Question about Apple iPhone 3GS Black (16 GB)
I HAVE ONLY EMERGENCI CALL
I HAVE ONLY EMERGENCY CALL
    Problem Solver:
  • 4 Answers
It sounds like your SIM card is not being detected. Make sure it is seated correctly in the holder and that nothing is obsructing the contacts inside the phone.
Posted on Feb 25, 2010
Is there any danger in running my Carrier HVAC in "Emergency Heat" mode all the time?
No theirs no danger in running the Emergency Heat all the time, Emergency Heat is your backup heat mode. when the Heat Pump is not working do to a malfunction or Defrost, the Emergency Heat kicks in. The Emergency Heat is usually electric heaters so your electric bill will be much higher.
Nov 07, 2016 | Carrier Heating & Cooling
Tip
Removing rear rotors
On the rear wheels, the inside of the rotors act as a drum for the emergency brake shoes. You must loosen the emergency brake so that the shoes back away from the inside walls of the rotor. Loosen the emergency brake, left and right side, by loosening both nuts at the emergency brake handle. Further, the emergency brake's internal adjusting nuts are accessible through the lug holes in the hub. Then remove the rear rotors
on May 19, 2008 | 1987 BMW 5 Series
How do i remove the emergency break cable on the rear caliper of a 2001 jaguar s type?
No, you do not have to remove the emergency break cable unless you are changing the emergency break pads. The caliper acts independent of the emergency break.
Feb 16, 2015 | 2001 Jaguar S-Type
S3
Maybe tou entered the password wrong when you set up the phone.
May 10, 2014 | Samsung i9082 Galaxy Grand Duos Dual SIM...
What is needed to fix emergency brake on dodge nitro
Adjust the Emergency Brakes
  • 1 Raise the car on a car lift. While using a car jack may be tempting, do not use it. A car jack is much too unstable to properly support a car for long and should at least be reinforced with safety stands.2 Locate the emergency brake adjustment. It will be found underneath the car, roughly in the area where the emergency brake pedal is located in the interior of the car.
  • 3 Adjust the emergency brake using either a screwdriver or a wrench, depending on the make and model of your vehicle. The brake line will be visible and in most cases will need to be tightened. This can be accomplished by turning the emergency brake adjustment so the line becomes tighter.4 Test the emergency brake again by parking on a sloping road and engaging the emergency brake, again noting at what point it engages when it has beenpressed and at what point it is fully engaged.5 Repeat the adjustment process until the emergency brake will engage properly. Take care not to adjust the emergency brake too tight, or it will always be engaged, which will damage your hydraulic brakes as well as the emergency brake.
Sep 29, 2011 | Cars & Trucks
My car has a small red ligth in side panel by the estering well that is flashing and make a sownd like a emergenci ligths on
probably part of a antitheft system,talk to previous owner or disable it.
TIM...................
Oct 21, 2010 | 1993 Dodge Intrepid
I start de generator ahd the light of L.H.propect is on and emergenci stop and off de generator.
check your oil level. many generators have a low oil level light and will shut off to protect the engine
May 30, 2010 | Electrical Supplies
Why do the turn signal lights come on the mirrors when doors open
dont worry is factory sefty so anibady in trafick will see yu,nuver vans hawe same.sefty laike dodge caravan emergenci flasher com on wen doors is open
Mar 13, 2009 | 2001 Ford Windstar
Emergency brake
look under the front of the rubber boot that covers the bottom of the park brake handle, u will see a nut on the end of the park brake cable, tighten it until u reach the proper adjustment.
Feb 27, 2009 | 2004 Kia Rio
Emergenci
The flat side with numbers points away from the motherboard.
Mar 10, 2008 | Dell Inspiron 7000/7500
Apple iPhone 3GS Black (16 GB) Logo
94 people viewed this question
Top Apple Cell Phones Experts
Computer Repairing
Computer Repairing
Lesley Cameron
Lesley Cameron
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
