Washing machines fill with water afterwash leaving clothes soaked
I have a washing machine that has been working fine up untill other day i open the drum draw and water poored everywere and the clothes were mopping wet .. when the washing machine stops after a wash u can remove the clothes and there be no extra water but if you leave it 4 mins + after wash it will just fill up with water and the softner has not been flushing out of the draw properly but the washing powder flushes out with no problem...
  • emmaobrie75 Feb 08, 2010
    and what should i do?
  • 42 Answers
Hi Emma,
Thats two problems......the first with your softener drawer, because of the nature of softener it congeals much more quickley than washing powder therefore the softener drawer needs to be cleaned more regular. Pay particular attention to the pinhole escape at the far end of the drawer. The second problem is most likely one of your inlet valves is faulty and needs to be replaced.
Regards
Posted on Feb 16, 2010
  • 572 Answers
Ur valve is bad
Posted on Feb 07, 2010
How to fix NEC NW-961 6kg
Good to know the washer is working fine.
You may also benefit from running the washer empty with a cleaning agent like this
http://www.rubbedin.com.au/Product/17/The-Magic-Range/Washing-Machine-Cleaner-
Apr 27, 2014 | Washing Machines
Ge washing machine fills up with water on spin cycle
Sounds like the timer is screwed... Sending out the wrong signals and the dryer is doing the rinse cycle when it should just be the spin cycle. Do t know what your timer looks like in that washer but most now days look like the picture. 11_11_2013_2_52_52_am.png
Aug 16, 2013 | Washing Machines
My 12 year old AEG OKO LAVAMAT is making a grinding sound when it fills. It's fine at all other times. I've tried cleaning out the filter, and running it empty.
This is usually caused by the recycling pump running empty whilst the washing is still soaking up the initial fill water. as the water begins to soak the clothes it then starts to pass through the drum into the pump and the whole thing quietens down. running empty will not work. to test this theory try opening the drawer very slightly and filling it manually with a hose before starting the machine, (ONLY TO THE NORMAL LEVEL) and see if the noise is still as bad.
Feb 09, 2013 | AEG Washing Machines
New washer, seems to work fine. I just question the water filling sequence at start of a wash. The water valve opens in 1 sec spurts about 6 times when drum is rotating in one direction. On 7th time it...
Every few months, new things are done to improve washing methods. If washing machine is washing clothing cleanly, and no apparant fault code comes up, then it is how the controller is programmed and meant to be.
Aug 14, 2010 | LG Washing Machines
Leaves white marks on coloured clothes
I'd try putting the machine on a hot fill wash, max water level put in half a cup of baking soda when the machine starts to washer turn it off and leave it to soak overnight, then let it finish the cycle the next day. Also make sure you tip some of the hot water down the beach dispenser and clean all around the top of the machine
Cheers
Mar 25, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirpool Duet Was. WFW9400SZ01--Spin cycle leaves clothes soaked.
the problem is your spin program is normal but the machine could not do its job usually there is broken pin clucth under the spinning tube and sometimes the spin gear.this is due to overlload problem. you should brought the machine to your trusted machine repairer as this cost you around US 100-200 in comparison if you buy new one
Sep 25, 2017 | Whirlpool Washing Machines
Kenmore elite calipso was motion
calyso is a low water use machine similar to front loads only enough water enters machine to get clothes soaking wet water is recirculated through tube on back right corner of tub to insure clothes are soaked if pressure switch determines minum water level not reached it will add more
Apr 26, 2008 | Whirlpool Calypso GVW9959K Top Load Washer
Smartdrive 703 Model Washing Machine Leaving brown stains in clothing after some wash cycles. Stains are small and seem to be something coming through to the clothess from the slits in the drum holes. ...
if you do cold washs all the time you get a build up of sludge between the drums you need to fill it with hot water and let it soak for a few hours and then put through a high wash to rinse out,no clothes.Or you can remove the drum and wash it .hope this helps
Mar 14, 2008 | Washing Machines
Washing Machines Logo
85 people viewed this question
Top Washing Machines Experts
