Question about Apple 20gb Ipod Mp3 Player With Click Wheel System
Apple 3rd generation 20gb ipod wont come on
My ipod turns on then shows apple logo, then shows, fire wire logo then turns off, also is not reconized by computer help !!!!!!
PyroPCMan
  • 405 Answers
SOURCE: apple ipod 20gb
Try a reset:
How to reset iPod To reset an iPod with a Click Wheel, including:iPod nano (3rd generation) iPod classic iPod (5th generation) iPod nano (2nd generation)iPod nano iPod with color display (iPod photo) iPod (Click Wheel) iPod mini iPod mini (2nd generation)
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds.
You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
If the above steps did not work, try connecting iPod to a power adapter and plug the power adapter into an electrical outlet, or connect iPod to your computer. Make sure the computer is turned on and isn't set to go to sleep.
To reset iPod, iPod (scroll wheel), iPod (touch wheel), and iPod (dock connector)Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)Press and hold the Play/Pause and Menu buttons simultaneously until the Apple/iPod logo appears, about 6 to 8 seconds. You may need to repeat this step.
If you are still unable to reset your iPod, use only one finger from one hand to press the Center (Select) button, and one finger from the other hand to press the Menu button.When you reset iPod all your music and files are saved, but some customized settings may be lost. Date and time is preserved (unless the iPod reset itself because it had no power and then was reconnected to power). Other customized settings, such as Bookmarks, On-The-Go Playlists, Shuffle, Backlight timer, and so forth are preserved from the last time the hard drive turned on.
Hope this helps
check out my blog at:
http://www.pchelpforanyone.blogspot.com
Posted on Apr 03, 2008
  • 11 Answers
SOURCE: Ipod won't turn on 3rd generation silver
Has the battery been charged lately? If not, try charging it first and then try to turn it on. If that is not the case your ipod probably just needs to be reset. Try pressing the center button with the menu button together and hold those two buttons together for about 6-10 seconds. You should get an apple icon that comes on before you will see your menu for your applications.
Posted on May 18, 2008
uge44
  • 226 Answers
SOURCE: my ipod says www.apple.com/support/ipod
95% of the time, when you get the sad face or now on the new 6th generation classics and 3rd and 4th generation nanos it's a cross, it means that you have a faulty hard drive. You can buy hard drives for reasonable prices on ebay. You'll be looking for a Toshiba MK8010GAH if you're using a 5th generation iPod video, and if you're on the 6th generation classic you'll be looking for either a Toshiba MK8022GAA or a Samsung HS081HA. The Samsung's are more reliable.
Posted on Nov 20, 2008
  • 15 Answers
SOURCE: Ipod 3rd Generation
Test the hard drive by holding menu+centre to reset and immediatly holding left+centre when it reboots to enter the ipod diagnostic menu. Use the right arrow to highlight the Memory or HDD menu. Select it and you should be able to find out if the drive is dead.
If the drive is ok, try restoring the ipod through itunes.
Post back here if the drive is wrecked.
Posted on Feb 06, 2009
mneilsen2084
  • 342 Answers
SOURCE: Apple iPod Nano 3rd gen won't turn on nor charge
If you guys still have this issue, I would strongly recommend going to the following web site:
http://fixyouripod.weebly.com/
There is an instructional video on your exact issue. :) good luck. I hope it's not too late for your iPod's
Posted on May 14, 2009
3rd generation wont turn on
Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.) Press and hold the Menu and Center (Select) buttons simultaneously until the Apple logo appears, about 6 to 8 seconds. You may need to repeat this step. Tip: If you are having difficulty resetting your iPod, set it on a flat surface. Make sure the finger pressing the Select button is not touching any part of the click wheel. Also make sure that you are pressing the Menu button toward the outside of the click wheel, and not near the center.
Hope this helps :)
Apr 25, 2009 | Apple iPod nano 3rd Generation
Ipod 3rd Generation
Jan 25, 2009 | Apple 20gb Ipod Mp3 Player With Click...
My ipod says www.apple.com/support/ipod When I hit menu the apple logo appears and then is replaced by the X and the apple support message but is not reconized by itunes. Help
Nov 17, 2008 | Apple iPod MA446LL/A MP3 Player
Ipod
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
Jul 23, 2008 | Apple iPod nano 3rd Generation
IPOD NANO 3RD GENERATION
take the palm of your hand and click all the buttons at once and it should come on. sometimes it will show dead batterey. if so just do that 'till it does show the apple logo
May 17, 2008 | Apple iPod MP3 Player
Apple ipod 20gb
Try a reset:
Hope this helps
Apr 03, 2008 | Apple iPod nano
Reset 3rd gen ipod?
Toggle the Hold switch on and off. (Set it to Hold, then turn it off again)
Press and hold the Play/Pause and Menu buttons until the Apple/iPod logo appears
Nov 02, 2007 | Apple iPod 3rd generation MP3 Player
Apple 20gb Ipod Mp3 Player With Click Wheel System Logo
59 people viewed this question
Top Apple Audio Players & Recorders Experts
Sean Cole
Sean Cole
TO Lady
Are you an Apple Audio Player and Recorder Expert? Answer questions, earn points and help others
