Question about Microwave Ovens
I have a Whirlpool old model # RM278BXV-1'
I have a Whirlpool old model # RM278BXV-1. Everything is OK.
But it does not heat up water at all.
Please help.
Thanks,
Terry
  • 572 Answers
Ur magnetron is faulty
Posted on Feb 07, 2010
I have a Whirlpool old model # RM278BXV-3 and it has started shutting all the way down when heating things up. Contol panel goes blank and quits heating.
Sounds like the control panel. All the other parts are just brute force parts and either work or they don't. Over heating components on the control board are the probable cause.
Dec 30, 2014 | Whirlpool Microwave Ovens
Whirlpool microwave have power, not heating up food or water
The problem is most likely the magnetron, or the inverter board, "7years old or less" and possibily the keypad control board.
May 02, 2012 | Whirlpool Microwave Ovens
Whirlpool MH3184XP Microwave Turns On, Heats, but sounds like fans not working. 4 years old, fans worked fine until they seem not as loud anymore. The magnetron is working fine as it heats (did the 1 cup...
Suggest you pull the plug out, remove outer cover and place a cup of water into the micro. Set power to minimum then switch on and take note if the fan works or not. If not, switch off immediately and have it replaced(magnatron will burn out if left to run without fan.)
Sep 18, 2010 | Whirlpool MH3184XP Microwave Oven
Have an older model (RM278BXV) Whirlpool microwave
what is the problem with it im guessing it prob doesnt heat, if so prob need to get acess inside and check components i would recommend getting a service call as some componoents inside are still live even when unplugged,, it might require a magnetron which would be fairly expensive but if u dont wana replace it than i guess its your only option.. hope this helps
Feb 07, 2010 | Whirlpool GH4155XP Microwave Oven
Our whirlpool microwave does not heat. Everything
Hi!if your microwave does not heat, it only means that the magnetron is not working, try to look for busted fuse. or check the capacitor for leak, the hi voltage diode sometimes malfunction, and if all of the above mentioned are all ok maybe your magnetron is defective.
Sep 15, 2009 | Whirlpool GH4155XP Microwave Oven
Microwave turntable won't turn
Most likely the turntable motor itself is bad - not an uncommon problem for that model.
Check with www.martinmicrowave.com (toll free 1-877-894-0035)
unfortunately, the particular motor used in your model is rather expensive - + - $50
Dec 23, 2008 | Sharp R-930AK Convection/Microwave Oven
Re: microwave does not heat
Is very unlikely that there could be any other electrical failure since everything else seems to be working.
If you are able to fix it yourself then is way more cheaper just to buy the magnetron.
Click here to find the magnetron.
Before you do any work on this device, please click here to know how to discharge the high voltage capacitor and other safety concerns when working with devices that generate high voltages.
I would say is not worth it to spend more then $100.00 for a 5+ years old microwave.
Good Luck.
Jul 16, 2008 | Whirlpool MH6150XM Microwave Oven
Microwave ahs power but doesn't heat.
check the magnetron and related circuit and high voltage fuse and high voltage diodes, etc..
Sep 24, 2007 | Whirlpool GH4155XP Microwave Oven
Microwave Ovens Logo
110 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Microwave Oven Expert? Answer questions, earn points and help others
