Question about Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR
Hammer action power there but weak
Bosch xcel pbh corded drill. hammer action power there but weak drills power is weak
  • gobbins123 Feb 07, 2010
    bosch 220re corded drill as lost its power when i put it on hammer action it will not go through the wall it is spinning slow and seems weak
    Problem Solver:
  • 14 Answers
Bosch makes a special grease that is actually a mulit-viscosity oil thats a gel at room temp. At high temp it becomes liquid oil that lubes the gearcase and when the tool has cooled off it reverts back to a gel for containment purposes. If you use any other type of grease on these tools it will appear as if it is losing power, when it is actually being "bogged" down by conventional grease. The proper grease is Bosch part# 1 615 430 001-000. Retail price should be around $20 for a 225ml tube.
Posted on Mar 01, 2011
  • 5,603 Answers
It is hard to understand what you are asking, however I have found that with the SDS drills one does NOT want to crowd them but just let the tool work with light pressure...
Posted on Feb 07, 2010
  • Fred Yearian Feb 07, 2010
    I have had trouble with a Bosch 1194A hammer drill. The brushes fail with only a little use. Look for excess sparking at the brushes. If you have that, then you either have bad brushes or a bad armature. If no arcing is observed, then the trigger throttle control is probably bad.
    In any case, servicing is required.
How do I replace brushes on this drill?
[PDF]Hammers and Hammer Drills - eBuild
www.ebuild.com/ImgRepos%5C2010%20Hammers.pdf_06072010_110..See pages 46-49,. 184-214 for hammer drill accessories. BOSCH. H a m m e rs a n d.... 11250VSRD - 3/4" SDS-plus® Rotary Hammer .... technician can quickly replacethe brushes and cord .... 11264EVS - 1-5/8" SDS-max® Rotary Hammer.
Oct 20, 2015 | Bosch 11264EVS 1-5/8 SDS-Max Rotary Hammer
Main wires to boschhammer drill pbh 240 re
They go to the switch where the two screw terminals are.
Mar 28, 2013 | Bosch Drills
What's your problem? rotary hammer will not hammer
Look for a lever that has signs hammer/drill or just drill Place the lever in the hammer position.
Feb 19, 2012 | Bosch Drills
Replacing cord on Bosch Hammer Drill
I don't know what model you have but most Bosch hammer drills have three or four screws on the backside of the handle that, when removed, let you split the handle from the motor housing and gain access to the switch and brushes. The screws may or may not be covered by a rubber, non-slip covering that you'll have to peel back to get at them.
Jan 28, 2012 | Bosch Drills
Maintenance on a bosch pbh 2200 re sds, do i need to put oil or grease anywere in the drill?
The Bosch hammers all use a special grease for the hammering mechanisms. You should be able to buy a small tube similar to the size of a toothpaste tube, from a Bosch dealer or online. The part number is 1615430014. Here is what it looks like.
http://www.ereplacementparts.com/grease-tube-p-768150.html
Jul 16, 2011 | Garden
I bought a used Bosch Bulldog hammer drill on the internet some time ago and discovered it's not hammering. It will drill be almost no hammer action. Any suggestions?
There is an o-ring on the striker that will wear down over time, this needs to be changed, of worst case the striker has stuck in the hammer piston. Both these repairs should really be done by a service center as these hammer drills are complicated to repair if you are not familiar with them. Any Bosch service center will be able to help you. Just go to the Bosch website and find a center in your area.
Jun 08, 2011 | Bosch 1" Sds+ Bulldog Rotary Hammer Drill...
I can't remove the chuck bit from my hammer drill PBH 2000 re
This is normally easy procedure, just press chuck inward and turn clockwise, then retrieve.
This is same way as you will insert/remove your drill from the chuck.
If this method is unsuccessfull, plese rotate knob (close to chuck) anticlockwise till you go to position between chiseling and driling, as this is not lockable position, you need to hold knob in one hand and manipulate chuck with other hand.
This method is described in more detail in manual which comes with hammer-drill.
Hope this solve your problem, this is excellent tool and I always love to use it. Will handle drill up to 20mm in concrete and not even much vibration.
Aug 12, 2010 | Bosch Drills
Bosch GBH 2-20 SE hammer drill stopped working
hi
check the cord and the switch to have continuity,the wires,the brushes,the rotor and stator.
regards savumihai71
Oct 11, 2009 | Bosch Drills
New bosch psb 550 re with hammer action. Hammer action does not seem to engage. even with 5mm bit progress is non existent. The bits were bosch masonary bits and I was drilling into concrete blocks
your pin under the selector switch my have broken off. also the hammer rod could have broken too. if its drilling and not hammering that more likely. you may be under warranty call bosch or log on and go to dealer locator's for the closes dealer to you. hope this helped
Oct 09, 2009 | Bosch Power Tools Hammer Drills
Pbh 2200 re hammer action drill
hi
try to figure out how the switch operation mode works and put back together right.
bye savumihai71
Oct 13, 2008 | Drills
Bosch SDS-plus BULLDOG Xtreme Rotary Hammer 11255VSR Logo
769 people viewed this question
Top Bosch Hammering Experts
John Trevino
snowycreek
Are you a Bosch Hammering Expert? Answer questions, earn points and help others
