Question about Janome 6019QC Mechanical Sewing Machine
Is it necessary to take all the parts apart as shown in the handbook, or are there any shortcuts. I have used the machine for 2 winters..but not much otherwise. Can I use a vacuum cleaner attachement covered by a piece of fabric to get most of the lint/dust out? Also, any need to oil anything. one quilt shop mentioned putting some oil on the "wick" located near the bobbbin holder?? Thanks, Pat
  • ssrpearl Feb 07, 2010
    I am referring to a Janome 6600.
  • 25 Answers
There are no shortcuts to cleaning your machine.when you take the needle plate off you need to take the bobbin out as there is always bits of fluff and cotton under the bobbincase which needs to be cleaned out. Put a little oil on a soft cloth and wipe the inside of the bobbin case. you shouldn't need to oil anything else as the mechanic will do that when you have it serviced.Which needs to be done regularly if you use it a lot.
Posted on Feb 11, 2010
I am looking for a Free owner manual for a brother lock 925D serger
handbook for compact overlock machine manual de ... - Brother USA
www.brother-usa.com/.../en-US%5CHAD%5CConsumer%5CUsers...
Translate this page
Do not allow to be used as a toy. Close attention is necessary when the sewing machine is used by or near children. 2. Use this sewing machine only for its intended use as described in this manual. Use only accessories recommended by the manufacturer as contained in this manual. 3. Never operate this sewing machine ...
[PDF]Instruction Manual - Brother USA
https://www.brother-usa.com/.../Users%20Manual/UM_PL_2100_EN_238.PDF INSTRUCTION. BOOK FOR SERGER ... Use this sewing machine only for its intended use as described in this manual. Use only accessories recommended by the manufacturer as contained in this manual. 3. Never operate this ... THIS COMPACT OVERLOCK. Your machine is a high quality, easy-to-use product. To fully.
BROTHER 925D HANDBOOK Pdf Download. - ManualsLib
https://www.manualslib.com > Brands > Brother Manuals > Sewing Machine > 925D View and Download Brother 925D handbook online. Compact Overlock machine. 925D Sewing Machine pdf manual download.
Feb 11, 2018 | Brother Sewing Machines
Had trouble with the bobbin case sent it back to the dealer and he replaced it and charged me $60. I haven't used it all sumner and started to sew today and the needle plate completely fell apart
Bobbin cases are sometimes expensive but necessary, as is the needle plate. You can try locating a replacement. Search for:
Make Model needle plate
or
Make Model parts diagram
Aug 27, 2017 | Sewing Machines
How do I free up my reverse lever? Does anybody have the schematics on the mechanics of this Juki DNU-241?
1. Because you have had it since 1995 and haven't used it much I'm guessing that it has had some grease/oil to gum up. It would be a good start to take apart slowly and clean as you go. It may be necessary to use carburetor cleaner, toothbrush, rags and qtips together to do this.
2. Once this is thorough you will need to do a grease job. Make sure the grease is very clean. Many parts that are steel against steel movement will need to be oiled.
3. While looking and monitoring the movement inside the machine push the reverse button. It should move freely now. If not, it will need a little more effort. Also, check for a small part that extends from the button. Look to see if there is a screw that has came loose. It must be held tight in order for the extension to do it's job.
ANYWAY: CLEAN AND CLEAN SOME MORE.
LUBRICATE
CHECK SPECIFIC BUTTON AND CONNECTED PARTS INSIDE MACHINE FOR MOVEMENT AND LOOSE SCREWS.
Nov 18, 2015 | Juki Sewing Machines
HOW DO I REMOVE FRONT COVER ON KENMORE SEWING MACHINE
1. Newer machines are more difficult. You will have to find the hidden screws behind little plugs. You just pull out the plugs using a very thin screwdriver.
2. The next trick is to pull the machine apart. Their are snaps to unsnap by pulling. Pull a little on areas to see where the snap areas are holding parts tightly together. You will have to pull hard to get these areas unsnapped. You will get it but it takes a little work. Don't pry with your screwdriver or you will ruin the appearance.
3. The older machines are easier. Just unscrew and the parts come apart.
4. Whichever you are working on use some masking tape to mark the screws or hold the screws in the holes they come out of. If you don't do this you may have a problem when it comes time to reassemble.
Sep 03, 2015 | Kenmore Sewing Machines
Janome memory 7
LOOK ON EBAY. LOOK ON CRAIG'S LIST: WHY DO YOU THINK THE SOLENOID? WAS THE MACHINE MOTOR IN MOTION OR DID IT JUST BEGIN AFTER YOU TURNED ON THE MACHINE? ANYWAY, IT COULD BE MANY PROBLEMS BUT IF YOU ARE VERY GOOD AT TAKING THINGS APART I WOULD LOOK AT BURN MARKS ON THE MOTHERBOARD.
Apr 24, 2014 | Janome Sewing Machines
How to take apart a signer 7430 model
You can remove screws bottom plate, however, unless you are mechanically inclined, I would take in for service. Lay machine back on soft cloth or old towel. Don't lose screws! Oil moving parts one drop good quality sewing machine only and use Singrr lubricant on gears. If you don't have oil or lubricant, you can blow hair dryer 1-2 minutes and put plate back on. Never oil or lubricate plastic parts! One drop oil on shuttle hook, Run scrap to distrubute oil before sewing on project fabric ! Jimmy
Apr 03, 2012 | Singer Sewing Machines
What twin needles do I get for my overlocker ,It is a Janome Mylock 134D Are the needles universal or do I have to get a special one for this machine
I think Janome Mylock 134 has 2 separate needles. They are #11 or #14 for sergers and secured by 2 independent setscrews. I saw on ebay the instruction book with the owner's handbook for Janome Mylock 134D.
Jun 23, 2010 | Janome MyLock 644D
Threading a husqvarna huskylock 1001L serger
Solution taken from "Handbook for Huskylock Sewing Machine Models 1001L/1000L/1000"
1. Raise the presser foot by using presser foot lever. When the presser foot is raised, the two thread tension discs in the thread tension control panel are released so that thread passes freely between them. Otherwise thread tension may not be correct.
Important! When threading the needle, always be sure to lift the presser foot lever, and also take care to thread in the proper order.
Threading order:
1. Upper looper thread (green)
2. Lower looper thread (blue)
3. Double chain stitch looper thread (purple) in case of 5 thread stitch or double chain stitch
4. Right needle thread (red)
5. Left needle thread or double chain needle thread (yellow)
Caution!
Because the left thread tension dial (yellow) is used for either the left needle or the double chain stitch needle, these needles will never be used at the same time.
Upper looper (green) sequence:
1. Thread holder (silver triangle openings attached to thread holder stand)
2. Thread guide (flat silver clips just behind thread tension disc)
3. Thread tension disc (circular knobs with numbers for tension setting)
4. Pull thread around upper looper guide and upper looper
5. Pull thread into hole of upper looper
Lower looper (blue)
Repeat 1, 2, 3.
4. Pull thread around guide (see color coded chart inside front serger cover).
Easy threading mechanism (for lower looper)
1. Pull out the lower looper threading lever
2. Thread the lower looper and position the thread on hook of the lower looper
threading lever.
3. Push the lower looper threading lever back to its basic position while
holding the end of the thread.
Caution:
When returning the lower looper threading lever, always make sure that the two
blue triangle marks (directional arrows) meet each other.
Left needle thread (yellow)
Important: Thread the needles after threading of lower looper and upper looper.
First raise the presser foot lever, and then thread the needle threads in order shown in color coded thread guide.
Jun 24, 2008 | Sewing Machines
Janome 6019QC Mechanical Sewing Machine Logo
67 people viewed this question
Top Janome Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Eva Hack
Level 1 Expert
Are you a Janome Sewing Machine Expert? Answer questions, earn points and help others
