Question about Directed Electronics 1100f Ford Pats Securilock Data Remote Start Interface Module
Just changed out the ignition and the new ignition wont let the truck start what is the deal 2000 ford f150
    Sergeant:
  • 306 Answers
Is the theft light flashing when you try to start it?
Posted on Feb 07, 2010
2000 ford f150 Manuel trans. Code p0320 is it a expensive repair? Stutters while in gear 3/4 but doesn't stall. Just started a few days ago
P0320 means that an ignition pulse that's supposed to fire a spark plug was missed. It could be as simple as a chafed wire under the hood. Watch this video:
Ford has some information too:
P0320 2000 Ford F150 Ignition Distributor Engine Speed Input Circuit...
Oct 02, 2015 | Ford Cars & Trucks
1990 FORD F150; 351 WINDSOR 5.8 V8 ENGINE; HAS NEW DISTRIBUTOR COIL AND IGNITION CONTROL MODULE STILL WONT START
crankshaft position sensor is bad. it uses this sensor to tell the computer when to make each plug fire. no signal no fire.
Nov 21, 2013 | 1990 Ford F150
1990 ford f150 wont start
You may have a broken ingnition switch actuator in the tilt steering rack and pinion that moves the rod that actuates the inginition starter switch
May 21, 2013 | 1990 Ford F150
2000 Ford f150 the windows,radio & wipers don't work
sounds like your ignition switch under steering colum has gone bad autozone or dealer should have new one if this was helpful please leave me good feedback
Apr 12, 2013 | 2000 Ford F150 Flareside SuperCab
F150 ford truck 1990 key wont turn over engine new ign. switch
we have 1998 ford f15 we replaced the ignition and it still wont start the truck,, the key turns over now and the radio and everything comes on but it wont start, what is wrong???
Mar 18, 2010 | 1990 Ford F150
Hello im working on a ford f150 1992 the truck wont start i have been replaced the ignition coil because they dont have sparks y put the new ignition coil but stil dont have sparks wont start
check if your rotor in your distrbutor and contact points to your sparkwires in your distrrbuter are clean,and also check your selenoid on passenger side fenderwall,hope this helps
Mar 13, 2010 | 1992 Ford F150 SuperCab
1994 Ford F150 wont start, changed starter,solenoid and battery still wont start
1 Inspect Ignition Switch Improperly Connected or Faulty Ignition Switch. 2 Inspect Battery Battery Discharged or Faulty. 3 Inspect Battery Cable Coroded, Broken, Shorted or Poorly Connected Battery Cable. 4 Inspect Solenoid Switch Starter Solenoid Switch Faulty. 5 Inspect Starter Starter Motor Faulty. 6 Inspect Wireset Worn or Damaged Spark Plug Wires. 7 Inspect Coil -Ignition- Faulty Ignition Coil. 8 Inspect Distributor Cap Loose, Cracked or Worn Distributor Cap. 9 Inspect Spark Plug Incorrectly Gapped or Fouled Spark Plug(s). 10 Inspect Distributor Cap and Rotor Kit Loose, Cracked or Worn Distributor Cap. 11 Inspect Fuel Tank Fuel Tank Empty. 12 Inspect Carburetor Worn, Faulty or Damaged Carburetor. 13 Inspect Fuel Pump Faulty Fuel Pump.
Sep 03, 2009 | 1994 Ford F150 Styleside Supercab
Wont start or has problems starting
Chek fuel filter first, and replace if it hasn't been changed in a while. Then if it still has problems starting, check ignition module. Make sure all grounds are tight and making good contact as well.
Aug 19, 2009 | 1990 Ford F150
1997 ford f-150...no power to coil packs or fuel pump
hows the fuel pump?i just changed mine in a 2000 f150 with 130,000 miles
Apr 22, 2009 | 1997 Ford F150 Regular Cab
Ford 1995 F150 Truck. Turn ignition key off but Truck still runs
ignition switch electrical portoin above brake pedal on steering column
shack
Apr 14, 2009 | 2004 Ford F150
Directed Electronics 1100f Ford Pats Securilock Data Remote Start Interface Module Logo
316 people viewed this question
Top Directed Car Audio & Video Experts
Colin Stickland
Colin Stickland
Mark Skinner
Are you a Directed Car Audio and Video Expert? Answer questions, earn points and help others
