Question about HP Photosmart R927 Digital Camera
Is there a usb cable available that can attach my camera directly to my lap top to download pix, where do i get it
  • 15,935 Answers
CLICK HERE
Thanks!!
Posted on Feb 07, 2010
How do you move pictures and videos from the camera to a lap top
Either connect the camera with the supplied USB lead, or put the media card into a card reader attached to your computer
May 26, 2017 | Cameras
How do i print pics from a samsung TL 105 at a kiosk
Just connect the usb cable to your printer only hp or cannon photosmart printer will print your pix directly attaching usb cable select the pix and send to the printing options in main printer menue
Jun 11, 2014 | Samsung TL 105 Digital Camera
How to trasfer pictures from camera D60 Nikon to my lap top
Using the Camera
* 1 Attach the USB cable to the camera. Open the small, rubber door on the side of the camera body and plug the corresponding end of the USB cable into the slot on the camera.
* 2 Plug the USB end of the cable into the computer. Make sure the cable is securely attached to both the camera and the computer.
* 3 Turn the camera on. This will open software to download your images. You will be able to move the images from the camera to the computer and choose whether to remove the images from the card.
* 4 Select the option to download or transfer images. This will depend on what type of operating system you are running and may vary if you are running third-party image processing software, such as software that came with your camera.
Using a Card Reader
* 1 Turn the camera off and remove the memory card carefully.
* 2 Insert the card securely into the card reader slot.
* 3 If necessary, turn on the card reader. This will open the software to remove images from the card and place them onto your computer.
* 4 Select the option to download or transfer your images.
Apr 30, 2011 | Nikon D60 Digital Camera
Where on back of computer does cannon cable go. Have one end attached to camera. Son said attach other end to computer and follow instructions to download my pix and select ones I want.
Hi, your son are right only one end is conected to a computer USB connector,later you follow instructions or options to download the pictures to pc.
Greethings
Feb 20, 2011 | Canon Rebel XT / EOS 350D Digital Camera
How do you down load pictures to the computer from a olympus sp800uz
You must install special software that came with the camera to up load pictures to a computer with the cables that came with the camera. The detail is covered in the manual of which a copy can be down loaded from http://static.highspeedbackbone.net/pdf/olympus_SP-800UZ-Manual.pdf
A quick method of using the SD memory card in your camera to shoot pictures on, and then removing the card from the camera, plug it into a card reader attached to your computer. You also can insert the SD card directly into your printer if that printer has "PICT-BRIDGE". That means that the printer has a card reader built in. Many newer Lap Tops have a card reader built in. You may also attach a card reader by USB connection to your computer.
In any event all of the above are covered by the manual.
Jan 23, 2011 | Olympus SP800UZ Digital Camera
How do I view photos off the trail cam. None of my USB cables fit the trail cam to connect to my pc. I no longer have my lap top so am using the desk top which sucks!
If it is a D40/50,or earlier model you need a USB to MINI cable;if I40/M40 or newer you need a USB to MICRO cable...both available at Radio Shack.
Aug 09, 2010 | Moultrie GameSpy 4.0 Digital Camera Deluxe
I have put my cable in lap top and camera and photos dont upload
Use a card reader to download your pictures to a folder you create on your desktop.
Oct 12, 2009 | Casio EXILIM ZOOM EX-Z60 Digital Camera
Downloader says no pictures on the camera!
Computer does not recognize camera and unable to download pix???? It sounds like a bad usb cable connection. Try purchasing a new cable.
Jun 11, 2009 | Disney Pix Click Digital Camera
What should i do to get my pix on to my lap top.
do you have the camera turned on when it's hooked up to the USB? the camera has to be turned on, and sometimes in playback mode. (where you go to view the pictures)
also if all of that was done properly, you may need to download a driver for it. you can look it up online for the specific camera you have.
Hope that helps!
Feb 11, 2009 | Kodak EasyShare M853 Digital Camera
Disney Pix Max 3.0 Megapixel Camera by Digital Blue can't download photos
If you're plugging the camera into a port on the front of your computer try one of the ports on the back. The front ports in most cases only provide 100 milli-amps of power whereas the back ports provide the full 500 milli-amps of power. This could be the problem or it could be your USB cable. Try a different cable and see if that makes a difference. Just make sure that you aren't plugging it into a USB hub and you're connecting it directly to a port in your computer.
Mar 05, 2008 | Disney Pix Max Digital Camera
HP Photosmart R927 Digital Camera Logo
50 people viewed this question
Top HP Cameras Experts
Fred Sops
teddyboy
Lawrence Oravetz
Are you a HP Camera Expert? Answer questions, earn points and help others
