Question about Saeco Royal Digital Plus Coffee Maker/Espresso Machine
How much decalcifier do I use. Doesn't say on the bottle. Thanks
Please advise how much decalcifier to use in this process.
  • 1,089 Answers
Hi Use 1 oz. for every 32oz of water. There is a program in your machine for descaling. Select it and open knob in front once you have the powder disolved. When you have finished go to the menu that says "reset descale" and choose "yes". Then set your water hardness in your menu to 4, and your machine will tell you when it needs to be descaled again.
Posted on Feb 07, 2010
Have a Rinnai XR26 . For a 2 person house and gas for water heating and cooking hob only, we use x1 45kg bottle of LPG every 3-4 weeks. 4 days of the week we are both away at work all day so it us just...
I'd really like to help you. But, you can not measure propane gas in kilograms. That's measure of weight, not liquid. The weight of the bottle, doesn't determine the liquid amount that the bottle or tank holds when it's 85% full.. Since Propane Gas is a liquid, I would need to know how many liters the bottle/ tank holds, to determine what your consumption is.
Please advise. Cheers...
Jun 26, 2011 | Heating & Cooling
Gaggia syncrony digital DECALCIFY, I done the prosess but i have the worning about DECALCIFY
You must use the correct tablets for this, gaggia make special decalcifying tablets.
The machine must be cold when running the program.
It takes about an hour to run the solution through the machine.
Please dont forget to vote this answer was helpful.
Many thanks
Mar 04, 2011 | Gaggia Syncrony Compact Digital Espresso...
On the screen it is written decalcifying.How do I fix this?
This is a pretty sophisticated coffee maker.. the manual goes into great detail about set up for entering water hardness and descaling messages. There is a discussion about the decalcifying procedure, but none the mentions a decalcifying message.
You should re-read the manual and possibly re-enter the programming again. The manual is available for free, here. Pay particular attention to sections 15, 16a, 20c and 22. These sections are only a paragraph long, but will help explain the filters, decalcify procedure and decalcification tablets.
Please rate this reply - thanks!
Dec 03, 2010 | Jura Capresso Impressa E8 Espresso/Coffee...
I don't have a manual and need to decalcify my saeco stratos. I know I have to buy a bottle of descaler. What do I do then?
Don't use vinegar or CLR or any chemical used in the bathroom. Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don't have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say "Descale finished". Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose "Yes" and push enter so the machine will tell you when you need to descale again.
Manual descale: To decalcify your boiler, remove your water tank and fill it with hot water (100 to 120 degrees). Open a pack of decalcifier and mix into the water tank. Place the tank back on the machine, then turn the machine on.
  1. If you have a non-rapid steam machine, just open the steam knob and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes. It is very important that the machine does not remain on to heat the boiler anymore than necessary.
  2. If you have a rapid steam machine, turn on the machine and then push the hot water button. This turns off the rapid steam and allows you to run hot water/solution through the steam wand. Just open the steam valve and run approximately eight ounces of solution into a spare container. Turn the machine off and let set about 10 to 15 minutes.
  3. Repeat step #2 for your type of machine. Do this until you have used the entire water tank of solution (approximately four to five cycles). Remove the water tank and rinse it with fresh water.
  4. Refill the water tank with fresh water and place it back on the machine.
  5. Repeat step #2 to rinse the machine, only this time use the entire water tank at one time, and there is not need to let it set.
  6. Your machine has been decalcified. You may still have scale in your boiler, but not as much as you had before. To reset your descale light, hold down on the steam button for at least five seconds. You are ready to brew, once your boiler has heated up.
Oct 29, 2010 | Saeco Stratos Coffee Maker, Espresso...
Descaling
Hi
There is a program in the menu to reset descale. Chose it and chose "yes". Rember to push the menu button to accept any change before you exit the menu.
May 22, 2010 | Saeco Royal Digital Plus Coffee...
How do i decalcifie my evolution espresso machine? my machine isnt producing any coffee. i have some decalcifier liquid but i'm not sure how to use it
The usual way is to put the solution into the tank at the required strentgh (usually on the packet/bottle) and run it through the machine as if you were making espresso. Once all the solution has gone through run three more tanks of fresh water through to clean it out.
Mar 14, 2010 | Gaggia Evolution Espresso Machine
Saeco decalcifying liquid
Use 1/3 of it in a full tank of water
Apr 05, 2008 | Saeco Trevi Digital Plus Espresso Machine...
Decalcify?
I had the same problem with a Saeco Royal Digital. I ran the decalcifying liquid through the machine with the automatic descaling program as per the instructions on the bottle and the DECALCIFY message stayed up.
I solved it by going to the menu and selecting "Signal Descal." and toggling it from No to Yes. I escaped back to the menu and git the usual "Select Product".
Hope this helps.
Nov 05, 2007 | Saeco Royal Professional Espresso Machine
Saeco Royal Digital Plus Coffee Maker/Espresso Machine Logo
280 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
