Question about Homedics Health & Beauty
Sc-503 does not turn off automatically, it stays on
I cant pair my nokia bh503 bluetooth headset with acer emachine netbook
First of all, you need to charge the BH-503 before connecting it to your gadget. On the BH-503 after it is fully charged, go to your gadget and turn on its Bluetooth. Mind you some gadget do not have embedded Bluetooth in them;all you do is to but an external Bluetooth and insert it in the USB port. That will make your gadget discover your BH-503. Pair the 2 together, I mean your BH-503 and your gadget and your up and running!
Jun 30, 2012 | Nokia BH-503 Bluetooth Headset
How I can get a Nokia BH-503 driver cd?
How to connect bluetooth headset Nokia BH-503 with Windows 7
I try to use bluetooth headset with my laptop(Dell Latitude E6500) but I can't find device Nokia BH-503 in my bluetooth searching windows.
Many people found this problem. How to fix it? I think this problem is human error or device manual not cover,how to use device with computer and laptop.
if you want to find your bluetooth devices when you search bluetooth devices from your computer.
- Turn off bluetooth headset.
- Start add bluetooth devices function from your computer for search bluetooth devices.
- Hold call button on Nokia BH-503 untill the light blue and red blink (not only light bule blink).
- You will see Nokia Bluetooth BH-503 in your searching window.
- select Nokia BH-503 device and click "Next" for connect the device
- wait for windows find and install driver.If can't found driver let to check it in this web -->>>http://blog.komeil.com/2009/05/installing-bluetooth-headset-in-windows.html
Nov 15, 2011 | Nokia BH-503 Bluetooth Headset
BH 503 bluetooth headset is detected on my phone but it doesn't get paired with the 0000 pairing code. Is this a comparability issue. My phone model is Sony Ericsson Satio U1i with Symbian OS.
vsidharth I had the same problem with my satio.. i fixed it,
what to do is pair your bh-503 then click on auto connect.. now click on bh-503 a menu pops up look for set unauthorised.. turn it on
now turn off your ear phones and back on, your satio will say connect, and will now give you the option to enter your pair code 0000.. once you done that, your ready to go.. hope this helps
Jul 14, 2011 | Nokia BH-503 Bluetooth Headset
My BH-503 wont turn on again. The reset option (hold multi key + volume up) doesn't help at all, in fact. Nothing really happened! The only thing is does right now is: that the indicator blinks...
i thing that for you use the Different charger try to use this original charger that was came with it and if you have any another problem you can chat with me ad try to find all Solution my Email xxhemaxx@live.com
May 19, 2011 | Nokia BH-503 Bluetooth Headset
I have made connection between nokia BH-503 and my laptop operating windows 7. But after that when i am trying to connect with my nokia x3 mobile and BH-503 the mobile do not able to find the head set.
Try manual connecting. If you have paired your x3 and BH-503 before, you should have your paired devices. So after you connect manually, the headphones should connect to x3 next time automaticly. :)
Nov 29, 2010 | Nokia BH-503 Bluetooth Headset
Ricoh Aficio AP400N Laser Printer Sc 545 off on error
SC 545
A Fusing lamp stays on
The fusing lamp stays on more than
12 seconds after the main motor has
been turned off.
• Fusing thermistor defective
• Power supply board defective
• Defective connection of the fusing
This will not reset by turning of/on must enter sp modes to clear this error.
Due to possibility of fire hazard would be best to have tech look at it
Oct 09, 2009 | Ricoh Aficio AP400N Laser Printer
Got a sc141 and 142 on a ricoh mp5000. Have cleaned the lamp and associated mirrors and have reseated the connectors at the lamp and sbu. i have run the scanner free run with the lamp on. there is no...
SC 141 -Lens vertical home position sensor abnormal stays on
When the lens returns to the home position the lens vertical home position sensor does not detect the off condition.The possible cause :home position sensor open,lens vertical drive motor defective or optics control board defective.
SC 142 -Lens horizontal home position sensor abnormal stays off
When the lens returns to the home position,the lens horizontal home position sensor mot detect the on condition.Possible cause :home position sensor in shortcircuit,horizontal drive motor defective or optics board defective.
The SC can be reset by turning main switch OFF and ON if the SC caused by misdetection.
Scanner free run
Remove the rear cover and the air inlet duct.Remove CN502,CN503,CN504 from the optic control board.Create short circuit TP 514 and GND on the optics board.Turn ON the main switch.Short circuit TP 512 and GND then the machine automatically starts the scanner free run.Turn off the main switch.Perform the scanner control adjustment.Enter in the service mode:press the clear modes key - 107 -press the clear/stop key more 3 second until the service mode appears.Perform the free run test mode 30 times.
Sep 19, 2009 | Ricoh Office Equipment & Supplies
Comm 503
That is "CS of modem is not able to turn ON during training." It could be a bad SC circuit board, but usually that's a bad line or connection. Get your phone lines checked out by your phone company.
If that doesn't do it, then you'll have to replace the board in the fax machine.
Nov 19, 2007 | Panasonic Panafax UF-490 Plain Paper Laser...
My Panasonic SC-A240 shuts down displaying the error f61.
Several components in the power supply maybe faulty, especially Tranisitor Q5110, Resistor R5114 and Diode D5102 on the power supply board. Check and replace these and also resolder the regulator IC's on the heatsink.
Sep 05, 2007 | Panasonic SC-AK240S Shelf System
Health & Beauty Logo
44 people viewed this question
Top Homedics Health & Beauty Experts
Jim London
Jim London
Ankit Chandel
Ankit Chandel
Are you a Homedics Health and Beauty Expert? Answer questions, earn points and help others
