Question about All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater
I 50,000-85,000 All Pro Propane heater release red button fireout
I Have A 50,000-85,000 All Pro Propane heater when red button is released fire goes out
  • 1,476 Answers
If the red button has to be held down for a period of time to get the heater going it overrides the shutoff mechanism. If you are holding it the prescibed amount of time then either the hydraulic system which keeps your unit running is bad or out of place or the metering valve is bad. Check for a copper line with a bulb on the end. It should probably be in the fire created by the heater, if not bend it to be in the heat or very close. If this is ok then you may need to get a new burner for the unit which would probably mean buying an entire new unit as the cost would probably exceed the cost of a new unit. Let me know how you make out.
hardrocko
Posted on Feb 07, 2010
Change thermocoupler on all pro 50000-85000 btu heater
If you have replaced the thermocoupler and it still wont stay lit then replace the gas valve.
Nov 18, 2014 | All-Pro Heating & Cooling
I have a spc-40 heater i can not get it to stay fired up i press the fuel button and it does lite but after 15 to 20 i release button and it goes out what do i need to do to make it work again
Ensure all your connections are tight and not leaking. I would shot off the tank using the valve on the top. Disconnect it, then re-connect it. Once connected, ensure the fan on the unit starts to turn. Then you can slowly open the valve, give it a good 4-5 turns to ensure it is open. They try the ignition sequence again.
Feb 28, 2011 | All-Pro Propane Garage Shop Heaters - All...
My all-pro propane heater will not stay lit for over thirty seconds after I release the red fuel start button,before the flame goes out it makes an air hissing noise right before it shuts off.Heater will...
This sounds like a problem with your thermocouple.
Just remove the end of the thermocouple from where is goes into the gas valve and leave the end that goes into the flame in place.
Clean the end of the thermocouple connect by scraping off just a little metal from the end just about there the nut tightens the thermocouple into the gas valve. After you have exposed some new metal do the same inside the valve where the thermocouple seats into the gas valve.
Use a small pic or similar item to scrape inside the gas valve to expose some new metal there also.
Now reassemble the thermocouple into the gas valve and see if the heater works.
Here is a link with some more instructions.
http://www.msservice.net/ts/reseat_thermo-clean_pilot-ODS.htm
If this does not solve the problem you may need a new thermocouple and you can find that at www.desaparts.com
Thanks
Jan 04, 2011 | All-Pro Propane Garage Shop Heaters - All...
When I push my red button in it shut off the fuel and wont stay going
this is caused by a bad thermo coupling. just to make sure that it is in fact bad - hold down the button for about 20 seconds while the heater is going and if after that amount of time the unit still shuts down when you release the fuel button - then replace the thermo coupling.
c...
Jan 03, 2011 | All-Pro Propane Garage Shop Heaters - All...
The heater wont start got power,got propane ,when i release the push in switch it wont start
YOU WILL NEED TO HOLD THE START BUTTON FOR ABOUT 2 MINUTES, ON YOUR FIRST START UP , TO GET THE FRESH GAS UP INTO THE UNIT
Dec 01, 2010 | All-Pro Propane Garage Shop Heaters - All...
Heater lights but goes out when button is released
if it is propane fired, I would replace the thermocouple first.
Jan 13, 2010 | Scheu (85-FAC) Heater
Heater won't stay lit after releasing yellow button
you need to replace the thermocouple at the burner tip it will be a copper line with a bulb in the flame tip with a copper tube leading back to the gas valve and it senses the flame and keeps the gas valve open
Dec 24, 2009 | All-Pro Propane Garage Shop Heaters - All...
All-Pro Propane Garage Shop Heaters - All Pro SPC 125 Forced Air Propane Space Heater Logo
1,167 people viewed this question
Top All-Pro Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
T bone 1963
Are you an All-Pro Heating and Cooling Expert? Answer questions, earn points and help others
