Question about GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator
GSS25JERFWW ge refrig makes a whirring noise that is driving me crazy.. noise appears to be coming from the freezer sid. i was told by a neighbor it could be 'evaporator fan motor'
  • 311 Answers
Yes its possible you could have a bad evap fan motor bearings. Its part# wr60x10185 and will cost you about 60 bucks. This particular fan motor is not the easiest to replace. You will have to remove the back panel of the freezer and possibly the auger motor. I cant tell by looking at the image but I do know that this particular fan motor depending on the model can be a real pain. It can be done but may take you some time. If you remove the back panel and look up you will see the fan motor. It will be held in 2 screws on the bracket and will come with a new thermistor.
Hope this helps _MJ_
Posted on Feb 07, 2010
GE Profile Artica no display
I would inspect the wires that are located at the bottom left freezer hinge, opening and closing tends to break the wires over time. crimp the broken wires into a sleeve type connector, there will be little to no slack to use wire nuts. If the wires are perfect, you might need a new display board, but the wires are the prime suspect...
May 02, 2016 | GE Profile PSI23SGR Arctica¿...
Ge profile side by side 2005 psh25pswass small amnt of water on inside of refrig on the bottom of refrig floor on side next to freezer. vents in refrig appear to be bringing in very humid air that is
It can have an air leak, but also a clogged drain pan under the freezer evaporator coil. If the refrigerator is getting warm, then it may be another issue
Dec 17, 2014 | GE Refrigerators
Hotpoint G/E Side by side refrigerator Model
I have seen this issues with GE and HotPoints. I recorded video for You. Hope this will help. I replace usually both : main board and evaporator fan motor.
Nov 24, 2010 | Hotpoint HSM25GFRSA
My GE Fridge PSS26SGRD has a moaning howling
The fan is hitting on ice buildup...unit is not defrosting...
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 12, 2010 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer Humming. Making me Crazy.
the fan motor is probably going bad.its about a $50.00 part and its behind the back wall,grab the model number and go to an appliance parts store and order or pick one up.
Apr 25, 2009 | GE GSH25JFR Side by Side Refrigerator
My GE side by side refridgerator makes a "howling" sound. Any ideas?
the problem you are having is in the main control board. ge has had a problem with this part causing the fan motor to go into high and low speed which causes the howling noise. unfortunately it is a costly fix, around $125 for the part. if you are savy to changing this part it is a matter of unplgging about 5 connections and replugging them. the new board has an extra set of pin that nothing connects to. READ the instuctions and it is a simple fix, saving about $50-60 in labor costs.
Sep 08, 2008 | GE GSH22SGRSS Side by Side Refrigerator
GE refrig model PSH23SGPABS
The main board needs to be replaced.
May 05, 2008 | GE Refrigerators
GE SidexSide PSS26SGPASS Makes Humming Noise
GE refrigs have a variable speed evaporator fan motor that is controlled by a computer board on the back of the refrig. now the noise you are hearing is most likely the fan motor ramping up and down in speed (some of my customers say it sounds like a ghost). if its a continuous ramping up and down then the speed cotroller on the board is bad and must be replaced. if its just an occasional sound then thats normal and nothing to worry over.
Btw the reason the noise stops when the door opens is because the fan shuts off when you open the door.
Dec 19, 2007 | GE (PSS26MSRSS) Side by Side Refrigerator
Ge fridge
you have 2 fans one underneath by compressor ,one in freezer make sure one in freezer is running
Dec 14, 2007 | GE GDS20SBS Stainless Steel Bottom Freezer...
Freezer
I have a GSL25JFPH BS refrigerator by GE. It made the whirring sound, a repairman came out and told me that the fan motor needed replacing, price of $277. I sent him away, and after a few minutes on the internet, saw on this site that a new circuitboard (part# WR55X10656) should fix it. I found it on ebay for $83, and it took about fifteen minutes to install. No more whirring!!
Oct 31, 2007 | GE GSL25JFPBS Side by Side Refrigerator
GE GSS25JFPCC / GSS25JFPWW Side by Side Refrigerator Logo
226 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
