Question about Kenmore 62602 Electric Dryer
Kenmore dryer 3prong cord installation diagram
I need to replace the 4prong electric plug on a Kenmore dryer with a 3prong, but I need a diagram so that I know which way to hook up the prongs since the wires aren't color-coded
    President:
  • 2,468 Answers
If its a" flat cord" what-ever color jacketed 3 wire cord, the 2 outside wires are your 2 hot power wires they go to L1 and L2 on your dryer,the center is the N neutral wire and goes to the N terminal,usually the L1 and L2 are a gauge larger than the neutral: HINT: the center is normally neutral on both the cord and machines terminal board in the back of the dryer,there usually is a diagram on the dryer on how to install the input power at the place you hook up power
Posted on Feb 07, 2010
  • 1,531 Answers
The three three prong cord is more or less like the four prong. so long as the middle wire goes to the center of your terminla block the other two wire go to the outside terminals
How to change from 3prong to 4prong on model FLSE60RGSI
I Am going to replace the control board to discart the possibility that I might have a brand new defective board on my hands
Feb 20, 2014 | Frigidaire FEX831CS Top Load Stacked...
I have a used dryer that 4prong electrical cord and my old unit only uses 3
you can change the cords it is easy, take the back plate off both machines and wire the three the same as the old one. Hope this helps tim
Aug 28, 2010 | Whirlpool Dryers
Trying to replace a 3prong plug with a 4prong plug
Ok, so you currently have a three prong cord on your dryer? Your house has a 4 prong receptacle? Ok so now you've purchased a 4 prong dryer pigtail? Be sure cord is unplugged. Remove cover of junction in back of dryer. You will see three terminals. They should be labeled something like L1,L2,N . ON one terminal you well see a small ground strip This is currently connecting the neutral terminal to ground. On the new cord connect the outside two conductors to L1 +L2 connect the white conductor to the N terminal. Connect the green (ground) conductor to the frame where the copper bonding was. This seperates the neutral conductor from the equipement grounding conductor.
Jul 17, 2010 | Maytag Neptune MDE5500AY Electric Dryer
Is it safe to use a 3 prong dryer cord on my 2004 Kenmore Calypso dryer? I moved to an older home with a 3prong outlet.
It is safe as long as it is wired correctly. The following link explains the differences between 3 and 4 prong configurations:
http://www.fixya.com/support/r3575913-installing_a_220_vac_appliance_cord
Just make sure to match the corresponsing wire colors at the terminal block in the back of the dryer:
RED - HOT (120 VAC)
BLACK - HOT (120 VAC)
WHITE - NEUTRAL (0 VAC)
GREEN - Ground
In a 3 wire configuration the Neutral (White) and Ground (Green) wires are terminated together at the terminal block.
NOTE: If the wires are not color coded, the outer two wires (left and right) are the HOT leads. The center conductor is Neutral.
The other alternative is to have an electrician install a 4-wire receptacle in your home.
If you have any questions, please post back and let me know. I hope this helps you.
Mar 31, 2010 | Kenmore Elite HE4 Electric Dryer
Need diagram for replacing 3 plug to a 4 plug
The following link explains how to convert from a 3 prong appliance cord to a 4 prong:
If you have questions, please post back and let me know. I hope this helps you.
Feb 07, 2010 | Kenmore 62882 Electric Dryer
4 prong power cord to a 3 prong monunt I'm trying to replace a 3prong cord with a 4 prong but there is an extra wire, what do I do with it?
Dryers come with a wire or metal strap connecting the center "neutral" terminal to the frame of the dryer. When using a four wire power cord, take that wire or strap off the frame. (it can be discarded or better yet, in case this dryer needs to ever be converted back to a three wire cord) connect the frame end of the wire / strap to the center terminal of the power block. Now, Green (ground) wire goes to the dryer frame, White (neutral) goes to the center terminal, and the Red and Black (both "hot") wires go to either outside terminal. (one to each)
May 22, 2009 | Maytag Neptune MDE4000 Electric Dryer
I need to change the dyer cord from a 4prong cord to a 3prong cord. Is it possible? It is model number M90825760.
If you have a digital camera, you could take a picture of the plug (several different angles) and your outlet then go to one of the large chain hardware stores, camera in hand, and ask for an adaptor between the dryer's plug and your outlet. It may not be necessary to rewire the dryer at all. If they don't have one, keep reading.
The change probably is possible since dryers generally use a 2-phase connection at the most but I wouldn't recommend that you DIY. You are dealing with a line voltage whcih could be 220 and a circuit capable of supply fairly high (20) amperage.
This combination could make toast out of you if improperly wired. Any competent electrician can determine how to do the conversion with a few measurements.
There is an exception; some mfr.s have pasted a large label either inside or out on the larger panel that contains the electrical diagram of the machine.
With some care, most laymen could determine how to make the change.
Mar 03, 2009 | Kenmore 62622 Electric Dryer
Kenmore series electric dryer need to replace 3 prong w/4 prong
The following link explains how to convert a 3-prong appliance cord to a 4-prong and vice-versa:
http://www.fixya.com/support/r793520-3_prong_4_prong_power_cord_conversion
If you still have questions, please let me know. I hope this helps you.
Feb 15, 2009 | Kenmore 62802 Electric Dryer
WIRING DIAGRAM
The following link explains the proper wiring scheme for installing a 220VAC power cord to an appliance:
Make sure you also have a dedicated outlet and power source for your dryer. This means a single outlet with a single circuit breaker. Most homes are constructed this way to ensure safe operation of the appliance and to prevent improper loading. If you have questions, please let me know.
As far as a wiring diagram is concerned, most manufacturers place a schematic drawing inside the operator console of the appliance for troublshooting purposes. I hope this helps.
Oct 16, 2008 | Kenmore 64732 Electric Dryer
Kenmore 62602 Electric Dryer Logo
1,143 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
