Question about IBM 3500 Typewriter
Storing a Job
When playing back a stored job, the writer moves instead of typing to job where it is currently set. I want the job to print where I put the writer.
  • IBM Master
  • 3,594 Answers
Is the WW printing at all? During normal typing, if not you may need a print solenoud cap. thet are available for 15.00 but a little tricky to install.
DickyO
Posted on Feb 22, 2008
Xerox center printer is being shut off instead of going to sleep and wake on job
bad control board or might be settings to put in sleep mode then shutoff check settings go to menu
Jun 03, 2015 | Xerox Office Equipment & Supplies
How can I edit an address I already have stored in my IBM Wheewriter 6 without deleting it entirely and retype it in and storing it again?
You do not have to purchase a manual for this one job. There is a free copy at http://images.lexmark.com/publications/pdfs/2007/index/en.html
Just go to the bottom of the page for "Typewriters" and choose your model. I believe the answer you are looking for is on page 3-25. I have looked at it myself. Here are the steps.
Always open the storage before making a revision.
- The store light must be on.
Pressing Store + the number (1 to 99) always opens storage at the beginning of a job.
If you play back too far or want to start over:
1. Press Play to stop playback
2. Press Store + the number (1 through 99)
3. Press Play. (Playback starts again at the beginning of the job.)
Use the Correction key to erase unwanted carrier returns from Stored job:
1. Press Play or Play+Spacebar until the carrier return playb
2. Press the correction key.
After making a revision hold down Play while you press and release the Spacebar several times to make sure the next few characters play back correctly.
When revising indented jobs, be sure to stop playback at the word or character you want to revise. Remember, you cannot use the Correction key to erase characters typed before you press Code+Tab or Code+Crtn. Therefore, if you play back too far, you may need to start playing back again from the beginning of the job.
Let me know if there is anything else needed.
Apr 07, 2011 | IBM Wheelwriter 6 Typewriter
Printer is offline - 1 document in queue that won't let me delete it
Unplug printer, reboot PC, put it all back, then it should all either go away, be able to be deleted or it may even print...
See this will clear any buffers that are storing the print job. usually removing from USB & Power, turning printer OFF, Turn PC OFF and then, reconnect, printer, to power and USB turn ON, then start the PC, then first thing go to printer properties and see if the print jobs are still there, if so, either restart, cancel etc...
Mar 31, 2011 | HP Office Equipment & Supplies
How to cancel a print job that has multiple copies selected for the print job
Click Start
Click Control Panel
Click Classic View
Click Printers
Double-click the active printer to open the "job-queue" window
Select the file to be cancelled
Right-mouse click on the selected file, and choose cancel.
Nov 17, 2009 | Microsoft Windows XP Professional for PC
The printer works but skips labels sometimes and causes some labels to be printing on two different labels instead of one. How can I fix this?
make sure the printer is calibrated. It should feed 1 label only. If it does not default it to force a calibration. hold pause and feed while off then turn on, count to 6 and release the buttons. You also need to set label height and width in the printer driver. Both zebra designer and zebra universial. goto printers and faxes and right click on your printer driver chose properties, this opens up on the general tab.
Configuration changes for current job and Default Configuration changes
There are two places in the driver configuration to change print configuration. In Windows 98, ME, 2000 and XP, go to the "General" tab and click the "Printing Preferences..." button. This menu of configuration parameters are the settings that are in effect for the current print job. Any changes made here will only affect the current, or next, print job. These settings are initialized for each print job from the configuration defaults.
Go to the "Advanced" tab and click the "Printing Defaults..." button. The displayed configuration menu describes the default settings for the driver. These settings are used to set the initial "Printing Preferences..." for new print jobs. It is a convenient place to set parameters that seldom change in you environment. Commonly set default parameters include Printer firmware, Media Settings, Device Options, and Page Size.
On Windows NT, these menus are available when you right click on the printer name in the Printers folder. The pop-up menu contains selections for "Printer Settings" and "Default Settings" which take you to these screens in the driver.
Aug 20, 2009 | Zebra Z4M Printer
Quicken no longer prints checks for me What is wrong?
Your printer DEFAULT - could be set to Intuit or Quicken PDF writer. Try to select print, and when it offers a PARTICULAR printer, see if you can designate the correctly named printer.
Also, IF there is currently a stuck or jammed job in the printer on your computer, you can find the printer queue, and PAUSE and then CANCEL the jobs entirely.
Jul 29, 2009 | Intuit Quicken Premier 2009 for PC
Zebra printer 140xilll - Too many print jobs?
It does sound like you have a memory overload when you send the 2nd print job. Each label is getting sent to the printer and filling up the memory. Make sure you are using the printer resident fonts and not a regular windows font. The windows fonts get sent down as graphics and take up memory. What zebra is saying to do is store the format of the label in the printer memory and then just send down the information that changes. For example if you were printing a UPS label the basic format of the label is the same but things such as the addresses and tracking # would change.
Jun 23, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Printer
spooling, is where the information being sent to the printer is being checked/converted for the printer driver , prior to being printed
Jan 27, 2009 | Kodak ESP 3 Multifunction Printer/ Copier/...
How to set memory
On the L. side of the keyboard there are 3 keys store, play and delete.
To store hold code and press store type in 01-99 for an address, rel keys, type info. when complete press store.
To play press play and the address 01-99 to print.
To delete press del. and address.
DickyO
Jul 23, 2008 | IBM Wheelwriter 30 Typewriter
Storing a multiple page job
Simple. Scan your document into your e-filling box. No funny stuff. When you want to print it, select your document. At the bottom of the screen you will find the button settings. It will take you to the main screen. Simply select what you want the machine to do with the document.
Hope it helps
Feb 19, 2008 | Toshiba e-Studio 350 Copier
IBM 3500 Typewriter Logo
60 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Don  Farrell
Don Farrell
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
