Question about Canon CanoScan 8400F Film Scanner
I have new Apple laptop, and I plugged my Canon scanner into my computer but it won't scan
  • 600 Answers
Check on the canon website for software or drivers, or try image capture in applications.
Posted on Apr 29, 2010
What scanner drivers do I need for scannerCS5600F .Just had new hard drive in iMac running OSX Lion 10.7.5
No additional drivers are necessary. Your CanonScan 5600F is listed in "Printer and Scanner software available for download," http://support.apple.com/kb/HT3669 .
To add your scanner, simply plug it in. If it does not appear in Apple Menu > System Preferences > Print & Scan, you may need to run Software Update (also from the Apple Menu, second item down), and then click the plus ( + ) button in the lower-left of Print & Scan, select your scanner, and then add the printer.
The default scanning application in OS X is Image Capture. After completing the above steps, open Applications > Image Capture and you should see your scanner listed on the left.
Sep 11, 2013 | Computers & Internet
My Canon P-150 keeps giving me a "double feed" error and won't scan.
Uninstall all drivers and scanning software. Switch off the comp and Scanner, restart the scanner first and then the computer. Then reinstall software again
Jun 07, 2012 | Canon imageFORMULA P-150 Personal Document...
DR-6080 not recognised after reloading Windows 7 (32-bit) on laptop. Re-installed latest driver (says Win7 supported) successfully but still won't work, Anything?
Disconnect the scanner from the computer. Uninstall driver software, shut down and restart the Comp. Reinstall the driver. (http://software.canon-europe.com/software/0036991.asp?model= ). connect the scanner and the system will report USB device plugged in. This should work.
S. Mohan. Chennai, India
Dec 02, 2011 | Canon DR-6080 Path-Through Scanner
RE Canon scanner problem 'No driver found'. downloaded new updated software twice and got the same message. Using Apple Mac Os x (snow L.)
Pls disconnect the scanner, uninstall scanner driver and switch of the computer. After restarting, run Scan disk and then install appropriate driver for MAC OS and connect the scanner. This should work.
S. Mohan
Sep 21, 2010 | Canon CanoScan 4400F Flatbed Scanner
I plug in my cannon lide 20 scanner and it doesn't stop scanning
I had this problem with my old Canon scanner and my new Canon scanner. I mistakenly threw my old scanner away, believing the problem to be terminal, only to find the new scanner demonstrates the same problem. The problem appears on whatever computer I install the drivers on (I have 3 computers). Constantly unplugging and plugging the scanner back into the USB port eventually sorts the problem out, i.e. the scanning arm will go to the 'home' position and stay there waiting for some scanning action.
I presented this problem to technical support of Canon, and this was their response.....
Thank you for contacting Canon.
It appears that your Scanner is receiving commands from your PC to scan. That means that the scanner can only operated when a command is given by your PC, the scanner can not operate all by itself.
In that case we suggest you contact the manufacturer of your PC or Microsoft for further assistance in solving this problem with your operating system.
I hope this information is of use to you.
Well there you go, the biggest example of 'pass the buck' you may have ever seen.
Having been a software enginner and using computers for the last 25 years, I sort of don't believe this - AT ALL. My only conclusion is to get a new scanner and make sure it isn't a Canon.
If you find out the answer to this problem, and I haven't thrown my scanner away by that time, then I'd be interested in it.
Nov 08, 2009 | Canon CanoScan LiDE 30 Flatbed Scanner
Scan function won't work with Mac OS10.5.5 & Airport
I plugged the printer cable directly to my laptop instead of trying to scan using the airport wireless router. Plugging it in did the trick.
Thank you,
Jtoussa
Nov 22, 2008 | Canon PIXMA MX310 All-In-One Printer
Canon dr 2050c
i want the driver for canon dr-2050c
Aug 14, 2008 | Canon DR-2050C Path-Through Scanner
Apple Canon CanoScan N670U
Are you referring to the scanner or the computer not having a light on?
The scanner only lights up when it is scanning. If your computer is running ok, check the Apple System Profiler to see if the scanner is detected. What Mac OS are you using? Leopard is not supported with this scanner model.
May 30, 2008 | Apple Canon CanoScan N670U Flatbed Scanner
Apple laptop M8407 vs. n670u canoscan
Keep in mind that connecting a specific scanner to the computer would have nothing to do with the computer now powering on unless there are physical computer hardware problems. Disconnect any uneccessary external peripherals from the computer (printers, scanners, webcams, etc.) and see if the computer will power on. Remove the computer battery and put it back in. Check power connections and test to make sure the electrical outlet is working by plugging something else into it.
Canon mp610 scanning problem
The readme says that some USB hubs have an issue.
I was having problems and was connected via a hub. I removed the hub and connected the printer directly to the back of the PC and voila scanning is all good.
ALex.
Apr 20, 2008 | Canon PIXMA MP600 all-In-One InkJet...
Canon CanoScan 8400F Film Scanner Logo
54 people viewed this question
old marine
old marine
