Question about Pioneer DEH-P6400 CD Player
I need a wiring color code for a pioneer deh p6400 stereo deck ex i need to know what each color goes to ex. which color is the constant which is right speaker + etc
    Sergeant:
  • 306 Answers
Constant is yellow . switched ignition is red. ground is black. amp remote is blue white. illumination is orange. speakers are gray front right. white is front left. green is rear left. purple is rear right. all speaker wires have a match with a black stripe.black stripe is negitive
Posted on Feb 07, 2010
I need a wiring diagram for a pioneer deh-p6400.. please help..
red - 12v battery
yellow- 12 ignition
black- ground
blue/white- amp turn on
white FL+
white/black FL -
gray FR +
gray/black FR -
green RL +
green/black RL -
purple RR +
purple/black RR -
Feb 15, 2011 | Pioneer DEH-P6400 CD Player
I need wiring color coding 4 pioneer deh 2050mpg? i know red is constant power.
Not to question you about the red being constant power but I have a pioneer deh-1600 car stereo and red is hooked to electric terminal controlled by ignition switch (on/off) and if your unit has a yellow wire that goes to constant power. The only problem with hooking up the red wire to constant would be if you happened to accidentally leave your player on it could drain the battery. Hope this helped a little. Good luck.
Oct 10, 2009 | Pioneer DEH-P2000 CD Player
Wiring A Pioneer DEH P6400
If the factory harness is still in tact, you can buy an adapter at Best Buy for about 20$ or ask to see one and write down the pins and wires then match it up and cut n splice to your new deck. Hope this helps
Aug 17, 2009 | Pioneer DEH-P6400 CD Player
Installing my deh 2300
Heres all the radio wiring colors for your car:
2002 Oldsmobile Alero Car Radio Stereo Audio Wiring Diagram
Car Radio Constant 12v+ Wire: Orange
Car Radio Switched 12v+ Wire: Yellow
Car Radio Ground Wire: Black/White
Car Radio Illumination Wire: Brown
Car Stereo Dimmer Wire: Gray
Car Stereo Antenna Trigger: Dark Green
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Tan
Left Front Speaker Negative Wire (-): Gray
Right Front Speaker Positive Wire (+): Light Green
Right Front Speaker Negative Wire (-): Dark Green
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown
Left Rear Speaker Negative Wire (-): Yellow
Right Rear Speaker Positive Wire (+): Dark Blue
Right Rear Speaker Negative Wire (-): Light Blue
window.google_render_ad();
Jun 02, 2009 | Pioneer DEH-2300 CD Player
Memory of presets
You need to Check the Wiring Harness from the Stereo. There is a Constant Power Memory Wire (Should be Yellow or Orange). This needs to be Connected to the Cigarette Lighter Power Wire for Constant Power Memory. Please Rate My Response! Thanks!
Feb 07, 2009 | Pioneer DEH-P6400 CD Player
86 buick century
go to a car stereo store and buy an adapter plug it will plug into the plugs in your dash then all you have to do is match the wire colors from your radio to the colors on the adapter..........i believe some walmart stores carry these
Dec 27, 2008 | Pioneer DEH-P6400 CD Player
Pioneer Premier DEH-P730
Pioneer follows standard color coding for stereo/headunit wiring. Pioneer car stereos needs two wires plus the ground wire to be activated. The yellow is connected to the always on B+12 such as the positive terminal of the battery, the red goes to a switched B+12 such as the ACC of the IGN switch while the black of course goes to the chassis/body ground.
Should the above been done correctly and problem persist, then perhaps the fuse may have blown, there is a loose connector at the rear of the head unit or a probable internal electronic defect has developed.
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
May 11, 2008 | Pioneer DEH-P730 CD Player
Install pioneer DEH-P6400 into 98 dodge dakota, just wont work :-(
Have you measured the 12v ignition and permanent supply?
Also check the earth.
You will need a tester for this.
Check the fuses
John w
Feb 13, 2008 | Pioneer DEH-P6400 CD Player
STEREO PROBLEM
i need a wire layout
Jan 22, 2008 | Pioneer DEH-P6400 CD Player
Wire Color Code
what color is what on the pioneer deh-p4100
Jul 12, 2007 | Pioneer DEH-P4100
Pioneer DEH-P6400 CD Player Logo
663 people viewed this question
Top Pioneer Car Audio & Video Experts
Michael Kovalik III
Michael Kovalik III
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
