Question about Samsung HCN5527W 55" Rear Projection Television
Cant get the color adjusted to the right setting
There seems to be a glow around objects
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that you have to replace the convergence IC and check power resistor for leakage, if values are not exact you have to replace them. The typical cost to get this fixed by a pro is about $300 - and it doesn't mean that he/they will do a job better than you do. The parts are less than $100 (about $20-$30 for the IC's) if you want to do it yourself. Replacing only the IC's MAY solve the problem; however, many people have also had blown resistors requiring replacement. Why would you ask should you replace both of the IC's if only one is shot?! If one is shot the other one is not far away and for that little price of the chips it worth changing them both at the same time. Also the convergence board should be checked for cracked solder. If you replace the ICs and the resistors are shot, the ICs may blow again almost immediately, meaning you may have to do the repair twice. Please do rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Posted on Feb 10, 2010
The tv seems to be glowing, especially all the bright colors. Have adjusted brightness, sharpness, color and so forth and nothing seems to fix it. What can I do?
Your problem is the fluid in the 3 picture tubes needs to be replaced. All the older projection sets used this type of cooling for the tubes. After time and usage the fluid becomes contaminated and starts to turn brown and light cannot get through the crud and therefore you wind up with a dull picture. I recommend having a service company do this procedure. It is very detrimental to the printed circuit boards and components if you would spill and on them. Most shops charge around $250.00 to replace the fluid.
Jan 04, 2011 | Philips 60PP9202 60" Rear Projection...
Faded and bright
Dull Video...
Your set may have one or more of the following symptoms....
*Dull looking picture
*White looking picture
*Halos around objects
*Red/Orange looking picture
Convergence
* Screen Looks 3D, Warped, Distorted, etc
* Colors do not line up
* TV may shut off - and make a chirping sound.
bb0cf99.pngYou can see some more examples and find a fix using this link on Fixya http://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
May 17, 2010 | Philips 60PP9352 60" Rear Projection...
Cant adjust the color on the tv
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. This is called convergence.
When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired. Convergence problems are very common on all Projection TV sets including Sony, Samsung,JVC,Philip Magnavox,Panasonic,Akai,Pioneer, Hitachi,Mitsubishi,Zenith and others.
You can get more information and a DIY convergenece repair kit with instructions from the link below.
Here are some of the most common problems with these sets...
Problem #1) Convergence
Yours may have one or more of the following symptoms...
*Screen Looks 3-D
*Colors wont align
*Screen may look distorted or warped
*No Audio/Video - TV Shuts down - May also make a constant chirping sound
Problem #2 - Another common problem is dull or washed out video.
Apr 18, 2010 | Samsung HCM5525W 55" Rear Projection...
Sony KP-41T65 41" rear projection tv with convergence issues on part of the screen. And screen is generally slightly blurry. I received this TV already broken (had the red blinking light issue) which I...
These sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the picture to look normal. When its out of alignment the video will look 3-D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
Convergence problems are very common on all Projection TV sets including Sony,Samsung, JVC, Philip Magnavox, Panasonic, Akai, Pioneer, Hitachi, Zenith, and others. You can get a convergenece repair kit wiith instructions from the links below.
  • Screen Looks 3-D
  • Colors wont align
  • Screen may look distorted or warped
  • No Audio/Video - makes a chirping sound.
Problem #2
Your TV may have one or more of the following symptoms....
  • Dull looking picture
  • White looking picture
  • Halos around objects
  • Red/Orange looking picture
You can see some more examples and find a fix here
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Apr 03, 2010 | Sony KP-41T65 41" Rear Projection...
My tv ,whites glow way too bright,dark colors way to dark,what is wrong
These sets have several common problems listed below.
Symptoms:
  • Screen Looks Distorted/3D
  • Colors wont align
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking screen
  • White looking sceen
You can see some examples and find a fix here...
Feb 08, 2010 | Philips 60P8342 60" Rear Projection...
White glow around dark objects
This is a common problem. Its called a convergence failure.
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Video may look distorted
  • Dull looking video
  • White looking video
  • Red/Orange looking video
Jan 28, 2010 | Philips 55PW9383 55" Rear Projection...
White halo fuzzes the picture on TV
Had the same problem with white glows. Followed the directions in this link and the white glows and color brilliance was fixed.
http://www.avsforum.com/avs-vb/showthread.php?t=1148792
Apr 07, 2009 | Mitsubishi WS-65809 65" Rear Projection...
It has a slight green hint & a white glow around people
Your TV most likely has one or more possible problems.
Problem #1: Convergence Chip Failure ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
2c07611.pngSolution #1
You need to replace the convergence chips and convergence resistors. Check the site www.TvRepairKits.com. They have put together a kits for most models. If you don't see a kit for your set send them a quick note and they will put one together for you. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, etc.
Problem #2 CRT Fluid is Cloudy
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
Picture of a set that needs the fluid changed.
TV set after fluid change
2c07611.pngSolution #2
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Apr 07, 2009 | Philips Magnavox 9P6034C 60" Rear...
Sony KP-51WS510 has a haze or back glow that cant be adjusted
It seems U are having no screen voltage.
U need to get it repaired
Rifaa
Nov 10, 2008 | Sony KP-51WS510 51" Rear Projection...
Lately, all "white" objects, text, spaceships, etc. have "glows"
Do you also have a glow around the projected image, try projecting on a white wall without any borders. The cause for this is dirt inside the lens elements diffusing the light.
Oct 22, 2007 | InFocus ScreenPlay 4805 Multimedia...
Samsung HCN5527W 55" Rear Projection Television Logo
44 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
