Question about Magic Chef 31000 Gas Kitchen Range
Our computer controls no longer work We can not
Our computer on our stove top no longer works.
The clock works, but we cannot get the oven past 110 degrees.The timer works, but not the oven.
Thank you.
  • 254 Answers
If it is gas i would check the either bake or broil ignitor as both cycle on and off to preheat oven,, if one is out u will experience the problem u are discribing. some replacement ignitors are sgr403 or a 12400035 u can get pics of these ignitors on repairclinic.com hope this helps..
Posted on Feb 07, 2010
What's wrong and how do I fix it?
The circuit breaker outside in the power panel for the stove has a bad breaker. It will be two breakers with their handles joined together by a pin so if one tripe it takes the other so 220 V is no longer present. When one, but not the other trips you only have 110 V. That's why the lights and clock still work but no heating elements.
Nov 16, 2015 | Frigidaire Kitchen Ranges
Model # 79094320300 the clock and oven does not work on my Kenmove flattop stove, what can I do about it?
The clock runs on 110 volts and the oven at 220 volts. If the cook top is on, the issue is in the stove. Best left to a qualified technician.
If the cooktop is also not functioning, check the breaker.
Jun 19, 2014 | Kenmore 30 in. 42701 / 42702 / 42709...
Large pop noise tonight while using oven, then problems where buzzer would come on by itself & lock oven. Oven does not work now, nor do the buttons make the usual noise. The stove top burners work...
Sounds like you overloaded a capacitor on the clock assembly. Before you replace the clock, you should check the voltage to your stove to be sure it's a steady 110 to 125 volts. But yes, it sounds like your combo clock brain got zapped.
Mar 07, 2010 | Kenmore 79012 / 79014 / 79019 Gas Kitchen...
Water spilled down the stove top causing the oven
ater spilled (4-5 cups) on the stove top running down into the stove control panel face (where you view oven temp, timer, etc). No water ever dripped into the oven or oven window. The stove top still works but the oven, warming drawer, clock are all non responsive after three days. No buttons on the control panel work at all. What repair is needed?
Jan 06, 2010 | KitchenAid KDRS807SSS Dual Fuel (Electric...
I have a Frigidaire stove model number fef364dwa everything works on control panel. all surface lights work,clock works oven controls work, only the eyes don't get hot and oven doesn't get hot. do you have...
your stove is 220 volts,the lights, clock and controls, they work on 110 volts, and when there is a short on the 220 part of the stove, the elements work on 110 volts.that's the reason they only get warm. there is a short in your stove.
Dec 09, 2008 | Kitchen Ranges
Oven wan work
make of stove .. digital or standard controls .. may not even be the oven ovens are 220 volts 110 works stove top other 110 works oven
Aug 24, 2008 | Kenmore 40494 / 40495 / 40499 Electric...
The indicator lights and clock on our glass top slide in stove work, but the burners and oven do not heat
From what you are describing, the power to your stove is incorrect. The diagram indicates the voltages that should be present at the receptacle, I suspect one of the 110 volt legs is bad at the receptacle or circuit breaker. The clock operates on the good 110 volt leg. The burners need both 120 volt legs to be good because the burners and oven need 220 volts to work.
Jul 11, 2008 | Frigidaire Kitchen Ranges
Kenmore Elite Electric Convection Oven Not Working
Check the voltage at the wall Sounds like you have lost one 120 voltage side Red to white should read 110-120 black to white should read 110-120 red to black should red 220-240 check at range and at the wall hope this helps
Aug 25, 2007 | Rangemaster Classic 110 (Dual Fuel) Dual...
Magic Chef 31000 Gas Kitchen Range Logo
173 people viewed this question
Top Magic Chef Kitchen Ranges Experts
paulcarew
Dan Webster
Dan Webster
Mike Carew
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
