Replacing fluid in the magnavox projection tvs
Why is my screen red when it should be black?
Search Results
    Philips Magnavox 8p6031c Crt Lens Fluid Repair Questions ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/page-11
    Recent Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & answers. Free expert ... Philips flat screen tv, Red flashing light. Light.
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Repair ...
    www.fixya.com/...philips_magnavox_8p6031c_crt_lens_fluid/popular
    Popular Philips Magnavox 8p6031c Crt Lens Fluid Kit Dull Video Fix questions, problems & fixes. ... My son accidentally spilled water on our Philips tv and when i turned it on ... I need a screen replacement of philips tv 60" ... Why the tv come on but a min after the red blinking come on an it turn off by it self what the problem?
    Magnavox Projection TV problem... ' Techlore
    www.techlore.com/forum/thread/.../magnavox-projection-tv-problem
Jan 13, 2016 | Philips Magnavox 8p6031c Crt Lens Fluid...
I have model #115298-0001 Series #12333264. I need to find replacement screen if available. Also if you have te protective covering.
Sorry,this is not possible,tvs pictures screens panels are 90% important to the tvs itself.If it still available,tvs pictures screens panels replacement,will cost u the same as a new tvs.Because tvs pictures screens panels are limited in productions buy the tvs corporations.But these tvs technologies are opsolete and no longer in the tvs markets by the tvs corporations have stop these tvs productions.
Nov 22, 2010 | Philips Magnavox 9P6034C 60" Rear...
Numbers and letters look blurry
rear projection tvs have coolant to cool pix tubes which goes bad in the blue and green tubes.to verrify-remove front of tv-outer edge unclips-take out screws arround screen-carefully remove screen-now turn tv on look down into blue/green tubes--pix is bad--blue is so bad you cant even see the pix.you can call a local shop-get quote to replace fluid--if its too much and you are mechanically inclined email us-we will let you how to do it for free-hope i helped you djstvrepair@comcast.net
Sep 16, 2009 | Philips Magnavox 51MP392H Rear Projection...
Picture not as sharp as it used to be
Replace the coolant in the CRts very common problem with Phillips / Magnavox Tvs.
Sep 06, 2009 | Philips Magnavox 51MP392H Rear Projection...
Magnavox projection tv model 8P6044 C102 is very
The CRT fluid is cloudy and should be replaced. Goto www.TvRepairKits.com. They have a kit to do it yourself.
Ed
Jun 21, 2009 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
60" Projection Tv - Approx 6 yrs old
Your CRT fluid needs to be replaced. After many years the crt cooling fluid gets a ton of alage built up in the tubes.  This will cause the screen to get a halo effect or get darker.
You only need to replace the fluid in the blue and green tubes.
Dec 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Magnavox 55" projection Television. Picture not as sharp as used to be. Lenses and screen have been cleaned picture still not clear...
You need to change the coolant in the CRTs. Its a common problem with phillips/magnavox TVs. You can get the coolant replacement kit at the following link with all the coolant and the step by step instructions with pictures on CD. Its listed under the repair kits. magnavox and phillips are the same TVs. here is the link.
http://servicemanuals.vstore.ca/
Aug 06, 2008 | Televison & Video
Changing fluid in CRT's
You can go to the following site, under the repair kit catagory they have a CD that documents the step by step proceedure for coolant change in phillips / magnavox tvs with pictures. They also have the entire kit with 48 ounces of high purity coolant and the cd
Heres the link.
Jul 11, 2008 | Televison & Video
Adjusting colors on a magnavox 46" projection TV
Replace the CRT fluid. It grows algea in the blue and green only. 9.99 from MCM electronics.
Oct 19, 2007 | Philips 46PP9302 46" Rear Projection...
Picture tube fluid
Magnavox are good at fluid breaking down especially blue and sometimes red. Yes you would have to be very carefull not to waste on boards, because of set CRT's are tilt this mean when you open it will start to leak. The best bet if you are willing to try yourself is to prop up set somehow to make crt's level and when you take lense off you can look underneath and open the bottom lense cover up and expose the old crt fluid and then you will need some type of suction pump to suck out the old fluid. Once you have old fluid out then you can clean inside crt and make sure you clean good. Then replace with new fluid and go in reverse and clean all that touches crt. Hope this helps!
Sep 14, 2007 | Philips Magnavox 51MP392H Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
