Question about Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV
In the lower left hand corner of the TV there is a small blue spot, what causes this?
SOURCE: Blue Noise, left side of TV
I have the same problem -- had a Best Buy technician out 4 times so far, replaced 2 parts, adjusted the voltage, etc., but still have the same problem -- looks like there may be no solution other than replacing the TV, which is an expensive proposition considering that mine is about 18 months old.
Posted on Jun 24, 2008
  • 4 Answers
SOURCE: screen appears blue
It's the Light Engine (also called an Optical block) -very expensive.
Posted on Jan 08, 2009
vinnyq
  • 157 Answers
SOURCE: Blue Spots
This is a failure of the optical block of your TV. This was an inherent problem for your model. The only way to fix it is to replace the optical block. It is very expensive (over $700) and time consuming (takes over a hour for an experienced technician).
Sony extended the optical block warranty for your model that covered parts and labor but it expired on June 30, 2008. Contact Sony, they might be able to pay for at least part of the repair.
Here is a link to the Sony response to the issue with pictures: http://7402519399385937065-a-1802744773732722657-s-sites.googlegroups.com/site/sonylcdrptvproblems/sonyrearprojectionlcdtv-opticalblock/2003GrandWEGABlueHazeAdditionalCoverage.pdf?attachauth=ANoY7cqH-wG8F6xCLp07es9MJWf0B9tr36oyw8conVtRyMlYrQTo-iZ-dba8Nq2VTMzjXKhDY_FEX-ho-9o2iYDqTkzqtsoHY1URYyWt2tAuoQZN7XMvcCPOiA4bgQupIqffnXIuB0ldeVn8bbMwfxVB7Y9cTbRXUxV_eVqVk1YuV-m_ElE7jhtlxfQ5eG6zRY6dCmnVl-_e-eGOFdgcddmrc_Vz2iRgCGkPBL3wZAK3-KFHw2kRV-w7AHaV6-A-OqHnbU8hCU0CkFwDL-6kvxWwhg-Vn4fwsDFHLeOXn3xNgvjoxPt6i6E%3D&attredirects=0
Posted on Oct 07, 2009
sonyfsd
  • 153 Answers
SOURCE: The lower left hand corner of the screen is turning blue
catually is problum is related with blue lcd & blue polizer but first you clean the optical unit if the problum gon then ok other wise must chang blue lcd & blue polorize with uv filter plese contect to your nearst sony service centre
Posted on Feb 05, 2010
hardrocko
  • 1476 Answers
SOURCE: blue spot growing in lower left had corner and
You have a bad optical engine and need to replace it. I have a tip at http://www.fixya.com/support/r4251975-replace_dlp_light_engine which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on May 12, 2010
I have a Sharpe LC-60LE600U. The power went out on it. What power board works on that TV. The lower left hand corner has a black spot, too. Will the power board fix the black spot as well?
Power Board wil not fix black spot. the spot is caused from lamp failure. Led strip has at least one LED out, takes out the whole section. Go into trouble shooting to verify. After so many start ups with the black spot, the TV will not turn on in TV mode.
Sep 22, 2016 | Sharp Aquos Televison & Video
I just replaced bulb with new and after a day there is a dark spot on the screen
I have the same TV - I have a dark spot in the upper left hand corner. I have always thought this TV was dark. Be sure to get OME lamp. Cheaper ones are not worth it and can damage your TV more.
dlplampsource,com--Just a note if this ever happens to you. TV would not come on in the AM-Had no picture, but had sound. It was not the lamp, but the safety switch. It's blue and at the bottom of the lamp housing. As soon as I flipped it and replaced the back cover, the TV came on.
Dec 22, 2012 | RCA Scenium HDLP61W151 61 in. HD-Ready...
Blue spots on Sony WEGA KDF60XS955
Thats caused by a bad optical block. The cost of that repair will almost always be greater than replacing the TV.Thats a very common issue with alot of Sony DLP models which suffered that optical block issue with the blobs of color usually blue or green
Dec 10, 2012 | Sony Grand WEGA KF50WE610 50" Rear...
Blue spot growing in lower left had corner and
hardrocko
May 12, 2010 | Sony Grand WEGA KDF-42WE655 42" Rear...
Feb 05, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
Screen appears blue
Try Moving The Speaker You Have There Away From It?
www.Myspace.com/CrossRoadsToNowhere2007
Jan 05, 2009 | Sony KDF-E55A20 55 in. LCD Television
Blue haze in lower left corner on screen
if you have any speakers near the screen the magnet may be causing the problem. i had a similar thing happen & when i moved the speaker the problem went away
Jan 02, 2009 | Televison & Video
Yellowish spot on the lower left hand corner of tv screen
Good Day, There is a device that can be used to correct your concerns. Symptoms can be correct by EE PROM CORRECTION TOOL:
LSUQ0100. Instructions included. Try calling 1-800-458-6053. It's under $100.00 and takes about 1 hour from start to finish. Good Luck, big IRISH.
Jul 07, 2008 | Panasonic PT-52LCX65 44" HDTV
Jun 12, 2008 | Samsung HP-S4253 Television
Blue Noise/Pixels Bottom Left Corner of my Samsung Plasma
You would need to have a technician remove the back of the TV and make the adjustment. There are 2 small adjusters that they change to adjust the voltage.
Jun 10, 2008 | Samsung HP-S4253 Television
Open Questions:
See all Sony Grand WEGA KDF-60XBR950 60" Rear Projection Questions
Sony Grand WEGA KDF-60XBR950 60" Rear Projection HDTV Logo
35 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
