Question about Campbell Hausfeld MIG / Flux Core Wire Feed Welder
Have campbell hausfeld farm hand wg 2064 wire speed wide open and cant get to slow down.
2 Suggested Answers
  • 8 Answers
SOURCE: Got a Campbell Hausfeld gasless 80amp welder. The
Check the tension on the drive wheel, you also might need a liner, they are fairly inexpensive
Posted on Aug 07, 2009
Air compressor issue
Sounds to me like a power issue, is your machine a single or 3 phase? Do you have an extension lead fitted to it? As the pressure builds, the motor needs more juice to turn it, if the power source isnt powerful enough then the motor will slow down, you might need to check that before looking at the compressor itself.
Aug 31, 2012 | Campbell Hausfeld Air Tools & Compressors
SMALL PUDDLES NO PENATRATION WELDER IS FARM HAND 115 VOLT MIG//FLUX CORE WIRE FEED PUT ON ANY SETTING NO DIF CANT FIND MODLE IT HAS CHPOWER.COM WEB ADDRESS
Hi:
If you are using flux core wire you need to switch the polarity of the machine. With flux core wire, your ground clamp becomes positive (lead) and your gun the ground. All you need to do is switch the cables above the feed rolls.
That will take care of the problem
If this was useful to you, please vote. Thanks.
Mar 20, 2011 | Campbell Hausfeld Welding Tools
My welder does'nt feed a constant feed motor seems to slow down and wire pushes my hand away when hitting metal.
If wire pushes your hand away when welding you need to do one of the following:
Reduce your wire speed, or increase the voltage.
Nov 24, 2010 | Campbell Hausfeld ® 115V MIG Flux Core...
16g wont shoot nails. bottom flat piece comes out
You broke the "hammer" you can open the housing and replace it, fairly simply. You can buy replacement parts at most large scale hardware or tool stores. The task takes about 10 min, and some simple hand tools.
Jan 03, 2010 | Campbell Hausfeld 2" 18GA Brad Nailer
While running to build pressure it slows down then speeds up
hi buddy can be the valves sticking try squirting oil in the air filter and get back to me
Sep 19, 2009 | Air Tools & Compressors
Aug 07, 2009 | Campbell Hausfeld MIG / Flux Core Wire...
Blowing circuit
Does it sound like it's running the usual speed? If it's at lower speed, it may have a problem in the motor, or a voltage drop condition exists. If speed is near normal, check the reeds in the compressor, or the checkvalve between the head and the tank.
May 22, 2009 | Campbell Hausfeld 26 - Gallon Air...
I have a Campbell Hausfeld MIG Welder 80, The wire will not feed,
Here's a link to the Campbell Hausfeld web page. Look under "Service Center" for "Find a Part." I hope this has what you need.
http://www.chpower.com/webapp/wcs/stores/servlet/chHome_10051_10001_-1
Feb 22, 2009 | Campbell Hausfeld RBWG202000 NA 70 Amp....
Campbell Hausfeld MIG / Flux Core Wire Feed Welder Logo
305 people viewed this question
Top Campbell Hausfeld Welding Tools Experts
rjivaro
Joseph Mueller
Joseph Mueller
ray gallant
Are you a Campbell Hausfeld Welding Tool Expert? Answer questions, earn points and help others
