When power button is pressed all the leds light up as normal but nothing happens. I have tested the oob switch, motor windings, display module, valves and pump, and motor controller all are ok
    Top Expert:
  • Washing Mach... Master
  • 75,807 Answers
Then the problem lies in the CCU main board, that is the number cause of this type of issue, this is the main board that controls timing and mode functions
Posted on Feb 07, 2010
New Control Panel instald all it does now is beep open lid stop beeping close lid nothing happens lights stay on help please
It is important to set the size switch setting into the Motor Controller's memory whenever a replacement Motor Controller and or Display Module is fitted
To set the size switch turn the power on at the wall and off at the machine. Press and hold the TEMPERATURE UP button then press the POWER button. SmartDrive will give 4 short beeps and the pattern of LEDs will change.
• Press SPIN SPEED UP button, the SPIN HOLD LED is on for (8.0kg) (650mm wide). • Press POWER to exit this mode.
If this doesn't work let me know
Jul 16, 2015 | Fisher and Paykel GWL11 Top Load Washer
Kenmore110.620 will not start
Electric dryer no start does nothing
Check dryer Terminal block prongs both outside prongs should give combined 220, and 110 each if u check 1 outside & 1 center (ground) prong. Also check house electrical outlet for full voltage.
CHECK THERMAL SHUT OFF THERMOSTAT USUALLY LOCATED ON THE BLOWER. for OHMS or resistance with a meter. Should show a closed circuit. Ohms WHEN THIS FUSE BLOWS IT WILL SHUT DOWN EVERYTHING.
NEXT Test the PUSH start switch with meter for OHMS. Should show OHMS when pushed in or on start, and no ohms or infinity when in off position.
If you hear a humming/clicking sound from motor area you more than likely have a bad motor.
Try this test out to see if u have weak windings or relay/capacitor on motor.
Open the dryer door and turn by hand the drum while machine is on ON position. And you or someone else presses the door engagement switch in. If it starts up then u have bad windings
Another thing to check is the belt safety switch. With a multi meter.
Especially if u just replaced the belt. The belt safety switch is attached to the Tensioner and motor. IT LOOKS LIKE A DOOR SWITCH SOMEWHAT a little black pc of plastic with 2 prongs going into it. Sits at bottom of motor. Under the Tensioner. Attach meter clips to the 2 prongs on switch, Then when the little white push button is pressed in it should show continuity and none when released.
Lastly check ut push start button for continuity with a meter when pushed in the on position, it may have gone bad.
Aug 18, 2014 | Kenmore Dryers
Ge front load error codes t01
make this test: God bless you
- 45 -
Service Test Mode
The dryer control has a service test mode that can be utilized by the service technician in order to test
critical components and to access error codes. This test mode will help the service technician to quickly
identify failed or improperly operating dryer components.
Test Mode Description
t01 Model ID Verifi
es (or sets on new board) the proper model id.
t02 Error Codes Lists up to 10 control-detected problems.
t03 Software ID
Displays the software version number and the non-
volatile memory version number.
t04 Program Non-volatile Memory Test Control computes and compares the 16-bit CRC of
the non-volatile memory with the pre-computed
version stored in the non-volatile memory.
t05 User Interface Control turns on all LEDs and the 7-segment display.
t06 Keys Continuity Verifi
es that all displays and buttons work.
t07 Outlet Thermistor Displays outlet thermistor temperature.
t08 Inlet Thermistor Displays inlet thermistor temperature.
t09 Moisture Sensor Displays voltage read from the moisture sensor.
t10 Exhaust Detection Verifi
es status of the exhaust system.
To enter the test mode: To exit the test mode:
Disconnect the power for 30 seconds.
Reconnect power and within 30 seconds of
reconnecting power:
Press signal button.
Press delay start button.
Press delay start button. (Displays t01)
1.
2.
a.
b.
c.
d.
Press the power button during the test selection
mode.
Note:
A dryer left in the test mode will exit the test
mode after a period of 30 minutes
Oct 01, 2013 | GE Dryers
My machine stopped and made a constant beeping while the 3rd, 5th, 7th & 8th lights across the top remained on. What does this mean????
It sounds like this is a Fisher and Paykel-made top load washing machine and you are referring to the Wash Progress LEDs. The flashing of the 3rd, 5th, 7th and 8th LEDs from left to right indicates fault code 43 and it means the Motor Controller Module has detected that the out of balance switch is permanently tripped. The out of balance switch lever may have been stuck in the open position or the harness connecting it and the Motor Controller Module is disconnected.
Move the basket assembly as far as it can go towards the right hand rear corner of the cabinet several times to possibly lodge the lever back into close position. Raise the top cover then locate the out of balance switch at the right hand corner of the cabinet then make sure the lever is hanging freely. Disconnect the out of balance switch wire harness, if the lever is properly hanging but the same LEDs are still flashing (Fault Code 43), then join the terminals together to bypass the switch.
Reconnect power then start the machine. Replace the out of balance (OOB) switch if the machine works fine with the switch bypassed. If not, check the continuity of the OOB switch wire harness and make sure it is snugly connected to the Motor Controller Module. The problem is in the Motor Controller Module if the wire harness is intact and snugly connected but the machine still doesn't work even with the OOB swicth bypassed. Replace the Motor Controller Module if that is the case.
Mar 22, 2011 | Washing Machines
Why does my fisherpaykel washing machine beep and flash the 3rd 5th 7th 8th lights
(00101011) Phase 1 to 6 - OOB Switch Fault The Motor Controller module has found that the signal returning from the out of balance switch indicates that the switch is permanently on or the harness to it is disconnected. Primary Source: Mechanical. Action: 1) Check that the out of balance switch is free to move. 2) Check that no harnesses are blocking switch movement. 3) Check that the switch operates correctly when activated. Replace the switch if suspect. 4) If the out of balance micro switch shows signs of corrosion, replace the switch and switch harness, and fit a condensation kit to the console area if not incorporated in the top deck. 5) Check the level of the machine and also the bias spring. Secondary Source: Wiring. Action: Check the harness to the switch is connected correctly. The terminals should be connected to the normally closed position. If the harness terminals show signs of corrosion, then fit a new harness. Tertiary Source: Motor Controller module.(Display Module Phase1 ) Action: Replace Motor Controller module.(Display Module Phase 1)
Feb 06, 2011 | Fisher and Paykel Washing Machines
I press the power button but the machine does nothing. It's pluged in and the lcd lights up
  1. Unplug the power cord from the electrical outlet.
  2. Plug another appliance into the electrical outlet to make sure the outlet works.
    • If the electrical outlet does not work , plug the product into another outlet that does work.
    • If the electrical outlet works, but the product still does not turn on , continue to the next step.
    • The power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
      1. Unplug the power supply from the rear of the product.
      2. Unplug the power cord from the electrical outlet, power strip, or surge protector.
      3. If the product uses a power module with a detachable power cord, disconnect the cord from the power module.
      4. Wait 15 seconds.
      5. Reconnect the power cord to the power module.
      6. Plug the power cord back into the electrical outlet. Do not use a power strip or surge protector.
      7. Check to see if the power module has an LED.
        • If the power module does not have an LED, continue to the next step.
        • If the power module has an LED, check to see if the LED lights up.
          • If the LED does not light up, contact HP to replace the power module. To buy a compatible power module, right-click the following link, How to Buy HP , and then click Open in New Window .
          • If the LED lights up, continue to the next step.
      Step two: Test the power on the All-in-One Follow these steps to test the power on the product.
      1. Reconnect the power supply to the rear of the product.
      2. Press and quickly release the Power button (c01602202.gif ) to start a Power On/Off cycle. Do not hold the button down. Figure 1: Press and quickly release the Power buttonc01896071.gif c01733891.gif If you press and hold the Power button too long, the product might turn on and then off without restarting. If this happens, press and quickly release the Power button (c01602202.gif ) again.
      • If these steps resolved the issue , there is no need to continue troubleshooting.
      • If the issue persists , see the next step.
      Solution four: Test the power with a compatible power cord from a different product If you have another available power cord that is compatible with your product, use the alternate cord to repeat the steps in Solution three: Reset the power module and test the power .
      • If the product turns on with the alternate power cord, the original power cord caused the issue. Contact HP to replace the power cord. Right-click the following link, How to Buy HP , to buy a compatible power cord.
      • If the product does not turn on with the alternate power cord, continue to the next step.
      Solution five: Service the HP product If you have completed all the steps listed above and are still experiencing a problem, service the product.
Jan 17, 2011 | HP PSC 2355 All-In-One InkJet Printer
Transfer case wont engage borg warner 13-56 electronic
if when you press the button to shift into 4 hi, all you hear are a lot of clicks from the control module under the glove box and no indicator lights, that could mean the actuator motor on the back of the t-case is warn(it has no braking ability) so it overshoots its position. this is a common problem. you can go under and hear the motor moving but it seems like it doesnt do anything. sense the module cant get the motor to stop in the correct position, it defaults all the way back to 2wd. a new tcase motor will fix that, you have to splice the wires into the 10 pin connector because from the factory i think 8 wires go to the motor/position sensor and 2 or 3 wires go to magnetic clutch and speed sensor. if there are no click when you press the button, i mean nothing happens, you can run a self diagnostic on the control module by turn the ingnition off, disconnecting the bottom 2 connectors of the 4x4 module (the top connector is the power supply dont touch that one) then turn key on and press the test button on the module (next to the red LED) if the LED lights up and stays on the module is bad. if you press the test button without disconnecting the bottom 2 connectors the led will light and stay on, this is normal and not an accurate self test. turn the key off before reconnecting the module. this advice is of course is assuming you already checked fuses, inspested ALL connectors in the circuit, especiall if a new tcase motor has already been spliced in some years ago, checked power at the switch and module and good grounds.
Aug 10, 2010 | 1995 Ford Bronco
My Tunturi Treadmill ramp is stuck in the top elevation position and will not run. I get a "Auto Syncing" message, but the machine will not run. Have tried unplugging etc, but it will not exit the mode...
Enter the testing mode after switching the treadmill POWER ON by pushing first ‘SELECT’ and then ‘SPEED DOWN’ and hold buttons pressed simultaneously.
LED scanning mode for verifying display functionality Press ‘ENTER’ to scan DATA LINES to verify display functionality Press ‘ENTER’ to scan SACN LINES to verify display functionality Press ‘ENTER’ to scan LED’s to verify display functionality After pressing ‘ENTER’ the TIME window shows “test” and the keypad functionality can be tested (the value displayed changes when a button is being pressed) Press ‘ENTER’ to enter IO mode (TIME display shows lift motor potentiometer value, SPEED reads speed from speed sensor and DISTANCE shows heart rate pulse) Press ‘START’ to test lower board relay (a “click” sound) and then press ‘ELEVATION UP’ for 2 seconds to increase the elevation to 8%. Press ‘ELEVATION DOWN’ to decrease the elevation to minimum percentage 0% Press ‘SPEED UP’ to increase speed value and ‘SPEED DOWN’ toto decrease speed value. Press ‘ENTER’ to repeat above test or ‘SELECT’ and ‘ SPEED DOWN’ buttons simultaneously to return to the normal mode
The lift motor calibration is done manually by following the following steps: 1. Drive the lift motor to 0% from user interface (inclination display must be 0%) 2. Switch off the treadmill and unplug the power cable 3. Remove motor cover 4. Fold up the running deck 5. Loosen two screws (A) attaching the lift motor nut (B) to the incline frame 6. Adjust the lift motor nut (B) so that there is 9 mm (.358 in ) gap between the upper end of the nut and the lift motor frame Tighten the screws (A) and verify correct elevation by measuring Adjusting lift motor to 0% position 2.76in 12% position 9.646 in measurement taken from floor to bottom of motor compartment frame.
Jun 11, 2010 | Tunturi T30 Programmable Treadmill
Wont switch on
Solution three: Reset the power module and test the power Step one: Reset the power moduleThe power module has a safety feature inside that protects the product during a power surge. If you experienced a recent power surge, the power module might need to be reset. Use the following steps to reset the power module.
  4. Wait 15 seconds.
Step two: Test the power on the All-in-OneFollow these steps to test the power on the product.
Apr 07, 2010 | HP Photosmart C5180 All-In-One InkJet...
I have just changed the brown control board and now i have a fault code 9
Hi and welcome to FixYa. I am Kelly.
You did not provide a make and model number so here is my best model to problem guess....
Your new control board is missing the size information.
AQUASMART-SIZE-SETTING. Size information must be programmed when a Motor Control Module or Display Module has been replaced. If the size is not set, the display will show fault code 9, or the water levels and wash actions will be incorrect. If the machine displays fault code 9, the machine must be switched off at the wall and then back on again before it can be sized.
Setting the size:
Unplug at the wall and then re-plug it in.
Press and hold Temp Up, then press Power. Wait for the 4 beeps, then set your machine size as follows to YOUR machine size:
5/5.5kg machines - press Temp Up. Cold led should light.
6/6.5kg machines - press Water Up. Low water led should light.
7/7.5kg machines - press Spin Speed up. Spin hold led should light.
Power off, try a programme.
Thanks for using FixYa!
_____________________________________
From the Tech Sheet:
IWL12 and GWL 11 are different models. One of the two procedures will work for your machine.
The machine size must be set into the machine
memory if a Motor Controller or Display Module has
been changed.
To set the size:
1. Turn the power on at the power point and off
at the console.
2. IWL12 - Press and hold the FABRIC CARE
button, then press the POWER button. This
will present a set of options in the LCD
screen. The LCD screen has within it a
number of options. Push the Adjust button to
highlight the 650mm (L) machine size.
Pushing the POWER button will lock the size
into the module’s memory.
GWL11 – Press and hold the WASH TEMP
Press the SPIN SPEED UP button (the HOLD
LED should be on.)
3. Press the POWER button to return to normal
operation.
Kelly
Mar 20, 2010 | Washing Machines
Washing Machines Logo
14 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
