Washing machine shows contrl locked ,,,not able to clear this function or start up wahing machine what to do ?
  • 572 Answers
Un lock the pad. child lock safety feature
Posted on Feb 07, 2010
My Fagor innovation washing machine is currently disabled by the child lock symbol we did not apply this how can it be reversed
STARTING UP AND
6
BLOCK FUNCTION SELECTION
Start/pause button
a To start up the washing machine you
have to press the start/pause button.
The minutes remaining until the end of
washing and drying will appear on the
display at all times.
Block function selection
The lock function ensures that the programme
will not be affected if any buttons are pressed.
It is used when children could press the
buttons, etc.
The block function should be activated after
the wash programme has been selected
together with all its options.
Activating the block function
a The block function is activated by
pressing the start/pause button and
holding it down for at least 3 seconds.
The display will show if it is activated.
Deactivating the block function
b The block function is cancelled when
the wash programme comes to an end.
If you want to deactivate the block
function before the end of the
programme, you have to hold the start
button down again for at least 3 seconds.
After 3 seconds, the block function
indicator will disappear from the display,
and it will go into pause status.
The ON/OFF button does not cancel
the block function
Apr 14, 2015 | Fagor Washing Machines
I have a problem with a samsung wahing machine model WA95V3. No power coming on water solenoid valve when you switch on the push button,No error coming ,all the function is on.
you will find the solenoid is probably faulty and shorted out that part of the module, cheapest fix is to swap the hoses over at the taps and then select hot wash and cold water will come through the hot solenoid
Mar 08, 2014 | Samsung Wa95v3 7.5kg Washing Machine For...
Water does not drain automatically wahes and spin
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 04, 2011 | Washing Machines
All of my washing machine's "FUnction" buttons do
Change the program controler unit /the board if you need to get access to all the programs.
Remove the controller unit and make sure that the connectors are tight. Make sure the water level sensors , the door switch is working.
If there is no result the program controller is a suspect.
Jan 21, 2011 | Samsung SW62ASP Top Load Washer
When the lid is down the wahing machine does not start
go to REPAIRCLINIC.COM type in your model # and you can order from them
Jan 03, 2010 | Washing Machines
Contrl lock light on wont allow washer to turn on or chng setting
hello try pushing (options and select) hold both down for 5 seconds to see if this clears it
Dec 23, 2008 | Frigidaire GLTF2940ES Front Load Washer
All lights flash on front of wahing Machine, it tkes for ever to try and start the cycle. When it does start, all the lights continue to flash repeatedly. It does complete the cycle though. The washing...
Try first unplugging the power cord for thirty minutes.
If the error does not clear then it is probably a faulty control panel.
When the fault is on a different part (eg. pump, sensor etc.) you get an error code.
You can find the replacement control/timer assembly here.
If you need to call repair service you can use the number printed at the end of the owner manual.
Sep 13, 2008 | Washing Machines
Water supply
yes it is normal. It fills up during the washing proces
I had the same thought at first but it truns out ok.
Jun 08, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
197 people viewed this question
Top Washing Machines Experts
