Question about Linksys WRT54G2 Wireless Router
Not getting the internet through my router anymore
I connected my WRT54G2 router six months ago and it worked just fine. Then about two weeks ago I started having connection to the internet problems, I was losing my connection. I tried everything including calling my internet provider and everything was fine but I still had the connection problem. So I disconnected the router and the problem was resolved. As long as I didn't connect the router I had a connection. My thought was to uninstall the router and reinstall. I have had no luck doing that. I am lost!
  • 12,061 Answers
Sounds as though you router has "spat the dummy". Spontaneous failures such as this generally indicate faulty electronics. The ONLY way to prove is try on another machine see if fault follows you.
Posted on Feb 07, 2010
  • 2,260 Answers
Try to upgrade the firmware of the router.
Is there any computer connected to the router with the cable.
If not then you will need to connect the computer to the router.
Download the firmware of the router from the manufacturer's website.
enter the model number. elect proper version number and download the firmware of the router.
Once you download the firmware, you will need to open the router set up and upgrade the firmware of the router.
After upgrading the firmware, it is recommended that you reset and reconfigure the router.
Click Here for more information about router and networking
Hi, I have a Linksys WRT56G2 V1 Wireless Router that worked just fine until 2-3 days ago... Now when I plug it in the power light is off, the internet light is on, the wireless light is off, and the 4...
1. the power supply to the unit has a malfunction.
the power light should be green to say that the unit is getting proper voltage if you see no light then the power supply is probably not working
If router is under warranty has manufacturer send a new one to you.
2. Try unplugging the router first for 30 second to a minute to see if your unit will restore if not a new unit is needed.
Oct 18, 2010 | Linksys WRT54G2 Wireless Router
Linksys WRT54G2 Wireless router unable to connect to Internet
Try again by Disabling the WEP (or WPA), MAC Address Filtering and Firewall Setting Individually. Should be a problem with one of those. Then when you receive the Signals, try to Adjust using Bottom Up method. That means one setting at a time, Hardening the Security. Have you checked your DNS settings? Have you checked the Channels you are using? Re check them and try again.
Feel free to contact back.
Please rate the answer if it helps you to solve the issue.
Thanks for contacting Fixya!
Jun 12, 2010 | Linksys WRT54G2 Wireless Router
Not getting wireless connection
Unfortunately Not All the details are not given in this
Any way
Try This
Open RSP By typing 192.168.2.1 on the Address Bar of Internet Explorer
On the Left hand side underneath Wireless Click Wi Fi Protected Setup
Leave the Password Blank and click Submit
Disable it And Apply Changes
Jan 06, 2010 | Belkin F5D8236-4 Router
Internet lose on my wrt54g2
please reset the router
configure the router type ip address on the browser
may be 192.168.1.1
Oct 29, 2009 | Linksys WRT54G2 Wireless Router
TEW432-BRP Trendnet wireless broadband router wont connect
Sounds like you need to configure the PC's USB wireless adaptor. The settings must be the same as the router. If you use a WEP password on the other connections then you need to have the same password on the USB wireless adaptor. Good Luck.
Jun 30, 2009 | Trendware TEW-432BRP Wireless Router...
Internet not working; Router not connecting with Internet or Wireless Adapter
try changing the wireless channel that the router is on. it sounds like something is causing interference.
May 16, 2009 | Dynex Enhanced-G Wireless Broadband Router
Connection problem
You can try to hard reset the router and update the firmware. Follow the steps below.
1. Download the latest firmware of the router from Linksys website. Save it on your computer.
2. Hard reset the router. Press the reset button at the back of the router for about 30 seconds, unplug the power for 20 seconds then plug it back in.
3. Connect your PC to port 1 of the router and access the router's setup page http://192.168.1.1 no username and admin for the password
4. Go to Administration tab > Firmware Upgrade sub tab.
5. Click Browse button and browse for the firmware file that you have downloaded from Linksys site. (.bin file extension)
After the upgrade, do a hard reset again. Repeat Step 2. Then you can reconfigure the wireless settings again.
Hope that helps.
Jan 20, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Wireless won't connect anymore
Geek squad is expensive. Have you called linksys techsupport? Here is another option, try http://technicalsupport.blog.friendster.com
Http://192.168.1.1 is not working anymore? i cant set up the router
so you can access the internet by getting connected by LAN cable. so now try to open the router by its default ip and look for the wireless securities setting and reconfigure them properly and if you are not able to access the router than there is reset button which reset the router to company default. and once you have reset the router than you have to configure it again as per your requirement.
Jan 08, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
Router causing lag after 10-20 min connected.
I know nothing about this type of router. Try pressing the button on the bottom and rebooting your router. Maybe that will help.
Jun 18, 2017 | Zhone 6211-I3-200 Router
Linksys WRT54G2 Wireless Router Logo
158 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
