Will not spin 06 F code turns on drains ok then it starts to spin slowly and then stops.Tried to re start , move cloths around unplug re set F code comes up 06 number as well
06 fault codes indicates a tachometer motor fail. meaning the tachometer was not able to record the speed of the motor . check for wiring harnes at the tachometer, check for dirt on the tachometer itself. check also wiring from the motor control board to main control board.
When you try to start it do the lights dim way low, have you been able to start it with a jump from another vehicle, unfortunately, chances are the starter needs to be replaced. How many miles does it have?
Check motor capacitor first.Try moving the drum and see there is no extra friction. If your washer has got braking mechanism check the brakes also. ( I have no idea about this model regarding break)
It was suggested that the pump had failed and taken out the programmer with it - expensive! Wife wouldn't wait, and bought new machine. Problem almost solved - anyone want an out of order washing machine?
We unplugged the washer and left it unplugged for 5 minutes. This allowed the system to reset and finish the spin cycle. Now What?
