Question about Grundfos MQ3-45 1 HP Pressure Booster Pump
My pump turns on when I open a faucet; pumps perfectly for exactly 13-seconds, then stops for two seconds, then pumps again for 13-seconds; then stops for two seconds, then pumps again...indefinitely. What can I do to fix the problem?
  • Leo MacCanna Jan 02, 2012
    I have exactly this problem. How do you increase screw in pressure regulator?
    Champion:
  • 243 Answers
Sounds like high pressure stop. increase screw in pressure regulator. or use more water.
Posted on Feb 08, 2010
  • jaap schildmeijer Feb 10, 2010
    can also be air in the pump.
    then it cannot reach its switch off pressure and the electronics will stop the pump and start it up again.
    Problem Solver:
  • 19 Answers
There are only a couple of conditions that will cause an MQ to cut out, those being: full pressure being reached, a dry run condition (takes 30 secs to occur) or a voltage issue/ overload. The pump may be coming up to pressure and shutting down only to find the pressure drop and need to start again, very common on low flow conditions. Is the suction check valve in place?
Posted on May 18, 2010
  • 3 Answers
Replace control unit or bypass control with a normal pump pressure switch..I recomend the bypass..it works and I had to replace the control unit twice in two years..nor no problem..
Posted on Jan 14, 2012
Did you find soloution yet
Posted on Oct 11, 2011
When starting my Bauknecht GSFP 5586 dishwasher the program is set for rinsing and the start light flashes two blinks, then again two blink etc. I cannot get the program to change. When I hold the Start...
Ok, so I had the exact same problem with the exact same model. NOT 7 blinks and to buttons that you do not have.
I will tell you what I did as I do not know what (if any) of what I did fixed it (it could be luck but I do not think so).
1. I pulled the washer out of place. You should see a small thing connected on the inlet pipe that is supposed to stop flooding. I gave that a few taps. (I am quite sure that this is not the fix but who knows).
2. I pressed the start (rest) button until the washer started to reset (whet to the END mode). I DID NOT wate for it to end. While it was pumping I turen the washer off using the power button. Then I turned it on again. I went on pumping. Then when it stopped pumping I turned it off again, waited toe 2 seconds and turned it on. Much to to mu surprise when I turned it on it was working normal.
I hope it goes on doing this as this in only the second problem we have ad with it in 13 years.
Hope this hels
Mar 31, 2010 | Dishwashers
13 standby blinks. Sony KDL-52W3000
It's a power supply related issue. It's an error code for a certain circuit pathway, but I'm not sure 100% sure what code 13 can be because I don't have the Service Manual for your exact TV model number. But, here's where you can get one:
http://www.service-manual.net/ashop/catalogue.php?cat=231&exp=&resultpage=108&shop=1
It will have all the info on the trouble codes for your TV. Schematics, Diagrams and Part number list for repairs.
Sep 03, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
Culligan RO sstem has recently stopped producing more that 6 oz
This might be a possible tank pressure issue. This could also be a clogged filter. I would first check the tank pressure by using the following steps
Necessary Supplies:
1) Tire Gauge marked in 5psi increments (ie 5, 10, 15, 20psi, etc.)
2) Bicycle tire pump for standard type bike tire valve
To recharge RO System Tank:
1) Close cold water feed valve (valve located at some point along the cold water line from street plumbing).*
2) Leaving RO tank valve on, turn tank on side & locate valve stem on bottom side.
3) Remove stem cap.
4) Drain all water out of tank through open RO faucet into sink. (Continue to leave RO faucet open throughout procedure)
5) If current tank pressure is insufficient to empty tank, apply tire pump to valve stem and pump 10 – 15 times. Exit flow will increase and then gradually decrease as pressure equalizes. Do not overcharge internal bladder of tank during this procedure.
6) Repeat step #4 until tank is completely empty. (Tank is empty when additional pumping produces no more water)
7) At this point, adjust EMPTY tank to exactly 7psi. (Gauge reading midway between 5 & 10psi is sufficient)
8) Turn off RO faucet.
9) Replace cap on valve stem and reposition tank in upright position.
10) Open cold water feed valve.*
11) System water is useable immediately, however, tank will take 3-4 hrs to completely refill.
FreshWaterSystems.com: The Water Super Store: 1-877-335-3339
Mar 19, 2009 | Culligan Under Sink Water Filter
''no water''
I too had the same problem as you with my pipes freezing, but my heat was the culprit. Basicly the problem was the same. I turned the water on in the sink and when the water thawed there the pump started and oh my god I had broken water pipes in the house under the counter, so I turned the main water valve off, or the pump from the breaker box for the well. The difference is that if you turn the well pump off then the water runs until the pressure goes down. If you turn the main water off it will stop sooner. I fixed the pipes under the sink and behind the dishwasher started to leak, Fixed that and again turned on the water again at the main valve. Ask where your main water lever is. My water started to run in the sink area, but the drains were frozen, I put a heater under the house and heated up the pvc pipe that was still frozen. Of course the toilet..... When it got alittle warmer and the heat on the pipe, things broke loose. The plumber was no where to be found because they were so busy, this worked for me and people had great ideas for me to try. When the water and the pump were turned back on all leaks were fixed and things are back to normal. I am now wiser...I hope this story helps somewhat.
Jan 17, 2009 | Plumbing
Water pump Question
Ensure that the water pump is turned off then locate the water pump in your RV. Typical locations are under the dinette, under the bed, or in a cabinet near the sink. If you can't find it, turn on a faucet and locate the noise coming from the pump (this should be really easy!). A typical water pump will be secured by 4 screws. Remove these 4 screws and slip a rubber mouse pad under the pump. Re-secure the pump being careful to not over tighten the screws. Using a mouse pad will help absorb the vibrations from the pump to the floor. Next, we will locate the rattling water pipes. Turn on the pump. Have a friend open and close any faucet while you try and locate where the clanging noise is coming from. Typical areas are where the cold water pipe passes through or runs along a cabinet wall. In this case, the cabinet acts like a sounding board and creates a lot of noise. Take some 1/2" foam pipe insulation and wrap the pipe where it rattles against the cabinet or flooring. It should slip right over and not require any securing to the pipe. But a little duct tape on each end of the insulation wouldn't hurt. Repeat this step until you have insulated all rattling pipes. Sometimes the water pump can rapid cycle on and off (cycling ON/OFF in less than 2 seconds) during low flow conditions. This can cause pulsations in the water system and create noise. To determine if adjustment is necessary, turn a faucet ON to lower than average flow of water. The pump should cycle, but its "OFF time" must be 2 seconds or longer. If the cycling is correct, no adjustment is necessary. If the pump is cycling rapidly, increase the setting by turning the adjustment screw (see image) clockwise (1 turn MAX.) until the pump operates for 1 sec. with at least 2 sec. "OFF time".
Aug 27, 2008 | Whirlpool Safety Bath Walk In Bathtub -...
Grundfos MQ3-45  1 HP Pressure Booster Pump  Logo
1,317 people viewed this question
Top Grundfos Garden Experts
john h
jasbo
jasbo
Audrey Messer
Audrey Messer
Are you a Grundfos Garden Expert? Answer questions, earn points and help others
