Question about Plantronics Explorer 220 Bluetooth Headset Wireless Headset
I want to place my 220 Plantronics in discovery mode
  • 110 Answers
Try pressing the power button and holding till the light stays on. This should be the discovery mode.
Posted on Feb 07, 2010
My headset the light is solid blue and will not work
It sounds like the headset is already connected to a device. Try holding down the center control button to put it back into discovery mode and then use your phone or device to locate the headset. The link for the manual is: http://www.plantronics.com/media/media_resources/literature/user_guides/explorer220_ug_en_es_fr_pt.pdf
Jul 23, 2011 | Plantronics Explorer 220 Bluetooth Headset...
My iPhone 4 bluetooth won't discover the plantronics 220 Bluetooth earpiece for pairing. Both devices are on including bluetooth on my phone
On your phone, make sure bluetooth is turned on (settings, general).
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode ***(usually you have to hold the power button for 7-10 seconds)***
Your phone will find the device, and you will be prompted to enter the devises PIN number (often 0-0-0-0). Your phone should pair with the device then.
Dec 31, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I am having a hard time pairing my Plantronics 233 with my Iphone 4...it has been saying "searching" for 10 minutes, but it is not finding my device.
While your phone is in discovery mode, turn your bluetooth device on and put it in discovery mode (usually you have to hold the power button for 7-10 seconds).
Dec 17, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Can you say if Plantronics 220 is compatible to work with blackberry 9630?
Hold down round button on earbud for 5-6 seconds until it flashes alternating red and blue. Then set your device (Phone/PDa) up for connectivity by allowing it to be discovered...Once your phone is in discovery mode, it will search and hpefully find the earbud.
Jun 20, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Trying to pair my HTC EVO to plantronics explorer 233 Bluetooth headset
Had the same problem and called Plantronics. They reminded me about putting the earpiece in "Discovery Mode" by holding down the button when turning it on until it flashes blue/red. Then have the EVO scan for bluetooth devices. It found mine right away.
Jul 01, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How do i get my plantronic 220 in discovery mode
Hi,here is a detailed solution on how to set your plantronic headset into the discovery mode;
STEP 1 You have to firstly put off the headset,by holding the call control button,which is the button on the face of the bluetooth,until the blue light turns red,as soon as the blue light turns red release the button.
STEP 2 After putting off the headset,wait for like 5 secs to ensure its completely off.when the device is off,you can now press and hold on the call control button for 5secs if its the first initial pairing,if it's not,then you have to hold on the call control button for 8seconds,afterwards the light should flash red then blue in both cases
STEP 3 At this point in time your headset is in discovery mode,and you have 60 seconds to pair it with your phone which should also be in the pairing mode as well.
Your plantronics headset and your phone are matched up and you are good to go.
Thanks and take care
Apr 22, 2010 | Plantronics Explorer 220 Bluetooth Headset...
Setting the discovery mode
The user manual is here http://www.plantronics.com/media/media_resources/literature/user_guides/explorer320_userguide_en.pdf
Press the button for at least 3 secs to getinto discovery mode Pairing and connecting Please note: You can only enter pairing mode from off position. Bluetooth® device must be in discoverable mode. Light Indicator flashes blue and red
Apr 15, 2010 | Plantronics Explorer 320 Wireless Headset
How do I put a Plantronics Explorer 232 in paring mode so I can connect it o a cell phone
Hold it in for three seconds or more to flash purple and enter discovery mode.
Once it's paired it will flash blue.
Default code is 0000.
Feb 22, 2010 | Plantronics Explorer 220 Bluetooth Headset...
How do I place my earpiece into discovery mode.
To place the plantronics in the pairing mode, simutaneously press the volume up (+) button and the Call Control button - for about 2 seconds.
Pairing mode is confirmed by LED flashing Red then blue.
You have a minute to pair it with your device.
Oct 13, 2009 | Plantronics - Bluetooth Headset Plus Base...
How to turn my plantronic explorer 220 on discover mode
  • TO SET IT ON DISCOVERY MODE YOU HAVE TO START WITH IT OFF. YOU CAN TURN IT OFF BY HOLDING DOWN THE CALL CONTROL BUTTON- THAT'S THE BIG ONE ON THE FACE OF YOUR BLUETOOTH, UNTIL THE BLUE LIGHT TURNS RED. RELEASE THE BUTTON AS SOON AS YOU SEE IT TURN RED. iT SHOULD BE OFF, YOU CAN WAIT A SECOND OR TWO TO SEE IF IT FLASHES BLUE AGAIN, IF IT DOES JUST HOLD DOWN THE CALL BUTTON AGAIN TIL RED THEN QUIT. ok IT'S OFF, SO WITH IT OFF YOU PRESS AND HOLD DOWN THE CALL CONTROL BUTTON 5 SECONDS IF IT IS THE FIRST TIME PAIRING. iF IT IS NOT THE FIRST TIME YOU HAVE TO HOLD IT DOWN FOR EIGHT SECONDS AND IN BOTH CASES THE LIGHTS SHOULD FLASH RED THEN BLUE( OR VISE VERSA.) BACK AND FORTH. aT THAT TIME IT IS IN DISCOVERY MODE AND YOU HAVE LIKE 60 SECONDS TO SET YOUR PHONE ON DISCOVERY AND MATCH THEM UP. i JUST WENT THRU THIS ABOUT 20 MINUTES AGO, i FOUND THAT EXPLINATION ON pLANTRONICS WEBSITE FOR MY MODEL, 220.
Jan 04, 2009 | Plantronics Explorer 220 Bluetooth Headset...
Plantronics Explorer 220 Bluetooth Headset Wireless Headset Logo
119 people viewed this question
Top Plantronics Radio Communications Experts
LeAnna Mathews
LeAnna Mathews
Level 1 Expert
shaun taylor
Michael Vincent Cruz
Are you a Plantronics Radio Communication Expert? Answer questions, earn points and help others
