Question about Samsung SL30 Digital Camera
Okay i got pepsi in my camera, so now when i put batteries in the green light turnson and stays on but nothing is displayed on the lcd.
    Brigadier General:
  • 3,006 Answers
There is nothing you can do. You've just got a sugary acidic liquid into your camera which has presumably partially dried by now.
Even if you could remove the sugar residues (difficult:you'd have to soak parts the camera in distilled water) there will still be residual damage caused by carbonic acid, and this will continue to corrode the camera circuitry for months. If you've used a sugar-free Pepsi variety, then there will be no sugar residue but the acid will still be present.
Sorry, but your camera is a write-off. Even a professional repairer would refuse to attempt fixing your camera: the cost would exceed the camera's value and the ongoing internal corrosion would make it likely what you'd soon return for warranty work which would make no money for the repairer.
There's only one thing you can try. Soak it it Coca-Cola...'Cos "Coca-Cola Adds Life".
That last bit WAS a joke...
Posted on Feb 07, 2010
Fault finding
The green LED is called the memory acces lamp. When you switch off the camera is will write back the last changes. when you switch the camera on and off, the light ususaly will stay off, because nothing has changed. When you remove the card en put in another the LED will flash again. At least my D7000 with 2 card slots will do so, because someting changed and the system will write that into the memory.
Aug 21, 2013 | Nikon D90 Digital Camera with 18-105mm...
The green light blinks on and off again
Are your batteries fully charged ? is the LCD screen on ? Does the camera stay on or shut itself off ?
Jan 26, 2013 | Fuji FinePix A345 Digital Camera
I hit the power button and it turns green for a second but then goes out. The camera and LCD screen do nothing. So I have some sort of power problem. When I put the battery in the charger the charger light...
theres no choice your battery charger is may be out and try new battery and try the power cable from the charger and connect directly to the cam if you got the original power pack/ for the green screen it can go green or bleu when the battery go low, some time that is the video processor ic...
i hope for you it just the battery....
and good luck
May 13, 2010 | Sony Cyber-shot DSC-W120 Digital Camera
My DSC-F505V powers up but screen stays dark, nothing happens. with battery and a/c adapter. Thank You
The problem is well known for this model of Sony DSC-F505V. The circuit board behind the display is the problem. Its replacement code is SY-62. As symptoms, sometimes the camera start but next time stays with the display black and the green light on. Cheers
Feb 25, 2010 | Sony Cyber-Shot DSC-F505V Digital Camera
My lcd monitor lights in green but does not display
That is definitely not normal. Try a different monitor on the computer and if you get video on the new monitor then you know your original monitor is bad for sure.
Sounds to me like its a problem with the lcd or the inverter. You might want to try and take apart the monitor and reseat both ends of the LCD cable. If that doesn't help then the monitor is faulty and you'll have to get another one.
May 12, 2009 | BenQ FP71G 17" LCD Monitor
At power up tv displays Acer logo then goes to black
will not turn off power with out unplugin it
Mar 01, 2009 | Televison & Video
No display, green light stays on
Hi , try to re insert the correct position the sd card might invert .
Jan 31, 2008 | Vivitar ViviCam 5100 Digital Camera
My camera has a black screen even when is on
It does not look good.
Here are some problems which could be with this camera:
LCD broken or bad.
CCD problem.
Since you go have some light on the green light, then that appears to be a LCD problem. this can happen if the camera had an impact to cause the LCD to be damaged or disconnected in some way.
For further help:
Go to:
http://vivitar.com/en-us/Support.aspx
Ask for your model.
Sep 18, 2007 | Vivitar ViviCam 5100 Digital Camera
Samsung SL30 Digital Camera Logo
107 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Samsung Camera Expert? Answer questions, earn points and help others
