Question about Nikon D100 Digital Camera
My l100 samsung camera beeps three times when i push the power button and then wont come on? I tried to take the battery out and put it back in but that didnt help. i also took out the memory card but that didnt help either.
    President:
  • 942 Answers
Lens motor stalled.
Checkout the price of a repair at Samsung suppor.
Had this happen with the lens stuck in the retracted position. Rapped the camera on my palm to jostle the lens a bit, turned it on and back to normal.
Posted on Apr 03, 2010
2 Suggested Answers
  • 56 Answers
SOURCE: pushed the Format button on my L100 Samsung Digital camera and my memory card was erased??? Please explain this?
formatting the memory card automatically erases all the files in the memory card.
it's like restoring the memory card to factory settings to be compatible with your camera.
when you format the memory card using the camera the camera erases everything then creates folders that the camera needs to store pictures in your memory card.
you can try to look for software that can TRY to retrieve the images but i cannot assure you that this will work
Posted on Jul 02, 2009
Camera lens is stuck in out position, but screen is not on, beeps three times when i push the on/off button
This may help: connect the camera with the charging cord.
press and hold the ON/OFF button and the PLAY button.
(the one that allows you to see the pictures you just took).
hold them until the light on the charger cord starts flashing and then the screen turns on and the lens retracts.
Mar 16, 2017 | Samsung L100 Digital Camera
Samsung L100 camera, battery charger shows battery is fully charged, camera powers on, lens extends then immediately retracts and camera beeps three times
it sounds like a faulty battery try testing it with another battery and see if the problem persists if not then get a new battery,
let me know how it goes,
Jul 31, 2010 | Samsung L100 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
Samsung L100 digital camera beep problem
If the lens is retracted, hold up the camera to your eye and look at the lens. If you see one end sticking out a little bit, push that side in and press the power button. It should work.
If the lens isn't retracted, push the lens around until it is in its regular position. When you press the power button, it will retract and come out again and should work fine.
Hope this advice helps!
Aug 04, 2009 | Samsung L100 Digital Camera
My Samsung won't turn on :(
Try to move the lens a bit or straighten it out, that usually works when it makes the three beep sounds.
Jul 22, 2009 | Samsung L100 Digital Camera
My samsung L830 camera has jammed with the lens open and
Just had this happen to my L100. First, take out the battery and wait a couple hours for everything to cool down and discharge. Then place the battery back in. Then plug the USB cord into the camera and PC. Then turn the camera on and it should be okay. Just worked for mine.
Jul 15, 2009 | Samsung Digimax L830 Digital Camera
I have a samsung L100 digital camera. the battery had to be recharged but the lens cover only partially closed at the time that it shut down. I tried to recharge the battery, when I turn on the power...
The battery was tested and showed to be fine. The camera just malfunctioned during the shutdown. The used battery was put into a new camera and it's been fine.
Dec 25, 2008 | Samsung L100 Digital Camera
Samsung L100 Digital Camera Problem
right as the lens comes out very quickly remove the battery before the lens slides back inand beeps three times, wait a second put the battery back in and switch on obviously let the lens go back in and hay presto itshould work, it worked a treat for my L100, i hope this helps some of you but its obvious to us all our camera's are ****.
Oct 27, 2008 | Samsung L100 Digital Camera
It was the L100 and I'm sending it out for repair. Warranty is still valid. Thank you.
Sep 04, 2008 | Samsung Digimax L730 Digital Camera
Nikon D100 Digital Camera Logo
178 people viewed this question
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
