Question about KitchenAid KESC307 Electric Kitchen Range
Inner door glass replacement
In my Kitchenaid Superba stove the inner door glass, P.N 9781593 needs to be replaced(cracked). Tips on how are required.
  • Anonymous Mar 28, 2014
    Inner glass window, replace
  • 254 Answers
Open door fully, look down by hinges where enter unit, pull those metal tabs back that lock the door in place, close door to broil position 3/4 way closed and lift up, which should get the door off the unit.. once removed you would have to get acess inside that door by a combination on removing outer sccrews and hing screws and also seperating those glasses.....be careful to remeber how everything goes back i know of some techs that run into problems reassemblin those doors.. hope this helps,, some local service companies often charge a smaller in shop service call for small items like that if thats avaialable in your area,, hope this helps
Posted on Feb 07, 2010
Testimonial: "Thanks a million. Excellent!"
  • Earl-Sr Feb 07, 2010
    any rating?
Cracked inner oven glass window
Here is a tip that I wrote about the oven door glass replacement...
It is not that hard...
Range/Stove/ Oven Door Glass Replacement
heatman101
Jan 16, 2011 | KitchenAid Ovens
KEB5247 Kitchenaid built in electric double oven
Yes the inner door glass is a replaceable part and the door will have to be disasembled but not replaced. I can help with sourcing any parts for you since you used a premium post.
Jan 02, 2008 | KitchenAid KEBC277 Electric Double Oven
Interior door glass cracked on my KitchenAid oven
thers the inner most glass then some inner glass packs then the outer determine waht u need take ur model and go to sears.com go to there parts direct or parts research link lookup ur model find the part number and a normal price ........anyways u are gonna have to take the door off and replace it, kinda hard to describr just have to get acesss inside and replace the glass... might need service might be cheaper if u have a local repair shop for u to take the door off and bring it in to them... to get that dooor off most have lil flappers or metal locks open the door fully inspect down by the hinge pulll those flappers back towards glass then move door to brooil position 3/4 way closed and lift striaght up... hope this helps reply or rate me if posible k thanks
Jan 27, 2010 | KitchenAid KGST307 Gas Kitchen Range
Kitchenaide gas range inner door part number 9781721 is cracked.
To replace the door glass do the following:
1 remove the oven door by pulling it up and removing from the the hinges. If glass is broken , then secure glass with tape. Have a table with a cloth on top ready to lay the door.
2 Remove the outer screws , starting from lower side of the panel.
3Remove the inner screws. Keep all set of screws ordered, and take noteof the order you remove them. You will follow reverse order inreassembly.
4 the frame will be free now,
5 Remove the external glass panel and leave it in a safe place.
6 Replace the inner glass.
7 Clean outer glass and metal door, re-assemble it and mount it back
See diagram below , click on picture to enlarge:
Here the part Inner Door Glass
Mar 24, 2009 | KitchenAid KGST307 Gas Kitchen Range
INNER GLASS REPLACEMENT FOR KITCHENAID KEM308GSS0
I took it apprt removing the door according to manufacturers in structions and I found out it only needs a peice of glass, so I put it back together and put the door back for now and I ordered the glass from a parts supplier on the interenet after I dentifying the part online from an exploded Isometric assembly drawing on the vendors site. When it gets here I will install it. very simple a teenager could do it. The big question is why did it crack inthe first place?
Dec 11, 2008 | KitchenAid Architect® KEMS308S Electric...
The interior glass on the door shattered last night when I had the broiler on. Can the glass be replaced or do I need to replace the entire door. Kitchenaid Superba Model # KERC607HBS1 Serial #IMJ4544460
The inner glass is replaceable. The door will have to be removed from the range (see your user manual) and disassembled. Most repair shops can do the replacement for you at a nominal charge if you take the door in to them.
Jul 28, 2008 | KitchenAid Kitchen Ranges
Broken inner glass on kitchaid range how to remove the door
screws near the hinge, make sure to get oven/tempered glass sometimes the screws are located in the crack between the oven and door on the bottom
Jun 12, 2008 | KitchenAid KGST307 Gas Kitchen Range
Interior Range Window cracked - How to Replace
It is simple enough not to need a manual.
1- open the door, then pull outwards. The door mounts slide right out.
2- lay flat on a towel on the floor. Remove screws on the inside of the door.
3- remove each piece and layer of the door and glass panels. Set them aside in order so you know how it goes back together
4- replace broken inner glass panel
5- put each piece back together, install screws
6- slide door (mounts) back into their homes on the front of the range
It is surprisingly simple. All you need is a #2 Phillips screwdriver and a bit of patience.
Tip: make sure to clean each glass panel while you have the door apart. Use a razor blade for those stubborn burnt on stains.
Apr 06, 2008 | KitchenAid KGRT607 Gas Kitchen Range
Oven Door Inner Glass Replacement
can you gals get me the complete model # off the stove and i will look up the parts diagram & exploded view.
Nov 20, 2007 | KitchenAid KGST307 Gas Kitchen Range
KitchenAid KESC307 Electric Kitchen Range Logo
553 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Dan Webster
Dan Webster
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
