Question about HP Mini 1000 Netbook
My pc wont even load up. it just gets stuck on the first HP screen with press f9 or f10. it just freezes up, and i dont know what to do. ive tried pressing both of the keys but none work.
  • djxs_ee Feb 20, 2010
    well 1) it wont even go to safe mode. i press f8 before it loads and nothing happens. 2) there is no CD drive, nor is there backup software. 3) HP has the worst support system up right now.
    to be more clear: I turn on the computer, the lights go on, the screen lights up. the first screen it shows is the one with the HP Logo and 2 keys F9 and F10. F9 doesnt really work, and F10 doesnt do anything. thats as far as i get.
  • 3,640 Answers
Try to start it in safe mode, then you can run system restore back to see if this fixes it. when computer loads up and shows the first screen, then push f-8 before it fully loads, this will take you to the safe mode screen, choose safe mode, then when loaded run system restore back to where the problem was ok. if this does not work then I would restore windows from the backup cd. if using safe mode when rebooting, it will change back to normal.
Posted on Feb 07, 2010
My HP Pavilion is stuck on the blue screen
While your system is still booting from start, keep hitting F11 to get past that point then proceed with the system recovery.
Nov 12, 2013 | HP Pavilion a6110n PC Desktop
Compaq Presario CQ50-103NR Notebook PC stuck in sleep mode
Try and perform a Hard Reset onto your laptop.
Performing Hard Reset
1. Turn off PC
2. Unplug both battery and ac adapter
3. Hold Down on the power button for 30 seconds
4. Plug everything back in and turn it on.
When you are back at your desktop screen, change the sleep mode and display settings to 1 minute to see if you can wake it back up.
If not, then load into your BIOS by pressing F10 during boot up. Once in BIOS, press the F9 key and select "load defaults". Once you load defaults, press to F10 key again to save changes and exit. After that, search the hp website using your product # on your laptop to see if there are any BIOS updated for your product.
Aug 13, 2012 | HP Compaq Presario CQ50-103NR Notebook PC
Monitor to bright
Decreasing Screen Brightness (FN+F9)
Press and hold the FN key, then hit the F9 key to decrease screen brightness.
Increasing Screen Brightness (FN+F10)
Press and hold the FN key, then hit the F10 key to increase screen brightness.
Mar 21, 2012 | HP Compaq nc6230 Notebook
I have a HP dv4t-1100SE. Recently I changed my LCD panel as per HP advise. The notebook worked fine for 3 months. Again I have multiple problems. 1. As soon as I start my notebook screen starts...
1; Try running with no main battery first. (batteries are short lived)
2: try a new power pack.? (wall to PC)
3: ;make sure the power pack jack at PC edge when wiggled does not cause screen to drop out. (bad connection there)
4: bad LCD inverter. (if separate from main screen)
5: stuck key on keyboard.
6: As you turn it back on tap the F10 key. This will load BIOS setup utility.
Press F9 to load defaults.
Press F10 to save and exit.
7:overheating, it can do that fast if the CPU heat sing falls off.
or goes loose with no thermal compound working there,
or full of dust bunnies. the fan must blow and most cool the pc
and not have its vents blocked, clean it. is cure.
HOw does BIOS work, ? good? all sceens look ok, /?
esc key or F10 to reach bios, which every yours is.
Apr 21, 2017 | HP Computers & Internet
I was playing around in my bios and must have set something wrong because no I get the black screen with F9, F10,F12 at the bottom right (Boot, Setup, Network) but not the blue F! at the left to boot it...
Just set the BIOS configuration to its default settings. Simply access the BIOS again and on the BIOS, Press F9 and select "Yes or press Y" to load BIOS defaults and Press F10 to Save and Exit BIOS setup.
Thank you for visiting FixYa!
May 19, 2011 | HP Compaq dc5100 Small Form Factor PC...
Wont boot tells me to choose f10 or f 9 nthen wont do anything no matter what you choose.
i press f9 and f10 it say when i turn my laptop on no boot device insert boot device and press any key i dont have a boot device
Mar 07, 2011 | HP Mini 1000 Netbook
Hi, i have a mini 1000 xp, it will show the hp logo and says press f9 or f10, but after that the screen will not load if dont click any button, it stays on black screen
It happens like that only when the Operating System fails to load correctly. Insert your OS CD and perform a repair. This will identify damaged files and reinstall them. If this procedure doesn't work, you will have to install a new copy of the Operating System.
Jan 05, 2011 | HP Mini 1000 Netbook
I have a HP Touchsmart IQ500 that is a little over a year old. It was working fine and I went out one day to come back and start it up to find it was only a blue screen with a few options.I found someone...
This might be an issue with the Hard drive or the operating system installed on the hard drive.
Try to access BIOS screen tapping on F10 on restart.
If you are able to access Bios try to run the Short smart self test on the Hard drive.
To run the test follow the steps as follows:
on the main window you will see 1 st drive 2nd drive 3rd drive 4th drive.
besides these drive letters you will find your Hard drive listed.
Highlight that and press enter.
on the next screen highlight Smart support and press enter.
on the next screen select Short smart self test and run the test.
If it gives an error code that means the hard drive has gone bad.
2)If not then come back on the main page by clicking on ESC button till you come back to the main page.then Press F5 select yes to load set up defaults and press enter.Press F10 once to save configuration changes and press enter.
It will boot to windows.
3)Still if you face the same issue then you need to perform the recovery using the recovery cds.
4)If you don't have the recovery cds then you can contact HP support and order the cds and perform the recovery.
This should resolve your issue.
Thanks.
Aug 20, 2010 | HP Computers & Internet
My HP Pavilion DV9000 is having boot up problem
hi
this is nothing to do with system crash.
> Take out the battery and the adapter from the notebook hold the power button for 30 sec
> Power on - ASAP tap on F10 - There if you are using vista press F9 to load the bios defaults and press F10 save and exit
With regards
Apr 12, 2009 | HP Pavilion dv9000z Notebook
HP Mini 1000 Netbook Logo
544 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
