connect them using audio shielded cables. connect your speakers to the amp. I guess you this already.
Nov 23, 2009 | Kicker KX600.1 Car Audio Amplifier
Subwoofer/speakers are hooked up to my amp but making bad noise
it sounds like you have some wires crossed or a bad ground
Hope this helps
Jan 25, 2009 | Kicker CVR12 Car Subwoofer
Am trying to install some L5 kicker subs..
I found this wiring guide to wiring them to the sub enclosure.
Click HERE
Jan 04, 2009 | Kicker CVR12 Car Subwoofer
How to wire a kicker 15 cvr
175W x 2 @ 2 ohms
350W x 1 @ 4 ohm
Your amplifier is not stable @ 2 ohm bridged. So you will have to wire them independantly on each channel.
+/- on sub to +/- on L channel
+/- on sub to +/- on R channel
Wiring the subwoofers in paallel will result in a 2 ohm load, which your amplifier is not rated to do. Doing so will cause heat buildup, and damage to the amplifier.
Dec 23, 2008 | Kicker CVR12 Car Subwoofer
Wiring diagram 354xi kicker amplifier
do you need the internal schematics, or how to hook it up? let me know.
Oct 28, 2008 | Kicker SX1250.1 Car Audio Amplifier
Hook up
how do you wire up a kicker cvr 12
Jun 14, 2008 | Kicker CVR12 Car Subwoofer
Car Audio & Video Logo
197 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
